D vs. S6
Discussion in 'General Tundra Discussion' started by Bakershack, Apr 20, 2023.
  1. Apr 20, 2023 at 9:00 AM
    Bakershack
    Bakershack [OP] Critical of Noncritical Thinkers
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    This may have been discussed somewhere before, but what is the difference between driving in D vs. S6?
  2. Apr 20, 2023 at 9:14 AM
    Vizsla
    Vizsla pretend2send
    AI-SHIFT operates in D, does not in S mode.
  3. Apr 20, 2023 at 12:48 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    OK, AI-SHIFT is a new one for me. What's that? And how does it benefit me?
  4. Apr 20, 2023 at 12:52 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    All you would ever wanna know, but in essence, the transmission adjusts how the truck drives in response to the driver's actions.
  5. Apr 20, 2023 at 11:05 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I don’t think ive ever used S mode without a trailer or big load.
    holy smokes the truck drives SO much better in S 6. The trans is definitely not thinking, but shifts much cleaner and at the correct rpms
    Bakershack[OP] likes this.
  6. Apr 20, 2023 at 11:57 PM
    blenton
    blenton New Member
    This.
    I sometimes get a little shudder on the 1-2 shift that completely disappears in S Mode (it’s the driveline going slack then re-engaging between gears, not a transmission issue; the AI prolongs and softens the 1-2 shift giving a small bump feeling on occasion). I drive like an old man in 1st gear then usually give a little (or a lot) more gas in second so the AI shifting hates me sometimes.
    It can sometimes net you a little better mileage to stay in D. And it saves you from having to click from S3 to S6 every time you put it in gear.
  7. Apr 22, 2023 at 12:13 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Been driving mine is S mode since i got with 150 miles on. At 70,000+ now with no issues. Run it
  8. Apr 23, 2023 at 2:39 PM
    TRDpro4x4
    TRDpro4x4 New Member
    2016 TRD DC 5.7V8
    I wonder if NAVI AI shift is in all or certain model Tundras, dont really see if it would make driving enjoyable. One thing i find annoying is, when i leave in cruise with some light trailer load, it sometimes keeps downshifting unnecessarily & stays longer in lower gears before upshifting, whereas same cruise drive in S mode goes really with smooth shifts.
    Hbjeff likes this.
