2010 Toyota Tundra 4.6 4 pin Alternator Connector Wiring < HELP
Discussion in '2nd Gen Tundras (2007-2013)' started by David P Hill, Mar 6, 2023.
  1. Mar 6, 2023 at 2:17 PM
    David P Hill
    David P Hill [OP] New Member
    I have a 2010 Toyota Tundra 4.6 and need a picture of the 4 pin Alternator Connector Wires that a bad Mechanic ( ME ) pulled off and could not put it back on. I do not know what color goes where, HELP. iphone 11 254.jpg iphone 11 292.jpg
  2. Mar 7, 2023 at 4:02 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
  3. Mar 7, 2023 at 4:07 PM
    blackdemon_tt
    I take it back. here is a diagram of the plug, that tells you how they're lined up.
    Now don't quote me on this, but see both files. It looks like top left looking at the connector
    is #1 black/yellow #2 top right is green yellow. #3 bottom left bottom is red, and #4 is black.
    Please verify with this pdf files I've attached, you can find them on the previous link I posted. Just in case, don't take responsibility for damage to your vehicle.
  4. Mar 7, 2023 at 6:09 PM
    David P Hill
    Wow That diagram looks so much better then the one i found on line, you can read the number of each wire Perfectly. Thank you so much. And if you get a picture of the real plug it would just be a good way to confrim. Cool
  5. Mar 7, 2023 at 7:28 PM
    blackdemon_tt
    I can't see the colors on my pig tail, but I can see the numbers on that connector from the picture you posted.
  6. Mar 13, 2023 at 10:07 AM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
  7. May 1, 2023 at 7:06 PM
    Shaniahicks
    Shaniahicks New Member
    Shani
    Did you figure it out? What wire goes to what I need help?
