A different fix for AGM charging
Discussion in '2.5 Gen Tundras (2014-2021)' started by JINKSTER17, May 1, 2023.
  1. May 1, 2023 at 6:22 AM
    JINKSTER17
    JINKSTER17 [OP] New Member
    William
    2019 Super White TRD Crewmax Limited
    I’m posting this to both share my recent discovery (*of what I think I know) and to welcome any criticisms that might save my Tundra’s ECM from ignorance related damage IOW’s?
    *Disclaimer: Don’t try this at home until some professionals here weigh in on what I’ve done.
    This past weekend I turned myself inside out trying to put together a cure for the lack of circuit protection using my modified GM diode that stole the place of my alt-s 5amp fuse (to achieve a proper AGM charging rate) and try to get that protection back in place.
    The HBK items are all out of stock and I think I now know why because when I attempted to put together a spliced inline dual fuse holder rig that would accommodate both the diode and the 5amp fuse (as shown elsewhere) I discovered 2 things the hard way.
    1: There’s a difference between mini blade and micro blade fuses and
    2: There seems to be a shortage of micro blade fuse taps.
    and it was only due to happenstance that I took a gamble and tried this and as best as I can tell? It works.
    It didn’t work with the diode in the top slot but only because the charging rate dropped back down to the original 13.5-13.7’ish numbers but when I plugged the diode in the bottom slot and the 5amp fuse in the top slot I got back up to the diode’s usual 14.2-14.4amp charge rate.
    What I’m not savvy enough to confirm though is if I did indeed manage to reinstate the 5amp protection of the circuit but I’m thinking that this workaround did and for now I’m calling it a win unless someone points out otherwise and?
    I’m all ears and wide open to educated opinions, advice and suggestions.
    Thanks for reviewing.
  2. May 1, 2023 at 6:28 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    That fuse isn’t doing anything. An add a fuse tap like that creates a new circuit, so now you have a 5A power source going to nothing. But the diode is still inline.
  3. May 1, 2023 at 7:46 AM
    JINKSTER17
    William
    Honestly? I was afraid that would be the case after thinking it through a little deeper.
    It seems the paradigm here is if you put the fuse coming off the alt and upstream of the diode where it would do its job? You still have the lower 13.5-7’ish charging rate but with the diode crossing over both legs I’ve achieved nothing because while the fuse might blow the diode won’t and will allow elevated amps through the circuit.
    I’ve read where users of the HBK units weren’t getting the same charging rates as just the diode with no fuse and were getting charging rates that weren’t much higher than OEM.
    I’m beginning to think the only dice to roll is to just run the diode and the heck with the fuse.
  4. May 1, 2023 at 7:55 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    All that the 5A fuse is doing is protecting the voltage sensor circuit coming off the alternator, nothing else. My shade tree mechanic gut feel says that there's relatively low risk in leaving the fuse out of the design. Others with a better understanding of that circuit (@Jeff_5_7 or @RainMan_PNW) might be able to chime in and confirm one way or the other.
  5. May 1, 2023 at 8:00 AM
    Vizsla
    Vizsla 2 = 2.5
    Don’t run it without a fuse unless that diode is also a fuse. Was going to explain how to use the add a circuit tap but too hard. Link to one for purchase that shows how to add a diode and keep fuse with the tap.
    https://www.ebay.com/itm/266233428659
  6. May 1, 2023 at 8:24 AM
    JINKSTER17
    William
    I Followed the link but found myself looking at what appeared to be a decapped/gutted version of what I have but with no fuse or diode and the pigtail clipped off with some black gummy stuff sealing it off.
    can you clarify what’s going on there please? (And please pardon my ignorance)
  7. May 1, 2023 at 8:31 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    They’re basically using a different form factor of diode inside of an add a fuse. Power goes up the left post of the tap, into the 5A fuse, into the diode, then back into the rest of the ALT-S circuit. I might hack up one later and see if I can get something to work. Thanks @Vizsla
  8. May 1, 2023 at 8:44 AM
    Vizsla
    Vizsla 2 = 2.5
    I had a tap so mocked it up. Diode goes in the red wire however, could be in-line fuse holder for your current diode. Red wire goes to lower right terminal of empty bottom fuse position.
  9. May 1, 2023 at 9:32 AM
    JINKSTER17
    William
    Gotcha and Thanks!
    Now let me see what I can whip up here and I’ll submit a photo for approval to make sure I get it right! Thanks again! :)
    TRDFerguson likes this.
  10. May 1, 2023 at 11:31 AM
    JINKSTER17
    William
    I submit the following for approval @Vizsla
    Vizsla, RainMan_PNW and TRDFerguson like this.
