Alignment feedback
Discussion in 'Suspension' started by biggsy, Apr 7, 2023.
  1. Apr 7, 2023 at 7:47 PM
    biggsy
    biggsy [OP] New Member
    Warren
    2010 Tundra DC Rock Warrior
    Just installed 6112s, UCA, and new OEM LCA. This is my first truck and not familiar with optimal alignment set up. I’m used to my track toy specs.
    what do you think? I wanted 0.05 toe on both sides. I think everything else looks good?
  2. Apr 19, 2023 at 10:51 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    It doesnt look too bad, the total toe i think is a little too low, from my alignments and some info on this forum i think the sweet spot for total toe is 14 even though the stock range goes up to 18. My alignment guy agreed with the 14 number as being optimal, especially with larger or heavier tires.
    biggsy[OP] likes this.
  3. Apr 24, 2023 at 5:30 PM
    biggsy
    Warren
    Thank you very much for the reply. Unfortunately it doesn’t matter because the inner tie rod and wheel bearing went bad. So I’m doing another alignment. I’ll keep in mind your numbers when I take the truck in
    MadMaxCanon[QUOTED] likes this.
