trans fluid level
Discussion in '1st Gen Tundras (2000-2006)' started by derryt98, Apr 20, 2023.
  1. Apr 20, 2023 at 10:38 AM
    derryt98
    derryt98 [OP] New Member
    Derry
    2002 Tundra SR5
    how much trans fluid should i add from here? this is the reading i’ve got after a drain and fill
  2. Apr 20, 2023 at 11:03 AM
    Chuy!
    Chuy! New Member
    Lakeside, CA
    2007 Tacoma 4X4
    If you took the reading on cold engine, it is good, maybe a tad overfilled. If the engine is at running temperature, you need to add ATF to the HOT notches. If not at running temperature, do so and see if the reading is at the HOT notches, adjust accordingly.
  3. Apr 20, 2023 at 11:52 AM
    derryt98
    Derry
    2002 Tundra SR5
    sorry! this is what it’s at when hot. i’ve checked multiple times after driving and this is where it it’s at. how much should I add from here?
  4. Apr 20, 2023 at 10:55 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Add a 1/4 qt. at a time, until it's between the two upper marks.
  5. Apr 21, 2023 at 5:43 AM
    This ^^
    But I'd add a point to it, be sure to fire up the engine and shift through all the gears a few times to get fluid moving before checking again.
    Last thing I want to see is OP back on here 2 months from now with, "I've added 2qt of fluid and it's still at the same level!" :rofl:
  6. Apr 21, 2023 at 11:38 PM
    wandering_boy
    wandering_boy Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    Lucky guy. You actually get a dipstick. My trans is fully sealed. Mins the drain plug and the annoying check plug which is always over full when the trucks off.
    shifty` likes this.
