Air conditioning on/off
Discussion in '3rd Gen Tundras (2022+)' started by DynoDog, May 6, 2023.
  1. May 6, 2023 at 12:43 PM
    DynoDog
    DynoDog [OP] New Member
    Do you guys have to turn your air-conditioning on every time you get in the vehicle? 2023 plat.
    And how was your temperature with the AC on?
  2. May 6, 2023 at 1:31 PM
    Breathing Borla
    AZ
    I just got my truck and tested out the ac since I have read complaints here, it did seem to need to be turned down much more to get cool and wasn’t blowing quite as well as it should for a given temp
    I went in with Carista and after I turned off that stupid ass engine fake noise I turned down the temp dial calibration to -2, it works perfect now
    cartage1 and Eurodriver like this.
  3. May 6, 2023 at 6:21 PM
    xc_tc
    xc_tc New Member
    If you use auto, it turns on the AC automatically but depends on what temperature you set. That’s why when you hit AC button it shows AC off first.
  4. May 6, 2023 at 9:20 PM
    DynoDog
    But I shouldn’t have to turn it on every time I get in the truck. Errrr Hell the seat heat stays on! So If I remote start to cool down…..it won’t work. Texas heat is killer
  5. May 6, 2023 at 9:29 PM
    Chugbug
    Chugbug New Member
    2023 Platinum, Midnight Black
    Change the settings for your vehicle in the Mutimedia screen. Go into the radio and then settings, then vehicle then tap climate then turn auto ac off. This will allow the ac or heat to default to what you last had it set on.
    cartage1, Raven67, Chikwaters and 2 others like this.
  6. May 6, 2023 at 11:32 PM
    DynoDog
    Thanks, I’ll give it a try.
    Chugbug[QUOTED] likes this.
  7. Dec 27, 2023 at 6:19 AM
    GrayPlat27
    GrayPlat27 New Member
    Lower Hudson Valley, NY
    2022 Tundra Platinum
    To Breathing Boria. My 2022 Platinum Tundra cabin temperature is off 4-5 degrees (higher) than the temp setting.
    My dealer says there is no cabin temp calibration for the 2022 tundra. Does anyone know? I can try the screen settings seeing the pic on your post but want to ask if anyone can confirm for 2022.
  8. Jan 2, 2024 at 7:21 AM
    GrayPlat27
    No ability to calibrate the cabin temp on the 2022 tundra that I can find. Seems Toyota made a change for 2023 to be able to calibrate.
  9. Jan 2, 2024 at 7:26 AM
    kirkb
    kirkb Lurking Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    Are you using the Carista app like what was mentioned in the post #2 bove?
  10. Jan 2, 2024 at 7:27 AM
    DRP
    DRP Old Member
    Dave
    Carista app and OBD dongle can do it. Do a search on Carista in this forum.
    Mattedfred likes this.
  11. Jan 2, 2024 at 7:31 AM
    GrayPlat27
    Ah, I did not realize Carista is an app, TY to you all. Will try that, not surprised the dealer has no clue.
  12. Jan 2, 2024 at 8:03 AM
    DRP
    DRP Old Member
    Dave
    Dealer should be able to do it but apparently they have better things to do than provide good customer service....
    cartage1 likes this.
  13. May 1, 2025 at 2:13 PM
    AroundToyotaFan
    AroundToyotaFan New Member
    Just figured this out with my 24 Tundra. You have to go into settings and turn off the a/c auto feature. Weird. But it worked.
    Hope it works for you too
    Raven67 likes this.
  14. May 1, 2025 at 3:36 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    In the summer, I leave the auto A/C on. From Fall to Spring, I set the A/C to off on Auto. IF I need A/C, I just push the A/C button just like old school days.
  15. May 2, 2025 at 5:50 PM
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    Slightly off topic, but not by much..., does it drive anyone else nuts, the AC switch does not illuminate? I mean, how cheap.., the panel looks like a Christmas tree, but the a/c switch does not have the illuminated indicator...
    Raven67 and kirkb like this.
