Are these found on 2WD Tundras?
Discussion in '2.5 Gen Tundras (2014-2021)' started by '08grade, May 2, 2023.
  1. May 2, 2023 at 6:29 PM
    '08grade
    '08grade [OP] New Member
    2008 DC V6 grade 1gr-fe
    2013 OE alloys. 2013 OEM head unit, Weathertecs,
    Reaching out to anyone who has a 2WD with the factory struts still installed. My 4x2 came with Autozone units, so I want to get back to OE for now.
    I know 07-21 is the same for tundras of the same type.
    The part numbers I want to put on my 4x2 are 48510-0C205 and 48510-0C205. They came off of a 2020 4x4, but I have reason to believe they are compatible. Any 4x2 drivers out there with these from the factory?
  2. May 2, 2023 at 6:54 PM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    Get some fox 2.0’s
  3. May 3, 2023 at 1:23 AM
    Blue By U
    Blue By U New Member
    Not sure where you're located but I have a set of factory Bilstiens with about a 1k miles on them. PM if your interested.
  4. May 3, 2023 at 3:05 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I have a 2021 base model 2wd. I'll look for stickers and take pics when I get to work.
  5. May 3, 2023 at 5:01 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Driver side: 48510-0C203
  6. May 4, 2023 at 12:36 PM
    '08grade
    Perfect! Thanks a ton! I found a "new" set of takeoffs" for 100 bucks.
    Jaypown likes this.
  7. Jul 17, 2023 at 1:13 PM
    '08grade
    YES!! they fit and work perfectly, now for 1000 miles. And they came off of a 2020 FOUR wheel drive. (non TRD)
    RichterScale likes this.
