Cam Bolt replacements?
Discussion in '1st Gen Tundras (2000-2006)' started by vst, May 5, 2023.
  1. May 5, 2023 at 10:45 AM
    vst
    vst [OP] New Member
    Scott
    2005 DC 4wd
    Hey guys I’m going to swapping out my lower control arms and I’m sure my cam bolts will seized like a lot of other peoples and was wondering if I should go with a new stock Toyota set which are pretty expensive or if the spc one’s are fine. I’ll link the ones I’m talking about here Any info would be appreciated
  2. May 5, 2023 at 10:56 AM
    I would go OEM. I've heard mixed reviews on SPC.
    vst[OP] likes this.
  3. May 5, 2023 at 1:46 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
  4. May 6, 2023 at 8:46 AM
    Big beef with non-OEM is, as I recall, plastic sleeves.
    Not being a part I've had to replace yet, and not having bought any myself, I have to trust the other member(s) who said that.
    That's not a part I'd want to have plastic sleeves for, so as long as they're not plastic, I'd probably at least try to save money. Just know, nothing sucks worse than spending half the OEM $$ on a non-OEM part, only to find yourself buying the OEM part later because the non-OEM part isn't good enough to do the job as well as OEM.
    nickrick78 and vst[OP] like this.
  5. May 6, 2023 at 9:41 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I've had to replace the SPC ones with OEM on other Toyota (4runner/Tacoma) vehicles as they wear out and start clunking. And they are lighter than our trucks.
  6. May 6, 2023 at 9:49 AM
    Are the SPC using steel sleeves or plastic? Just looking to fill in a blank on that one.
  7. May 6, 2023 at 9:55 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Plastic. Nylon iirc.
    shifty`[QUOTED] likes this.
  8. May 6, 2023 at 10:31 AM
    vst
    vst [OP] New Member
    Scott
    2005 DC 4wd
    Alright looks like I won’t skimp and go with Oem’s thanks
  9. May 6, 2023 at 10:56 AM
    Remember to coat the CAM sleeves and LCA bushing sleeves in anti-seize so if you ever need to do it again, you won’t have to cut them out.
    scooterprint likes this.
  10. May 11, 2023 at 7:00 PM
    bfunke
    bfunke Tundra Curmudgeon
    Yup - OEM and liberal antiseize
  11. May 11, 2023 at 8:31 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Don't coat the washers, bushing sleeve ends or the subframe itself. Those need friction to retain your alignment.
  12. May 11, 2023 at 8:32 PM
    Are the cam lock plates worth it in your opinion?
  13. May 11, 2023 at 8:34 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    If you're wiping out the adjustment off-road, sure.
    At that point you'll probably want to reinforce the subframe tabs too. Add some weld along the backside or buy/make the reinforcement/replacement that gets welded on.
  14. May 11, 2023 at 9:08 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    OEM cam bolts with a very generous amount of anti seize. the issue with the plastic sleeves is the bolts will still rust.. which ends up causing the sleeve to swell... and well it ends up being a destroyed bolt when it comes out
