2023 Sr5 AC not very cold
Discussion in '3rd Gen Tundras (2022+)' started by Cheerio915, May 4, 2023.
  1. May 4, 2023 at 6:54 AM
    Cheerio915
    Cheerio915 [OP] New Member
    2023 Sr5 TRD off-road
    Anyone here have issues with the ac not blowing too hard or too cold?
  2. May 4, 2023 at 7:44 AM
    TheLordwoulddriveaTundra
    TheLordwoulddriveaTundra New Member
    2022 Tundra Platinum Crewmax 4WD, Mag Grey
    Talons Cat Plate Tuff Skinz Inserts RetraxOne XR Bed Cover Premium Shield PPF Revivify Coating OEM Console Safe WeatherTech Mats
    There seems to be a general consensus the A/C does not work as well as previous gen Tundras. Mine takes much longer to cool the interior than my previous Tundra. It also does not blow as hard. Next time you go to the dealer, have them check it out to make sure it's functioning correctly. They will likely tell you "it's working as intended."
  3. May 4, 2023 at 7:51 AM
    My ventilated seats work well. As long as the bean bag stays cool, the A/C doesn't bother me too much. Definitely not like the arctic blizzard that came out of my previous gen, but it works well enough. Obviously A/C comfort is subjective based on the owner.
  4. May 4, 2023 at 8:03 AM
    nodak67
    nodak67 New Member
    JR
    well the new freon by subjective evals doesnt seem to be as effective as the old stuff
    1234YF
    pros and cons of 1234YF and the new equipment used for servicing
    Pros:
    • Recovers 95% of refrigerant in the system.
    • Recharges within a ½ ounce of specification.
    • Will not allow the recovery of contaminated refrigerant.
    • Will not recharge if leaks are detected.
    • More efficient.
    Cons:
    • More costly and complicated to maintain. 134a is about $5 per pound. The new refrigerant costs about 10 times as much. The average vehicle uses about one to one and a half pounds.
    • It’s mildly flammable. However, it will not ignite without a heat source greater than 1650 degrees Fahrenheit. According to theSAE, the refrigerant is safe for passenger use. Risk of fire is low in the case of an accident or refrigerant leak into the cabin area.
  5. May 4, 2023 at 8:09 AM
    Hella Krusty
    Hella Krusty New Member
    I find if I hit the AC on then press AUTO....it blows 3 X as hard
    Jongie123, jhtram, Medic343 and 2 others like this.
  6. May 4, 2023 at 8:13 AM
    Cheerio915
    I’ll try that
    Hella Krusty likes this.
  7. May 4, 2023 at 8:13 AM
    The EPA is looking to drop some more refrigerant regulations soon. Can't wait to see the impact of that.
    s
    OnThaLake likes this.
  8. May 4, 2023 at 8:45 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    This.
  9. May 4, 2023 at 1:32 PM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    Mine works just as well (if not better) than my ‘18 Limited CM.
  10. May 4, 2023 at 1:53 PM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    My wife complains about the air velocity coming out. It is adequate but the weakest of any recent vehicle I have had. I run it 2-3 degrees cooler than the previous Ram otherwise I would melt.
  11. May 4, 2023 at 2:18 PM
    Markysharky
    Markysharky New Member
    Not as cold as some older vehicles. It should be cool but not ice cold like vehicles of the older days due to higher efficiency compressors and newer refrigerant. Aka more fuel efficient but slower to cool off. I think the vent temps are around 45-55ish degrees F on max ac depending on ambient outdoor temperature.
  12. May 4, 2023 at 7:36 PM
    Hella Krusty
    I should note that I live in BC so we are just crawling into the heat months. Today i left the golf course after the truck baked there for 6 hours and it cooled right down while on the AUTO setting.
  13. May 4, 2023 at 7:41 PM
    Cheerio915
    I’m in Texas and we are already in the 90’s lol
    sablue and Hella Krusty like this.
