23 tundra wiring Drl vent light
Discussion in '3rd Gen Tundras (2022+)' started by Canzures_77, Apr 28, 2023.
  1. Apr 28, 2023 at 7:14 PM
    Canzures_77
    Canzures_77 [OP] New Member
    Cesar
    23 Tundra SR5 CC 4x4
    Hello everyone, I’m new to the forum and new to owning a Tundra. i have a 23 SR5 crew cab and I recently bought these vent drl led lights.
    I tried wiring them but I can’t seem to get the turn signals to work.
    anyone else have these lights if so how did you wire them and how did you get the turn signals to work?
  2. Apr 28, 2023 at 9:04 PM
    Fxclm5
    Fxclm5 New Member
    I'd try the mfg where you bought them from to provide some install instructions. If you bought em from AliExpress or another china site, good luck - you need to find the original store that has the install instructions
  3. Apr 29, 2023 at 4:24 AM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    There are a few YouTube videos out there about them. You may start there.
  4. Apr 29, 2023 at 4:58 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    I take it that your truck isn't a hybrid, bc those are the vent slots for the turbo intercooler.
    OCzipPAC likes this.
  5. Apr 29, 2023 at 5:39 AM
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    I wouldn't be blocking those vents as they are actually functional
  6. Apr 29, 2023 at 5:59 AM
    Canzures_77
    Cesar
    It’s not a hybrid and I bought them from Amazon… the instructions are in Chinese and don’t really say much.
    also there’s nothing behind these vents the turbo coolers are closer to the big center grill so I don’t think they actually do much
  7. Apr 29, 2023 at 6:01 AM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
  8. Apr 29, 2023 at 6:06 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    Like others have mentioned, there’s a small intercooler radiator behind each of those two small vent grills on either side of the center grill surround. These aren’t “active” like the center grill, and require constant airflow to maintain efficient cooling for the turbos. I’ll be installing sections of window screening between the radiators and grills (as I did for the grill on my first gen) to help prevent damage to the radiator fins and bug/debris build up. I always use black aluminum screen and check it periodically, remove and brush or hose off the bugs-etc and reinstall. Works very well
    TundraDan723 likes this.
  9. Apr 29, 2023 at 8:21 AM
    Canzures_77
    Cesar
    Bump! Anyone wired these?!
  10. Apr 29, 2023 at 9:05 AM
    chance12
    chance12 New Member
    GA
    23 Tundra CM Limited
    do you have pictures or a link to what you use? this sounds like a great idea.
  11. Apr 29, 2023 at 11:37 AM
    Fxclm5
    Fxclm5 New Member
    Can't block these flow vents - they don't even fully channel air directly to those intercoolers, 80%+ of the intercooler is being cooled from the main front grill
    In other words, there is 0 ram air effect where this guy is installing drl, look at the pic the guy posted above lol
    =JSG= and Black widow TRD like this.
  12. Apr 29, 2023 at 2:16 PM
    Canzures_77
    Cesar
    Yea that’s what I’ve read from other forums… I’ve looked on YouTube and google and can’t seem to find a good wiring diagram to help me wire these correctly
  13. Apr 29, 2023 at 3:52 PM
    =JSG=
    =JSG= New Member
    2006, 2017, 2021 Tacoma. Soon 2022 Tundra :)
    The vents are there for a reason. Why stop here? Do a similar setup for the main grille :monocle: lol
    Bulldog6 and Soupbean77 like this.
  14. Apr 29, 2023 at 4:02 PM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    If your going to install them and want those as DRL's then I honestly would tap the hot leg on the existing wire harness of the DRL's but if you want control of them to turn on off on command then just wire it if it has a rely then it's pretty much cut and dry task.
  15. Apr 29, 2023 at 4:32 PM
    Canzures_77
    Cesar
    I have them wired to the fuse box, so they turn on with ignition so they work, but once I connect the turn signal, the white DRLs turn off and the amber turn signals take over which is not supposed to happen.(amber light is only when turn signal is activated)
    They come with a white wire that’s supposed to connect to the headlights + wire but I’m not sure what color wire that is.
    Also I’m connecting to the center wire on the turn signals not sure if that’s the problem
  16. Apr 29, 2023 at 6:01 PM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    I'd have to see the trucks schematic diagram to verify exactly which wires to poach.
  17. Apr 30, 2023 at 9:05 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Try using a DMM and find your wires.
  18. Apr 30, 2023 at 10:29 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Y'all can find the wiring diagrams here..
    Ultimate TUNDRA Wiring Diagrams Collection | Toyota Tundra Forum (tundras.com)
    There are a couple different headlight diagrams.
