2nd Gen Oil Change: Chilton
Discussion in '2nd Gen Tundras (2007-2013)' started by Nor7, Jan 28, 2016.
  1. Jan 28, 2016 at 7:41 AM
    Nor7
    Nor7 [OP] Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Replacement
    Click to Enlarge
    Remove the 3 screws and 5 bolts.
    • Unhook the engine under cover from the vehicle body as shown in the illustration.
    Click to Enlarge
    Connect a hose with an inside diameter of 15 mm (0.591 in.) to the pipe.
    • [​IMG]
      Click to Enlarge
      Install the pipe to the oil filter cap.
      NOTE
      HINT:
      Use a container to catch the draining oil.
      NOTE
      If the O-ring is removed with the drain plug, install the O-ring together with the pipe.
    • [​IMG]
      Click to Enlarge
      Check that oil is drained from the oil filter. Then disconnect the pipe and remove the O-ring, as shown in the illustration.
    • [​IMG]
      Click to Enlarge
      Using SST, remove the oil filter cap.
      SST
      09228-06501
      NOTE
      Do not remove the oil filter bracket clip.
    • [​IMG]
      Click to Enlarge
      Remove the oil filter element and O-ring from the oil filter cap.
      NOTE
      Be sure to remove the O-ring for the cap by hand, without using any tools, to prevent damage to the cap's O-ring groove.
    Click to Enlarge
    Clean the inside of the oil filter cap, its threads and its O-ring groove.
    • Apply a small amount of engine oil to a new O-ring and install it to the oil filter cap.
    • Set a new oil filter element to the oil filter cap.
    • Remove any dirt or foreign matter from the installation surface of the engine.
    • Apply a small amount of engine oil to the O-ring again and temporarily install the oil filter cap.
    • [​IMG]
      Click to Enlarge
      Using SST, tighten the oil filter cap.
      SST
      09228-06501
      Torque
      Nm kgf.cm ft. lbs
      25
      255
      18
      NOTE
      • When tightening the oil filter cap, do not remove the oil filter bracket clip.
      • Make sure that the oil filter is installed securely as shown in the illustration.
      • Be careful that the O-ring does not get caught between any surrounding parts.
    • [​IMG]
      Click to Enlarge
      Apply a small amount of engine oil to a new drain plug O-ring, and install it to the oil filter cap.
      NOTE
      Before installing the O-ring, remove any dirt or foreign matter from the installation surface of the oil filter cap.
    • Install the oil filter drain plug.
      Torque
      Nm kgf.cm ft. lbs
      13
      127
      9
      NOTE
    (Click here for more information)
    Click to Enlarge
    Hook the engine under cover to the vehicle body as shown in the illustration.
    • Install the 3 screws and 5 bolts.
      Torque
      for bolt
      Nm
      kgf.cm ft. lbs
      29
      296
      21
      for screw
      Nm
      kgf.cm inch lbs.
      3.0
      31
      27
    Portions of materials contained herein have been reprinted under license from Toyota Motor Sales, U.S.A., Inc., License Agreement TMS1005. See details here.
    Ancient1 and jfrd30 like this.
  2. Jan 29, 2016 at 9:24 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Pulling off the oil filter cover makes a mess. No way around it.
    jfrd30 likes this.
  3. Jan 29, 2016 at 10:54 AM
    Nor7
    I was able to get it off with relatively little mess, I drained the pan first and drained the cap through the center after removing the filter plug.
  4. Apr 20, 2023 at 7:10 AM
    FilchedToyoResto
    FilchedToyoResto New Member
    Pictures are gone?
  5. Apr 20, 2023 at 8:04 PM
    csuviper
    Broomfield, CO
    Unfortunately looks like Nor7 hasn’t been on since Aug 2018.
