New Clacking/Ticking - 08 5.7L
Discussion in '2nd Gen Tundras (2007-2013)' started by Geacko, May 1, 2023.
  1. May 1, 2023 at 2:24 PM
    Geacko
    Geacko [OP] New Member
    2008 Base Tundra
    Hello All,
    This is my first post here, though I've been reading for a few years.
    My 08 Tundra with a 5.7 and 153k miles has started making a new clacking/loud ticking noise.
    It's making this noise when I'm accelerating or while the truck is facing uphill, even if I'm stopped on the hill. The noise stops when I stop accelerating. So, cruising, decelerating, or I stop on a level surface. It seems to be coming from the front of the transmission, but I know that could be completely wrong.
    The noise speeds up and gets louder if I accelerate harder. I've uploaded a video with the best recording of the noise I could manage, it's significantly louder while accelerating.
    https://youtu.be/G7grXwHFkic
    I've changed the oil, corrected every rattle I could find, pushed and pulled on the exhaust pipes, made sure the covers on the CATs aren't rattling, and held onto each of the heat shields around the exhaust manifolds to make sure one of them wasn't popping.
    Has anyone encountered a problem like this?
    Thanks in advance!
  2. May 15, 2023 at 11:23 AM
    Geacko
    2008 Base Tundra
    It turns out that the noise was coming from the Starter.
    The previous owner had an aftermarket Starter installed.
    The noise was occurring because the spring that retracts the gear into the starter broke allowing the gear to bounce against the Flywheel.
    mtucker and Wynnded like this.
  3. May 15, 2023 at 12:06 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Wow, what are the chances...
    By the way, thanks for returning to let everyone know what you discovered. This kind of follow through is important.