    I don't know anything about Gen 3 headlights and DRLs.
    Turn signal diagram.
  19. May 1, 2023 at 2:54 AM
    Soupbean77
    You can get a roll of black aluminum window screen at any hardware store… Lowe’s, Home Depot, etc.
    Cut to fit and attach between grills and radiators. I believe the center grill has active louvres, so have to make sure it doesn’t interfere with those
    chance12[QUOTED] likes this.
  20. May 1, 2023 at 6:43 PM
    Canzures_77
    Cesar
    Bump! Anyone have these installed? Just want to make sure I’m doing it right
    FREEDOMcomesatacost likes this.
  21. May 2, 2023 at 8:52 PM
    FREEDOMcomesatacost
    FREEDOMcomesatacost Go ahead, pull my finger…
    Just call me Easy
    Louisiana
    2022 SR5 Crewmax supersonic red
    Too much to list…
    I didn’t want to post anything because I can’t really help you. I have these installed on my truck but I have an install guy that does all my lights/wiring work. So I don’t know crap about how to fix it but mine work perfect. The 5 white lights stay on constantly then when you use the turn signal they turn Amber in color and flash in a up and down sequence. I like em. I have the exact same kit you do. Sorry again wish I could walk you thru hooking em up right but I know zero about wiring! Good luck bro…..
  22. May 3, 2023 at 8:21 PM
    Canzures_77
    Cesar
    I figured it out.. it was not that hard actually I was just wiring to the wrong turn signal wire.. and I also changed my fuse tap location and now it works perfect like stock
  23. May 3, 2023 at 9:43 PM
    Fxclm5
    Fxclm5 New Member
    pics?
  24. May 10, 2023 at 5:08 PM
    Canzures_77
    Cesar
    52E7320F-4A16-4D82-B816-A75F6F8261B9.jpg 84EABF62-5D89-43C3-9A2D-BE42B70AAA8F.jpg Sorry I hadn’t been on the site for a minute. Here’s the all whites and when I put the turn signal
  25. Aug 15, 2023 at 6:11 PM
    Handyman MD
    Handyman MD New Member
    2022 Tundra SR5 4X4 double cab
    K&N air filters, side grill DRL (3 vertices LEDs), in bumper off road LED light bar, BFG all terrain tires, blow off valves for the turbos.
    I just got similar DRLs. Mine are 3 vertices long leds. Can you provide pics of the wiring to the turn signal and to the fuse box? Also where did you put the ground too? No good instructions anywhere.
  26. Jan 9, 2024 at 10:57 AM
    DEL&FEFE
    DEL&FEFE New Member
    Ramon
    2024 Blueprint Tundra TRD
    None ATT
    I was thinking the same thing, I purchased these as well, but this evening I'm drilling a few holes in them (just in case) however I do see that the air from the OEM is so very minimal, it wouldn't make much of a difference. My Toyota Tacoma was totaled out (mid-build) 11-11-2023, but got my hands on a Blue Print 2023 Toyota Tundra Limited Off-Road. --- I ask myself all week, why mess with it-- but ultimately, I just wanna have fun. But we shall see how this turns out soon enough. New to the Forum and Searching, reading and catching up is next, LOL
  27. Jan 9, 2024 at 1:19 PM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Congrats man and welcome from MA.
  28. Jan 9, 2024 at 4:09 PM
    Handyman MD
    Del and FEFE,
    I have had a 2022 Tundra Double Cab SR5 since last March. I started having fun too. I did DRLs similar to yours. Peoe were saying those slots can't be blocked they are functional for air to your I tercoolers. True they are but the amount of air that goes through those vents is so insignificant. I have had mine since my last post with ZERO Intercooler cooling issues... None. I have done a lot of upgrades beyond that too and still no cooling issues. So don't sweet covering the vent slots and have lots of fun. I love my Tundra, the sound and the speed. Crazy fast it's a total sleeper truck. Has a cap on it with tools in the back for work. No one expects it to gap them from a roll or from the dig. I shame lots of people and love it.
    Welcome to the forum and your new truck.
  29. Jan 16, 2024 at 1:42 PM
    smileytn1
    smileytn1 New Member
    wonder if this vent is needed to cool the turbos?
  30. Feb 9, 2024 at 8:30 AM
    tundraxp23
    tundraxp23 New Member
    Do you have the wiring diagram of how you wired the lights up? I can find the blinker one, but what about the low beam? Can you provide how you wired those up? much appreciated. Thank You
