  1. Apr 29, 2023 at 5:43 PM
    rmeyer7
    rmeyer7 New Member
    Roy
    2008 Double Cab 5.7L
    Just a very small upgrade...the center caps on my wheels were cracked when I got the truck so I ordered a gently used set on eBay and they arrived today.
    Also improved night time visibility quite a bit with LED headlights, high beams and reverse lights. Bought the tail light LEDs but they didn't arrive as soon as the reverse lights. Also have the amber ones for the rear turn signal but I'm waiting on resistors to show up for those so they don't hyperflash. Oh and I ordered a few new TPMS sensors. One went bad, and the seller had three for a reasonable price so now I'll have 2 spares in case more of them go out.
    dondino, WVI, Ohannon7 and 3 others like this.
  2. Apr 29, 2023 at 5:47 PM
    rmeyer7
    rmeyer7 New Member
    Roy
    Just a heads up for anyone who needs tires soon -- first tank of gas since buying these and I'm on pace to get at least 20 more miles between fill-ups than with the previous tires. And I always kept the tire pressure at spec with the old ones. These not only ride nice but they're saving a little fuel for me too!
    dondino likes this.
  3. Apr 29, 2023 at 6:22 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    dondino, chugs, Ohannon7 and 3 others like this.
  4. Apr 29, 2023 at 6:32 PM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    20GR8 Super likes this.
  5. Apr 29, 2023 at 6:35 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    look more smoked than my v-lands.
    Also I’m assuming you’d need a converter harness and the trim pieces if you bought those as well, unless you had an 18-20 sequoia
  6. Apr 29, 2023 at 6:54 PM
    Shanet421
    San Diego,CA
    Yes I would assume the same harness and new trim pieces painted to match. Not in my budget atm but thought I’d help empty member's pockets.
    Ohannon7 likes this.
  7. May 1, 2023 at 9:26 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Today I was all geared up for frustration and lots of broken t-30 bits to get my fake bead locks off of the rock warrior wheels. I had read numerous accounts of people using up to 18/20 plus bits to get the screws out of the wheel. Apparently the loctite Toyota used is a real bugger and just breaks the tips right off of the bits.
    So I gathered up all the torx bits I could find around my shop and grabbed the PB Blaster and went to work hoping I had enough bits to get the job done. 3 broken bits later and I had only broken 9 of the total 48 screws loose. So off to lowes I went. I bought a couple of different brands of bits and headed back home. The first pack I opened was the wiha terminator blue impact rated set. 15 minutes later I was done and still using my first bit with not a one more broken.
    I used a ratchet to break the screws loose , then my driver to get them out. Not sure if that's why I didn't break more bits or these are just rated correctly?
    Anyhow, If you're interested in this diy, I can't recommend these bits enough.
    But here's my question to this great community. As I'm waiting for my plastidip coats to cure I'm thinking this may be a few days before I can get the bead locks back on. Should I reattach the screws into the wheels, or just leave them out for a few days?
    My other question revolves around using plastidip itself. I've never used it, and was wondering if I should follow the same rattle can procedure I normally do for prep. Clean, sand, clean again and primer. The can doesn't mention any primer needing to be used in the application process.
    Medicineman, dondino, MTRock and 2 others like this.
  8. May 1, 2023 at 9:28 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Just tape. Heat gun, clean shop towels, goof off and some elbow grease will get those emblems off.
    KeepOnTruckin[QUOTED] likes this.
  9. May 2, 2023 at 4:33 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    @KeepOnTruckin
    In addition to this, I also use some fishing line and work it back and forth in a flossing movement. The technique leaves some emblem tape behind but it doesn’t scratch the paint. Then I fingernail the tape off. Then, ppl have no idea if I am a Tundra or a Prius until I tell them.
    KeepOnTruckin and Shanet421 like this.
  10. May 2, 2023 at 4:47 AM
    Shanet421
    San Diego,CA
    This is all you would need to make this happen
    :boink:
    https://www.amazon.com/Southern-Fried-Decals-Identifies-MacBook/dp/B07JNTTX6S
    Ohannon7[QUOTED] likes this.
  11. May 2, 2023 at 6:19 AM
    Tenny
    Tenny New Member
    2012 Silver Tundra
    Please let us know what you think when you get them. I was looking at AM-Autoparts branded ones and heard good things so far. These look pretty identical to those. Coupon expires May 31, so we'll have enough time to buy them if you think the quality is good.
  12. May 2, 2023 at 6:23 AM
    Tenny
    Tenny New Member
    2012 Silver Tundra
    Picked up some of the TRD Pro BBS wheels... with tires (31" unfortunately, wish they were 33's) and got them installed yesterday and took off the camper shell. Gave the truck such a better look.
    From this:
    to this:
    D4x4TRD, Medicineman, tnbndr and 16 others like this.
  13. May 2, 2023 at 6:27 AM
    Tenny
    Tenny New Member
    2012 Silver Tundra
    @KeepOnTruckin
    In addition to what the others said, you may want to grab an Eraser Wheel while you are at it. They are $10ish off Amazon and work wonders. I have one ready for when I do my badges...
    joseph_womack and KeepOnTruckin like this.
  14. May 2, 2023 at 3:24 PM
    chrisf111
    chrisf111 New Member
    I fixed some static in my rearview camera and my flickering dome lights by simply polishing the positive battery connections.
    Also, a post on here last week reminded me to check my filters (engine and cabin). Maybe I can remind someone else to do theirs with these pictures. Looking at my notes this is about 11 months /20k of miles. Total cost for filters $25 on Amazon (Denso).
