2011 5.7 Tundra Transmission issues
Discussion in '2nd Gen Tundras (2007-2013)' started by K_Lym, May 4, 2023.
  1. May 4, 2023 at 4:33 PM
    K_Lym
    K_Lym [OP] New Member
    Kameron
    2011 Silver 5.7 2-wheel drive Tundra
    Lifted
    Need help!
    My transmission sprung a leak with the seal gasket were the drive shaft and trans inter lock. I went to the dealership and ordered a new one, but it doesn't fit. I also tried O'Rilly's, and the one they gave was too small?!
    Im starting to wonder if the transmission was replaced at some point; I'm the second owner, but I bought it 2016, so I cant imagine the transmission would go bad in 5 years?
    How can search for what transmission this without relying on the VIN, or door panel info?
    Is there a data base I can use?
  2. May 5, 2023 at 5:32 AM
    Monkey2583
    Monkey2583 New Member
    08 silver Tundra crew max 5.7
    Just led taillights and smoked headlights
    You'll have to give vin to dealership with 2 or 4 wheel and if has tow package how many lines on trans cooler
