In Bed AC Power won't stay on while driving?
Discussion in '3rd Gen Tundras (2022+)' started by havage, Jul 16, 2022.
  1. Jul 16, 2022 at 6:32 PM
    havage
    havage [OP] New Member
    Leo
    2022 Tundra TRD Off-Road
    Hey everyone, new to the forum and new to a 2022 TRD Off-Road Limited Tundra.
    I have the 400W in bed power option and I plugged in a Goal Zero (1500X) and then a Dometic Cooler. I want the 400W outlet to charge the Goal Zero WHILE I am driving around and then when I'm parked I want it to use the Goal Zero to run the cooler.
    Seems logical and easy.
    Problem 1: The outlet won't stay on when I start driving. It turns on when I put I turn it on in park but the moment I shift to drive it turns off. Anyone know what gives??? Owner's manual says it should work w/ 100W outlet when driving. The power adapter is 120W from Goal Zero. Is this tripping a breaker or something?
    ■ Maximum available capacity of the power outlet
    While the vehicle is being driven
    The maximum capacity of the power outlet is always 120 V AC/100 W.
    Problem 2: Apparently the outlet can run 100W and 400W? I don't know if that's true but I can't figure out how to tell if I'm running in 100W mode or 400W mode. Any suggestions or guidance are appreciated.
    Thank you
    matgor likes this.
  2. Jul 17, 2022 at 8:09 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    My 100% hypothetical guess is that it’s tripping up and pulling too much voltage and shutting off- might need to run a second battery or an Anderson style plug in charger for it
  3. Jul 17, 2022 at 8:16 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Your GZ is rated 120W but the outlet is only 100W MAX while driving. Probably a safety feature.
    NewImprovedRon and GODZILLA like this.
  4. Jul 17, 2022 at 9:24 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I wonder if it’s the same 100W / 400W inverter the Tacomas have been using for years? Guys on Tacomaworld figured out a way mod them to run 400W driving…
    GODZILLA likes this.
  5. Jul 17, 2022 at 9:40 AM
    Breathing Borla
    Northern Illinois
    Should be a min of 1500 like the sienna has
    interested in the answer, why isn’t it 400 all the time
    DexterL likes this.
  6. Apr 17, 2023 at 8:15 PM
    alpinefd100
    alpinefd100 New Member
    any more info on this? thanks
  7. Apr 20, 2023 at 7:50 PM
    alpinefd100
    just to confirm this, this 400watt/100watt, is this dc or ac? because 100watt ac is like 0.83amp at 120v, it can't power anything
  8. Apr 21, 2023 at 5:26 AM
    vtown76
    vtown76 New Member
    It’s AC, and yes 100 watts is pretty much useless. Hell 400 watts is pretty useless. I don’t know why toyota makes it drop when driving, but they’ve done the same thing since the 2nd gen Tacoma dropped in 2005. Hence the mod mentioned above.
  9. Apr 21, 2023 at 10:55 AM
    wayne73
    wayne73 New Member
    Wayne
    Minnesota
    2022 limited crewmax trd offroad
    Yep had the same thing on my old 2009 Tacoma, 400/100 watts are both worthless, Not enough to run even a small shop vac. I wish I knew what Toyota was "targeting" this to really be used for ?
    One time I thought I could charge some power tools on a craftsman battery charger while driving to my destination, the Tacoma completely ruined the battery charge.
    On the Tacoma forums, i remember seeing guys used to run Xmas lights in there bed for the holidays. At least someone found some use for the plug.
    Piney likes this.
  10. Apr 21, 2023 at 12:33 PM
    flatlandclimber
    flatlandclimber New Member
    2022 DC
    My old Tacoma had the 3000 watt anytime mod.
    Not cheap, but very effective.
    Piney likes this.
  11. Apr 21, 2023 at 12:58 PM
    docfnky
    docfnky New Member
    Sienna is only capable of 1500 output because the inverter is powered by the hybrid battery.
  12. Apr 21, 2023 at 1:10 PM
    Breathing Borla
    Northern Illinois
    I know, they should have the same or more on the hybrid tundra to add to that package
    spigatelli likes this.
  13. Apr 21, 2023 at 1:21 PM
    spigatelli
    spigatelli New Member
    DFW, Texas
    2023 Limited Hybrid CrewMax 6.5 in Army Green
    Yeah, Fords are out here powering houses with their Hybrid and mine can't power a strong fan. Lame.
  14. Apr 21, 2023 at 1:29 PM
    Breathing Borla
    Northern Illinois
    our new 2023 Sienna AWD 25th Anniversary edition we just got has already cooked bacon wrapped sausages in a crock pot on the way to a party, HA
    now that is important.
    but ya the inverter in our Sienna is really nice, we have a vacuum in there , pump, you can run tons of shit off it and it has two ports, sure nice, and thats only 1500 watts, ford has 7.2 kW