  15. May 2, 2023 at 8:47 PM
    mdc1192
    mdc1192 New Member
    Matthew
    Silver 2010 Tundra TRD Off Road.
    Last week I installed anzo USA tail lights and man do I have to say I can stop looking at her everytime I walk away again IMG_0104.jpg IMG_0112.jpg IMG_0105.jpg
    D4x4TRD, TheBeast, dondino and 10 others like this.
  16. May 3, 2023 at 6:09 AM
    Musicmasterd12
    Southern Louisiana
    Looks good. Reminds me of my truck. I just ordered this to match my taillights
    dondino, Mountun Goat and 20GR8 Super like this.
  17. May 4, 2023 at 6:28 AM
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    IMG_4478.jpg Noticed it turned evil.
  18. May 4, 2023 at 7:46 AM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    Hey bud, I filled up today and did some math. 250 miles on 17.6 gallons. Comes out in the 14ish mpg range. This last tank has been mostly stop/go city driving and several trips to Lowe's to get 20+ bags of mulch so I can't really complain. Not much of an improvement over stock, but I can't explain it, it really does run different than the OEM injectors. Everything feels smoother and the power is delivered faster, but somehow softer.
    Out of curiosity, after filling up the tank and hopping on the highway I hit reset on the MPG calculator and doing 60mph it got up to 21.5 mpg sustained for about 10 miles. I don't really know if I buy that. I'll report back once I make a longer trip.
  19. May 4, 2023 at 12:38 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    In addition to this fine reminders, I would also recommend sensor cleaning at this time. For a nice smooth idle during all conditions, remove that MAF sensor and hose it down 3 to 4 times with a Quality brand MAF sensor cleaner and reinstall it. No need to disconnect battery.
    - cheers
    If you'll don't mind, perhaps we could Tag these threads things with thing like:
    #Maintenance Tips
    #Upgrade xxxx lighting, gadget
    Just a thought
    joseph_womack likes this.
  20. May 4, 2023 at 8:23 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    That’s a lot better than I get… currently 9.8 in the city and a struggle to hit 12 on the highway. Granted truck is on stock gears with 35s and a RTT and bedrack. I’d be interested in giving them a shot for the ole 4.7. Also planning on doing spark plugs once I hit 250k (never did them at 200k)
    I do think it’s gotten so bad since I got my tires balanced with balancing beads and the tire shop I went to didn’t do a great job unfortunately (steering wheel shakes at about 55-65 depending)
  21. May 4, 2023 at 8:24 PM
    joseph_womack
    Joe
    Louisiana
    Also does anyone sometimes not get alerts for this thread even when they’re signed up for email alerts?
  22. May 4, 2023 at 8:41 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Same here, maybe we should deploy chatgpt to look at the code to see where the root cause of why alerts are intermentent.
    rmeyer7, Tenny, KeepOnTruckin and 2 others like this.
  23. May 5, 2023 at 4:49 AM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    I painted my key to match my truck. I'm a beginner at automotive painting and so the results are bad, but I can always redo it when I have more patience.
    93B5BC17-C267-4C78-8330-6B810B8E4E1D.jpg DF11E015-CD21-47F8-B4A0-B8685A3DE66D.jpg 63F2F3EC-CF44-4C48-9493-D62C272BD2E3.jpg
  24. May 5, 2023 at 4:39 PM
    chrisf111
    Picked up a used covercraft custom sunscreen from facebook marketplace. It was listed for a 2015, but fit the 2007 just fine, they have the same windshield. Been wanting one of these for a while but the $100 pricetag scared me off. Snagged it for $30.
    I think at this point I have everything possible to help beat the Florida heat. 5% tint all-around, 50% on the windshield, sunscreen when parked. Can open the windows from my office with the 3W module to let the hot air out, and then remote start to get the AC pumping.
  25. May 6, 2023 at 12:48 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    Washed it… been thinking about Raptor Lining the bed but wanted to check out what lies underneath the plastic bed liner before I got my hopes up and bought stuff…. Turns out the bed rot is a little worse than I was expecting for a southern truck. Now I gotta find someone capable of cutting out the cancer and welding in new metal. Not exactly high on the priority list in life though, so I cleaned the hell out of it and threw the liner back in.
    D4x4TRD, Mountun Goat and PhotoNerd like this.
  26. May 6, 2023 at 12:56 PM
    Tundra1D6
    Liners going to make it worse.
    They sell a rust eating spray paint, get a can and treat the areas for now. Ditch the liner, it’s not doing you any favors.
  27. May 6, 2023 at 1:05 PM
    joseph_womack
    Joe
    Louisiana
    get an angle grinder with a flap disk and grind off the rust thats present now, from the pictures it looks alright, then get some rust reformer paint and coat it
  28. May 6, 2023 at 1:31 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    It looks pretty deep, bro. There’s a hole smaller than a dime near the most aft passenger bed bolt. I used some 60 grit sandpaper for about 45 seconds thinking I’d clean it up and spray over it but it wasn’t worth it.
  29. May 6, 2023 at 1:34 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    the metal in the affected areas is done for. I picked several large pieces of it off by hand and then washed several others free using the pressure washer. It needs to be cut out and replaced. There’s no paint/primer that’s helping this.
    joseph_womack and PhotoNerd like this.
  30. May 6, 2023 at 1:40 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    I'll take your headlights though if you ever decide to upgrade to the Sequoia's!
    Shanet421[QUOTED] likes this.
