Collapsed oil filter cartridge
Discussion in '2.5 Gen Tundras (2014-2021)' started by gizardlizard, Apr 14, 2023.
  1. Apr 14, 2023 at 4:24 PM
    gizardlizard
    gizardlizard [OP] New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    A co worker brought his crewmax Tundra with the 5.7 over for an oil change. He just got the truck. I get it up on the rack and discover it has the updated aluminum housing for the filter cartridge. I take it off and discover the cartridge is collapsed. Whoever installed the aluminum housing never transferred the perforated pipe from the plastic one. He ordered a new housing. Anybody else ever see this? 3C56516D-34E1-40BA-9A5C-87EA53D6CB5F.jpg
    omgboost and bulldog93 like this.
  2. Apr 14, 2023 at 5:03 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Only when that pipe is missing, that's it's primary purpose.
    WILLINH and NewImprovedRon like this.
  3. Apr 14, 2023 at 5:28 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Looks like it worked effectively since the debris stain is even but yes could have been better with the insert, do dohs..
  4. Apr 14, 2023 at 7:46 PM
    Rangers
    Rangers New Member
    Joe
    Oklahoma
    2017 Bad Barcelona TRD Pro
    TRD sway bar
    A perfect example of why you do your own maintenance, saves a little money but driving down the road knowing everything is ok is priceless.
    2mchfun, Mike59, WILLINH and 2 others like this.
  5. Apr 14, 2023 at 8:25 PM
    Until your in a rush and drain the trans instead of the oil pan………
  6. Apr 14, 2023 at 8:32 PM
    Rangers
    Rangers New Member
    Joe
    Oklahoma
    TRD sway bar
    Well don't rush like the techs do at the stealerships lol
  7. Apr 14, 2023 at 8:47 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    :rofl:Ouch
  8. Apr 15, 2023 at 6:11 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    agree 100%. I’ve been doing my own vehicle work since age 16. Knowing jobs are done correctly and having piece of mind is priceless. Trust no one….Especially stealerships.
    snivilous, coldcanuk, vtl and 4 others like this.
  9. Apr 15, 2023 at 7:52 AM
    2-4-5 trioxin
    2-4-5 trioxin New Member
    2020 Tundra Limited
    My brother in law did that with my sister’s Subaru. She never let him work on the car again.
    WILLINH and FrenchToasty[QUOTED] like this.
  10. Apr 16, 2023 at 10:16 AM
    stevesgraytundra
    stevesgraytundra New Member
    Stephen
    2021 MGM SR5 CM 4x4
    No, no, no…engine oil IS red.
    hagrid likes this.
  11. Apr 16, 2023 at 10:17 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The dorman oil filter housings are usually where I see this happen. When the filter collapses oil pressure drops too. Sometimes it’ll cause VVTI related codes
  12. Apr 16, 2023 at 10:27 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    This is why we can't have nice things.
    hagrid and fuzzamungus like this.
  13. Apr 29, 2023 at 11:53 AM
    TRDWarrior11
    TRDWarrior11 New Member
    2011 TRD Rock Warrior
    This very same thing just happened to me except I had the tube inside. I religiously run Mobil 1 and change every 5k miles. The last time I changed the oil, they were out of Mobil 1 and that Purple stuff was on sale. Bad decision! Stick to a good quality oil and change regularly.
    I also heard people having this issue if they run synthetic oil to 10k miles. Need to change the filter every 5k miles (synthetic), 3k miles (conventional). I am starting to think about changing the filter every 3k regardless at this point.
    WILLINH likes this.
  14. Apr 29, 2023 at 2:09 PM
    EarlyRiser
    EarlyRiser New Member
    2020 Black Tundra SR5
    Just for clarification, you are saying that following the Tundra maintenance guide causes this issue?
  15. Apr 29, 2023 at 3:21 PM
    TRDWarrior11
    Absolutely not. I believe that the purple stuff I put in must not be rated for 5k miles. I have over 120k miles on my Tundra and never experienced this until I ran a different lubricant. I believe this stuff plugged the filter tight, causing the filter to collapse. If there are other issues, I guess I will find out next time.
  16. Apr 29, 2023 at 3:41 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Is that a Toyota filter housing and filter? I've never seen the metal tube collapse before.
    coldcanuk and WILLINH like this.
  17. Apr 29, 2023 at 4:47 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I 2nd that ^^^ inquiry. Just. Plain. Weird.
    I'm at 92k miles and do the oil AND filter at 10,000 miles. I'm just a distant lonely voice in the deep woods saying "never ever ever had any filter related issues."
    WILLINH likes this.
  18. May 1, 2023 at 3:30 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Wow, never seen that before..
  19. May 1, 2023 at 4:05 PM
    AZBoatHauler
    So.Arizona
    snivilous, WILLINH, NWPirate and 2 others like this.
  20. May 1, 2023 at 4:43 PM
    TRDWarrior11
    Aluminum housing, Mobil 1 filter. I was wondering if I had a brain fart and put the tube into a Fram filter but did not. Has to be the Purple oil. Up in WI, I run 0w20 in the winter and just switched back to 5w20.
    Use a good quality oil is all I can say. Lesson learned.
  21. May 1, 2023 at 5:29 PM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    I use Toyota filters and 0w-40 and never had this happen. I do not believe it was the 5w-20 oil.
  22. May 1, 2023 at 5:51 PM
    TRDWarrior11
    I have over 120,000 miles, always use Mobil 1 oil and filter (Fram filter as a last resort) and never had this issue until that one use of Royal Purple. Coincidence?
  23. May 1, 2023 at 6:53 PM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Since the top is crushed along with the sides, I would assume it interfered with the housing before I believed it was due to flow restriction. Flow restriction should have buckled the sides and not the top. That is my engineering opinion based on the photo but who knows. It's a crazy failure for sure.
    AZBoatHauler likes this.
  24. May 1, 2023 at 7:11 PM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    Coincidence? Sure. All I have to offer is that I’ve used RP on several vehicles including this one and never had a collapsed filter. I wouldn’t think oil alone is capable of doing that, but stranger things have happened.
  25. May 1, 2023 at 7:14 PM
    AZBoatHauler
    So.Arizona
    One thing is certain - the brand of oil had nothing to do with this.
    snivilous, BillyB, coldcanuk and 4 others like this.
  26. May 1, 2023 at 7:19 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  27. May 1, 2023 at 8:02 PM
    Jack_A_Lope
    Jack_A_Lope New Member
    Aaron
    Santa Barbara County, CA.
    2019 Tundra 4X4 SR5 TRD Sport
    Pro Comp Lift, Tires & Wheels, Steel front bumper with LED lighting, Cross bed tool box, bed rails, custom aftermarket sound system
    That thing looks like someone took a pair of channel locks to it. Your saying that happened while installed in the truck? I can't think of any reason that that would happen. The oil pressure would need to be off the scale to do that.
  28. May 1, 2023 at 10:32 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    I can't think of anything crushing that tube except the force of installation.
    WILLINH, RichterScale and Larly5000 like this.
  29. May 2, 2023 at 2:01 AM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Yes.
  30. May 2, 2023 at 2:52 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    This is why I decided against getting an aftermarket filter housing, or one from another vehicle.
    An original housing with an original stand pipe that's still attached properly is all that will ever be on my truck.
