"Low fuel" and "empty" on 32gal tank
Discussion in '3rd Gen Tundras (2022+)' started by raylo, Apr 20, 2023.
  1. Apr 20, 2023 at 1:06 PM
    raylo
    raylo [OP] not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    I had asked this question earlier about how much fuel is left when the low fuel light and warning comes on... most people said 6 gallons. On my road trip yesterday I tested mine for the first time and that's exactly what I saw. I refilled right after getting the "Low fuel" light and warning message and she took 26 gallons. At that time the computer was also saying 23 miles to empty which would mean that you would reach "empty" with ~5 gallons remaining. I am curious to know exactly how much of the 32 gallons are useable but not curious enough to really explore the limit... and we have plenty of range in any case.
  2. Apr 20, 2023 at 1:13 PM
    18" TRD Off Road Wheels
    :deadhorse:
    It is all usable. The DTE is conservative to protect the people who run it to the wire. You can run all 32 gallons out of the truck, but you risk overheating your fuel pump or stalling on inclines due to fuel starvation because the fuel can be tilted away from the fuel pickup.
    Yaboy, Hella Krusty and RCwyoming like this.
  3. Apr 20, 2023 at 1:29 PM
    raylo
    Frederick, MD
    Mattedfred[QUOTED] likes this.
  4. Apr 20, 2023 at 1:34 PM
    Skidmarcx
    Skidmarcx New Member
    Glendale, AZ
    ‘22 SR5 CM
    Let’s consider that the fuel tanks don’t fill to 100% capacity, I filled up over the weekend with 32 miles til empty and it took 28 gallons, so that seems about right to me, sure the low fuel warning was on beforehand but I’m not willing to bet on 6 gallons being in there still
  5. Apr 20, 2023 at 2:07 PM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    currently at 17 mi to empty gas getting expensive again lol
    earlwright239 and Hella Krusty like this.
  6. Apr 22, 2023 at 5:48 PM
    nodak67
    nodak67 New Member
    JR
    typical toyota reserve amount is dependent on tank size, but normally its 10% reserve or 20% depending on combined mpg of the vehicle (or around 70-100 miles range)
  7. Apr 22, 2023 at 6:17 PM
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    I got the 2023 SR with smaller tank, is it possible to buy the bigger tank and install it? Seems like plenty of room there. How would the field gauge needle work? Does it have to be calibrated or something.
    alex17117 likes this.
  8. Apr 23, 2023 at 12:02 PM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    I seen someone on Facebook who drove there truck way past the low fuel light and put 31.7 gallons in the truck. I’m uncomfortable at 1/4 tank.
  9. Apr 23, 2023 at 12:36 PM
    Breathing Borla
    AZ
    ha, now that is running on fumes, lol
    I’m with you fill it up before that
  10. Apr 23, 2023 at 3:26 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    If I buy one I promise to run it until it literally starts sputtering for fuel. Then we’ll know!
    I’ll just carry a 5 gallon Jerry can full of gas with me when I run the experiment.
    Skidmarcx and Mattedfred like this.
  11. Apr 23, 2023 at 5:16 PM
    Jeb80
    Jeb80 New Member
    I just ran mine 15 miles past empty and filled it up with 28.4 gallons. I’d say it’s a 4 gallon reserve minimum past 0
  12. Apr 24, 2023 at 5:44 AM
    nodak67
    nodak67 New Member
    JR
    lol i like to see you people do that when its -20F out up here in ND during our winters.
    my wife freaks out on matter the time of the year when it reaches 1/2 tank (more so during the winter months). trust me, you dont want to get stuck in winters up here with less than 1/2 a tank.
    it pretty much becomes a habit after 10-20 yrs of being up here to fill up at 1/2 tank.
    plus it helps to stomach the cost of a 1/2 tank vs an empty tank.
    GODZILLA, Texan-1794 and warriorlabs like this.
  13. Apr 25, 2023 at 5:30 AM
    Tilt-up Tundee
    Tilt-up Tundee New Member
    Moe
    22 Tundra SR5 Army Green
    I drove from NJ to NC on one tank of fuel. at 690 miles or so into my trip my light came on but didn't get gas for another 45 miles...730+ miles on a single tank of gas but I was averaging 21-23mpg. I filled up 32 gallons shortly after.
    On normal commutes (75mph +) I get about 450-500 depending on my foots mood. Usually only do about 27-28 gals of fuel then.
    Mattedfred likes this.
