New Morimoto 14-21 Tundra Taillights have FINALLY arrived!
Discussion in 'Lighting' started by Headlight Revolution, Mar 24, 2022.
  1. Apr 29, 2023 at 5:04 AM
    #241
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    You guys are maybe seeing hyperflash without headlights running because the truck runs your turn signal bulb circuit also as a running light, I wager that's the issue.
    Personally I eliminated hyperflash by running my own plug-and-play relays of sorts. I bought the harnesses from Amazon for $20, replacing the plugs with correct ones for $12 from eBay, and then screwed the resistors onto scrap aluminum plates to help keep them cool and away from other wiring. Done and done, no hyperflash, and been working perfectly for the last 15k miles / all winter. I used stainless zipties to secure the plates up front by the radiator.
    Premade harness and resistors:
    https://www.amazon.com/gp/aw/d/B07WD39L67
    eBay plug replacements:
    https://www.ebay.com/itm/402977686566
    Tundrastruck91 likes this.
  2. Apr 29, 2023 at 5:42 AM
    #242
    Rubberdown
    Rubberdown Spilling my guts here.
    Everything you’re talking about affects the daytime running lights. So I imagine the hyper flash is due to the fact that in various conditions you have extra load on the flasher circuit or not due to the use of the day time running lamps.
    Clearly you need more resistance.
  3. Apr 29, 2023 at 6:08 AM
    #243
    Get PPF installed on those headlights to prevent the lens from hazing.
    mista_g[QUOTED] likes this.
  4. Apr 29, 2023 at 9:43 AM
    #244
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Well, only had for a few days now, but not one instance of hyper flash. I will update for sure if experience that. Installed the resistors beforehand (not sure why they don't ship already set-up) and then also zip tied the 'bulk' of all the wires, once everything is connected. Then made sure to not reuse oem bolts, but the supplied new ones. Also just left the way it was shipped with the seq sequence set-up instead of regular turn signal option.
  5. Apr 29, 2023 at 9:54 AM
    #245
    Tundrastruck91
    Another reason to go with the red. Still might ppf for added protection from rocks/debris and the clear reverse led portion. Had black housing trd pro headlights PPF'd right after install.
    or just leave orig shipping film on lol ...
    edit: my bad, thought you were talking bout the clear/black tails
  6. Apr 29, 2023 at 1:02 PM
    #246
    mista_g
    mista_g New Member
    2016 Quicksand TRD Pro
    Damn. Pretty much the exact same thing I did. Guess I’ll have to do some trouble shooting.
  7. Apr 29, 2023 at 2:41 PM
    #247
    Tundrastruck91
    I also do have the iHacker harness up front ... not sure if this makes a differance ?! Did you see this V post ?
  8. Apr 29, 2023 at 3:52 PM
    #248
    mista_g
    mista_g New Member
  9. Apr 30, 2023 at 6:43 PM
    #249
    mista_g
    mista_g New Member
    Update, installed that solid state relay and it appears it disables the DRL for the halogen model Tundras and it also seems the hyperflash has gone bye bye. Like another thread states, it does remove the blinker "sound" being solid state and all. But F it, hyperflash seems to be gone so I am happy.
    Thus, anyone with halogen DRL's that wants to install XB LED heads and tails from Morimoto, you need to install the aftermarket relay to avoid hyperlfashing.
    Tundrastruck91 and MedCityMoto like this.
  10. May 5, 2023 at 1:55 PM
    #250
    mista_g
    mista_g New Member
    some pics for reference:
    Tundrastruck91, mZiggy and Y0TA PR0 like this.
  11. May 15, 2023 at 7:41 AM
    #251
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Looked out at my truck this morning and the right taillight is hanging out. It was not hit with anything. When I get home this afternoon I’ll check it out better. :annoyed:
  12. May 15, 2023 at 11:56 AM
    #252
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    I had something similar happen to me except it was the entire tail light hanging off of the truck. If yours is the same as mine, you'll have broken tabs from the tail lights where the hex screws are screwed in.
    I had to request a replacement to get it fixed.
