Ridge Grappler -> Recon Grappler
Discussion in 'Wheels & Tires' started by georgiey22, Apr 27, 2023.
  1. Apr 27, 2023 at 7:46 PM
    georgiey22
    georgiey22 [OP] Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    After 37,000 miles and 4 years I have retired my tired Ridge Grapplers. The tires still have tred but the rubber compound was so hard and old that I could feel the discomfort when driving.
    Mounted a new set of Recons today and the it’s incredible how much more comfortable the truck is again with new tires.
  2. Apr 28, 2023 at 10:21 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    You should feel a big difference in the weight and the 10ply. Which did you get? I have 285/70/18’s Nitto’s grapplers. I seen these 2 years ago at the truck show.
  3. Apr 28, 2023 at 10:48 AM
    georgiey22
    The Recon Grappler and Ridge Grappler are the same weight (59 pounds) and both are 10 ply, I purchased the Recon Grapplers this week. The new Recons are nice and soft right now, I suspect because the rubber compound is still newer. They are quieter than my old Ridge’s and have a 55K mileage warranty. Will be interesting to see below they perform over the next 3-4 years.
    RusPro21[QUOTED] likes this.
  4. Apr 28, 2023 at 11:21 AM
    RusPro21
    Don
    Pa.
    Sounds good!! Yeah i did not look up the specs to compare thanks.
  5. May 9, 2023 at 9:00 AM
    PermaFrostTRD
    Northern NY
    What'd you pay for the 285/70r18 RECON grapplers? if you dont mind me asking. You can PM if you'd prefer
  6. May 9, 2023 at 9:15 AM
    georgiey22
    Approximately $400 per tire mounted and balanced.
    PermaFrostTRD likes this.
  7. May 9, 2023 at 9:39 AM
    PermaFrostTRD
    Northern NY
  8. Dec 23, 2024 at 1:34 PM
    737fixer
    737fixer New Member
    Now that you are about 20 months in with the Recons would it be possible for an update. Have also had the Ridges for the last several years so am very curious about the change. Also, as I get older my offroad time has decreased so the Recons seem possibly better.
  9. Dec 23, 2024 at 1:42 PM
    georgiey22
    They are nearly a perfect tire. Will only run Recons here out.