  14. May 4, 2023 at 7:50 PM
    Bobroger79
    Bobroger79 New Member
    2023 midnight black tundra limited
    Mine is not impressive, temperature wise or output from the vents, especially the center vents
    Cheerio915[OP] likes this.
  15. May 4, 2023 at 7:55 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    mine will do 30 when its 92 outside, so I'm happy
  16. May 4, 2023 at 9:03 PM
    Cheerio915
    Yea my center vents are trash unless I put max speed
  17. May 4, 2023 at 9:19 PM
    Jarrow
    Jarrow New Member
    You gotta press that recirculate button and it’ll blast cold air.
  18. May 4, 2023 at 10:05 PM
    Eagleye
    Eagleye New Member
    22 SR5 4x4
    Rear seat cover, bed mat
    Yes, mine got slowly worse over about a months time after new. The condenser fittings were leaking and Toyota replaced the condenser, been working well since.
  19. May 5, 2023 at 3:42 AM
    6thyota
    6thyota New Member
    23 TSS Tundra
    Mine seems to struggle cooling and blower is very weak and MUCH louder than my other Tundra’s to get the same volume of air out.
    It makes me think the duct work is miss aligned or something
  20. May 5, 2023 at 7:55 AM
    Cheerio915
    Yea I got ceramic 5%
  21. May 5, 2023 at 8:02 AM
    gj953
    gj953 New Member
    East Coast
    2023 1794 Hybrid TRD OR Blueprint
    From SWFL - so we've had temps in mid 90's already. I notice it's not as cold as my 1st and 2nd Gen. Also, when in ECO mode, it backs off a bit on cooling as part of the efficiency for that mode. I did ceramic tint on every glass surface (front/pan/side/rear) and that made a huge difference. Keeps the heat out a fair amount more, while sitting, and when under way, the cooling can keep ahead of it, and actually go very cold.
  22. May 5, 2023 at 8:11 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Coworker of mine had the same complaint. Took it in and it turned out the system was overcharged. They drained it back to normal levels and he said it was better.
    Still not as icy cold as his 2020 was though. His hypothesis is that the interior is more square and the air doesn’t circulate as well as the previous tundra. Pair that with a blower motor that just can’t quite keep up and it makes sense to me.
  23. May 5, 2023 at 12:07 PM
    sablue
    sablue New Member
    jay
    2022 tundra plat
    I think here is south Texas it's the hot humid air that causing problems with he newer system. Mine will not stay cool at the temp settings. I placed a thermometer at the vent . At first it lowers to the set temp (73) but then fluctuates during the drive (74-76)
  24. May 5, 2023 at 12:34 PM
    xc_tc
    xc_tc New Member
    Someone mentioned it but ECO mode also puts the HVAC into an ECO mode which cools less.
  25. May 5, 2023 at 12:47 PM
    forzamrit
    forzamrit New Member
    23’ Tundra Limited DC TRD OR
    Mine works great. The whistling is annoying.
  26. May 5, 2023 at 1:36 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Is it something that happens when in traffic or all the time? I know that in traffic my A/C isn’t as cold as when you moving.
  27. May 5, 2023 at 2:30 PM
    Cheerio915
    All the time- but I’ve been using auto mode and it cools
    More- but just saw that eco mode also puts ac to eco mode. (Not sure if someone is trolling- or if it’s true)
  28. May 5, 2023 at 2:43 PM
    OnThaLake
    OnThaLake New Member
    Jarrow and Mattedfred like this.
  29. May 5, 2023 at 2:45 PM
    gj953
    gj953 New Member
    East Coast
    Seriously, I was sitting at a light, and put it in Eco, and heard the fans slow down, and it didn't feel quite as cool. Then, I put it back in Normal mode, and heard the fans pick up just a slight bit, and the air felt a shade cooler.
  30. May 5, 2023 at 2:45 PM
    gj953
    gj953 New Member
    East Coast
    LOL - OMG roflmao ! Now, that's funny!