    I suspect that with how the tabs were manufactured, once you screw into the bed's associated screw points, it creates too much stress between them causing it to eventually fail and break.
    WILLINH[QUOTED] likes this.
  13. May 15, 2023 at 1:22 PM
    #253
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    IMG_5393.jpg That’s exactly what happened.
    g6t9ed[QUOTED] likes this.
  14. May 15, 2023 at 1:57 PM
    #254
    mista_g
    mista_g New Member
    How was Morimoto with replacing the entire tail?
  15. May 15, 2023 at 2:03 PM
    #255
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I bought them from Headlight Revolution so I emailed them about it. I was on the phone waiting for 50 minutes and just couldn’t take it. Waiting to hear from them.
  16. May 15, 2023 at 2:12 PM
    #256
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Oh man that sucks Bill. Hope they make it right for you.
  17. May 15, 2023 at 2:32 PM
    #257
    g6t9ed
    I purchased mine through a third-party distributor. They requested photos similar to the ones @WILLINH provided. After that, they stated that the tail lights were on back order, so I had to wait a few months until I got my replacement. No muss, no fuss after that. I believe I even mentioned it back in November in this thread:
    mista_g[QUOTED] and WILLINH like this.
  18. May 15, 2023 at 2:54 PM
    #258
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Hopefully they do take care of it, I really like them.
  19. Jun 2, 2023 at 4:09 AM
    #259
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    They just sent a new taillight, all set NOW! Head light revolution was good to deal with.
    mista_g and Y0TA PR0[QUOTED] like this.
  20. Jun 2, 2023 at 5:16 AM
    #260
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Sweeet! Good to hear Bill! Back in business :bananadance:
  21. Jun 10, 2023 at 12:04 PM
    #261
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    so the right side was replaced 2 weeks ago by Headlight Revolution.
    The left side fell out this morning while I was out with my friend. The tabs also broke on the inside just like the right side. This is what I recovered from it falling out.
    iI had Winjet Renegade tail lights a year ago and the tabs broke on them too.
    Never a problem with the OEM I had for 3 years. Good thing I still have them. I do not tighten the crap out of them so I’m wondering is it the truck or cheap Chinese plastic.
  22. Jun 11, 2023 at 6:53 AM
    #262
    mista_g
    mista_g New Member
    Damn… how long were they mounted again?
    WILLINH likes this.
  23. Jun 11, 2023 at 7:02 AM
    #263
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I installed them December 16th
  24. Jun 11, 2023 at 7:15 AM
    #264
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Oh man that sucks. Wonder if it has happened to anyone else. I still have my oem tails. I think I will keep them as back up. Hope they fix you right Bill!
  25. Jun 11, 2023 at 7:30 AM
    #265
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Good idea to keep them, glad I did.
    Y0TA PR0[QUOTED] likes this.
  26. Jun 11, 2023 at 7:46 AM
    #266
    mista_g
    mista_g New Member
    Yea i have my rears as well, at least we know you can get a brand new one if this happens...
    Y0TA PR0 likes this.
  27. Jun 11, 2023 at 10:06 AM
    #267
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I’m calling Headlight Revolution Monday to see what they can do for me.
  28. Jun 24, 2023 at 6:34 AM
    #268
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Sucks to see the tabs fail like that. I wanted to order those lights. I live on a very rocky dirt/gravel road. Worried the vibration would just break those tabs with one drive on my road.
  29. Jun 24, 2023 at 7:29 AM
    #269
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    So Headlight Revolution sent me a new left taillight. Made sure they are just snug and not tight. Hopefully they last!!
    mista_g and Y0TA PR0 like this.
  30. Jul 1, 2023 at 3:34 PM
    #270
    raketemensch
    raketemensch New Member
    NEVADA
    I've been running the Morimoto XB Gen 2 headlights since I got the truck, and I've been running the XB tails since February without issues.
    Today I get hyperflash on passenger side out of nowhere, come home and get intermittent hyperflash on driver side. No hyperflash using hazard lights.
    Any ideas?
