1st Gen Seat Swap
Discussion in '1st Gen Tundras (2000-2006)' started by 02CE525, Apr 24, 2022.
  1. Apr 24, 2022 at 10:19 AM
    02CE525
    02CE525 [OP] New Member
    2002 Tundra TRD Off Road
    Hi All,
    I have a 2002 SR5 with the bucket seats and console. Is it possible to swap a 05-06 limited drivers seat with the drivers seat on my 02? Or do you run into issues with the seatbelt sensor, etc.? Thanks
  2. Apr 24, 2022 at 12:57 PM
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    I can’t answer the swap question, but I bought new foam from a vendor on eBay and got katzkin leather installed and the seats are considerably more comfortable now.
    02CE525[OP] likes this.
  3. Apr 24, 2022 at 1:05 PM
    02CE525
    Do you remember the vendor?
  4. Apr 24, 2022 at 2:12 PM
    dlowry81
    dlowry81 New Member
    Doug
    If you search Tundra seat foam it was the only one that showed up.
  5. Apr 30, 2023 at 5:51 PM
    Kilgore Trout
    Kilgore Trout New Member
    Oregon
    2002 AC Toyota Tundra SR5 4.7L V8
    Airaid Cold Air Intake, Magnaflow Dual Catback Exhaust, 2017 18” 4Runner Wheels
    Anyone ever see 3rd gen tundra bucket seats go into a 1st gen tundra? Specifically looking at some 2014-2021 SR5 buckets to replace my 2002 SR5 AC bench seats. Any idea how difficult it would be to swap them in? Has anyone ever done it? Any help is appreciated, much thanks.
  6. Apr 30, 2023 at 6:09 PM
    Anything is possible, you just be need to be savvy enough to:
    • Be able to re-pin any sensors
    • Deal with any sensor compatibility issues, and/or retrofit sensors from old to new
    • Deal with bolt-hole alignment problems, since floor pans are rarely the same - safest way is to build your own seat adapters, you'd hafta been pretty safety-oblivious to drill your floor and bolt through it without substantial reinforcement.
    I haven't seen what you're looking to do. I'd recommend sticking with like-year buckets instead, personally. At least the mating-to-floor part of it should be easier, with limited (if any) drilling.