  11. May 1, 2023 at 11:36 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    JINKSTER17[OP] likes this.
  12. May 1, 2023 at 11:37 AM
    RainMan_PNW
    Casey
    Clark County, WA
  13. May 1, 2023 at 11:39 AM
    RainMan_PNW
    Casey
    Clark County, WA
  14. May 1, 2023 at 11:48 AM
    RainMan_PNW
    Casey
    Clark County, WA
    certainly not compact, but that is functionally correct.
    GAknight, Vizsla and TRDFerguson like this.
  15. May 1, 2023 at 11:49 AM
    RainMan_PNW
    Casey
    Clark County, WA
    The question is, what diode to use for this. I’ve got to assume a certain size/spec of diode is needed for the correct function and voltage boost?
    Vizsla and TRDFerguson[QUOTED] like this.
  16. May 1, 2023 at 11:59 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yeah I haven’t been able to crack that yet lol. I don’t remember enough about diodes from electronics class 20+ years ago
    RainMan_PNW[QUOTED] and Vizsla like this.
  17. May 1, 2023 at 12:07 PM
    Vizsla
    Vizsla 2 = 2.5
    Have one of the EBay boosters around somewhere, will try to find it and see what diode was used.
  18. May 1, 2023 at 12:09 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    if i had to take a guess...it is a zener diode in a reverse bias that alters the signal that is monitored to simply allow alternator's voltage regulator to run at a bit of a higher voltage.
    landphil and TRDFerguson like this.
  19. May 1, 2023 at 12:15 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Indeed. Checks out with the info here
    https://youtu.be/RXJKdh1KZ0w
  20. May 1, 2023 at 12:16 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  21. May 1, 2023 at 5:15 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Your dork is showing
  22. May 1, 2023 at 5:18 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Are we now just coming to this realization?
  23. May 1, 2023 at 9:53 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Spent WAY too much time on this rabbit hole today, but looks like a basic 6A rectifier diode will do the trick.
    Might be time for me to do some solder work
    TRDFerguson and FrenchToasty like this.
  24. May 1, 2023 at 9:56 PM
    My one buddy made multiple of his own diodes using add a fuses, I’ll look for one in my pile tomorrow, hahah he eventually ended up using a pot switch, and showed me, cranking charging up to 17v or higher….. and then adjusts down as he sees necessary, I was kinda scared to be honest, you’d probably like this guy.
  25. May 1, 2023 at 10:14 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    i must ask, why do you think it is a regular diode?
  26. May 1, 2023 at 11:08 PM
    619Iron
    619Iron Desert Diva
    Amber
    San Diego
    2018 Tundra TRD-OffRaod CrewMax
    Method NV wheels 0 offset with Micky Thompson 36” tires and TRD wheel caps , fox 2.5 DSC coil overs, Camburg KINETIC UCA's, TRD front & Rear sway Bars, TRD Skid plate, Addictive Desert Stealth Fighter front Bumper, Rigid 40" curved Light Bar, 2 BAJA DESIGNS 10" AMBER driving lights, Baja Designs 40" ONX6 and S8 Amber behind the grill lights, 40" Radiance SR Pro RBGW light bar in hood Bulge, Rigid DSS pro Ditch Lights, pro Comp RGBW rock lights. Amp running boards with custom red LED lighting system, Custom TRD dual air intake with use of GTEK fab and 4" Spector intake tube and Mishimoto silicone fittings, AFE throttle body spacer, Dual Switch Pro 9100 lighting & electrical systems, Pedal commander, Warn Zeon 10K S Platinum winch, SDHQ dual battery Kit with Power steering Upgrade. TRD Pro Front Grill, with Color Matched Hood bulge, Coach Builder Shackles and coil over spacers, Coach Builder bump stops and bushings. Coach Builder tie rods, and steering bushings, IKON RST leaf springs, SDHQ traction bars, Dirty Deeds straight exhaust with Helmholtz resonator, RCV front axles, Total Chaos lower control arms, and Camburg spindles. SDHQ Arb on board twin compressor.
    Constant charging of AGM batteries by use of the diode isn’t the answer. Just buy an AGM battery charger and charge the battery every 3-4 months. Especially if you have an Odyssey Battery. They will last a lot longer this way.
    Vizsla, NewImprovedRon and hagrid like this.
  27. May 1, 2023 at 11:11 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Welp sacrificed my GM diode in the name of science!
    Diode P/N - AGP10G
  28. May 1, 2023 at 11:11 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    this certainly doesn't hurt either.
  29. May 1, 2023 at 11:26 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    looks and behaves like a regular 1 amp rectifying diode...about a .35-.38 voltage drop @12.44 vdc (my float voltage on my battery)
    1 amp diode left, AGP10G from the GM diode on the right...
  30. May 2, 2023 at 12:00 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    It should work, but you're going to need to flip the polarity of the fuse tap 180deg as the power source comes in on the terminal near the firewall of cab rather than the grille of the truck.
    -JS
