Total Brake Failure (and other rusty lines)
Discussion in '1st Gen Tundras (2000-2006)' started by w666, Apr 8, 2023.
  1. Apr 8, 2023 at 10:13 AM
    w666
    w666 [OP] D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  2. Apr 8, 2023 at 10:24 AM
    BanksyB31
    BanksyB31 New Member
    Brent
    06SR5AC V8 4WD LSD
    Wheels.
    looks like the line rusted through maybe?
    Any pics of the line cleaned off so we can get a better look at the hole/damage? Def be checking mine out soon
  3. Apr 8, 2023 at 10:27 AM
    w666
    Maryland
    I'll post the failed line after I yank it out. I'm curious too!
  4. Apr 8, 2023 at 10:27 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    From the few videos I've seen on older vehicles there is a separate proportioning valve that controls front to back separation. Not sure how the tundra is setup.
    w666[QUOTED][OP] likes this.
  5. Apr 8, 2023 at 10:34 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Buddy our trucks will GO forever and you expect them to stop forever, too? Don’t be greedy. :rofl:
  6. Apr 8, 2023 at 12:16 PM
    w666
    Maryland
    OK, this is the line that failed (although the other line was not far behind). It runs from the ABS pump to the 90 degree connector.
    I think my summer project will be to inspect every inch of brake line, and replace anything that's even remotely sketchy!
    bmf4069, thearborbarber and BubbaW like this.
  7. Apr 9, 2023 at 8:49 AM
    w666
    Maryland
  8. Apr 9, 2023 at 9:22 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    Is it possible that you've only had half a working system for a while now? The front brakes do (I believe) 70% of the braking. You might not have noticed when the rears failed.
    w666[OP] and N84434 like this.
  9. Apr 9, 2023 at 11:59 AM
    w666
    Maryland
    Good idea...but, no. The rears have been fine, in fact I used the ebrake to get home. There is still fluid at the rears, and no sign of leakage. A leak in the front system (even assuming a total fluid loss) should not affect the the rear system, which is (supposed to be) physically separated at the master cylinder. All I can assume is that the MC is bad too. I'm hoping someone pops up who has had a similar experience.
    It could also be the LSPV, frozen in such a way that 100% of the fluid is diverted to the fronts, but I'm not yet convinced.
    I just found another thread seemingly of my exact problem:
    https://www.tundras.com/threads/my-brakes-went-out-trying-to-understand-what-exactly-happened.88729/
  10. Apr 9, 2023 at 12:05 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    If that one let go, the ones for the back lines need to be checked very closely. They usually go first or are right behind that one
  11. Apr 9, 2023 at 12:11 PM
    Well, there’s your problem. The lines aren’t completely coated in vinyl exposing them to corrosion. Strange that mine are yet I don’t have ABS.
  12. Apr 12, 2023 at 7:24 AM
    w666
    Maryland
    Yay! I have lots of shiny new brake parts now. The problem should be solved (for now), at least for this corner. Hopefully I can check/replace the other corners at a more leisurely pace...
  13. Apr 12, 2023 at 4:08 PM
    How’s the fuel line in that area where it joins two sections over the inner left fender? That’s where mine rotted through.
  14. Apr 12, 2023 at 8:39 PM
    Aerindel
    Aerindel New Member
    Montana
    bmf4069 likes this.
  15. Apr 13, 2023 at 4:57 PM
    w666
    Maryland
    It's kinda sketchy...I may not be able to grab a pic for a few days. Were you able to buy parts, or did you have to improvise?
  16. Apr 13, 2023 at 10:07 PM
    The hose going to the fuel filter was replaced but the shop refused to bypass the fitting on the front one to the fuel rail and just cleaned it up. I think it's a ticking time bomb IMO and needs to be replaced but it'll require a used part since it's discontinued.
    If I knew they were gonna pull that bait and switch shit I would've never brought it too them and done it myself. However since they disconnected the fuel filter stating it was leaking everywhere (not true) I didn't want a truck back that was already leaking in a 2nd location everywhere.
  17. Apr 14, 2023 at 12:24 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Got a pic of it?
    I'll keep an eye out for a good one at the yard.
  18. Apr 14, 2023 at 4:07 AM
    It’s the hose in front connecting to the new line over the fender. The other side goes to the back of the fuel rail on the drivers side.
    assassin10000[QUOTED] likes this.
  19. Apr 14, 2023 at 4:54 AM
    That's what I was thinking. When you push the pedal, the fluid finds the weak spot and exits, effectively not putting pressure on the entire system.
    Aerindel[QUOTED] likes this.
  20. Apr 19, 2023 at 6:54 AM
    w666
    Maryland
    @Jack McCarthy Mine is rusty and crusty, but does not appear to be at imminent risk of failure. I'll try to buy the parts if I can find them. There are two parts, the line that runs from the fuel rail to the connector by the frame, and its mate which runs to the fuel filter. For my truck, the former is 238010F010, and the latter is 77251-xxxxx (still trying to identify it). I believe I have found stock for 238010F010.
  21. Apr 19, 2023 at 7:32 AM
    w666
    Maryland
    Jack McCarthy likes this.
  22. Apr 19, 2023 at 7:43 AM
    Where's it routed? MD to Bangladesh and back to America? lol
    Must be the white glove service where upon delivering it, they give you the finger in a white glove.
    bmf4069 likes this.
  23. Apr 19, 2023 at 7:45 AM
    Oh, wait a minute @w666, that's specified for freight delivery. Must come in on it's own pallet. lol
    Do they give you any other option for shipping?
  24. Apr 19, 2023 at 8:36 AM
    w666
    Maryland
    McGeorge claims to be able to furnish both, but they won't ship the 77251-0C012 because it is too long...local pickup only. I'm checking with my local dealers now.
    I spent $100 on brake lines for the assurance that I'll be able stop any time I want...I'll gladly spend ~ $200 so that I don't burst into flames!
  25. Apr 19, 2023 at 11:16 AM
    w666
    Maryland
    @Jack McCarthy FYI I sourced the 77251-0C012 at my local dealer. $79.33 MSRP, but no shipping. The 23801-0F010 is on the way from McGeorge.
  26. Apr 19, 2023 at 11:27 AM
    Yeah, I see the 23801-0F010 listed at my local dealer. I thought I had a different part number originally though that showed discontinued. I show the following in the parts diagram referencing item 23801P which are:
    1. 23801-0F010
    2. 23801-50020
    3. 23801-50021
    All 3 state “pipe-sub assembly fuel, no. 1” for a description. I’m confused.
  27. Apr 19, 2023 at 11:37 AM
    Okay, I referenced the thread “under hood fuel leak” I originally commented within about the fuel hose and dealer told me part # 23801-50050 is all they have listed.
    Now I’m totally confused. :confused:
  28. Apr 19, 2023 at 11:56 AM
    w666
    Maryland
    @Jack McCarthy It may be different for 2002, but I don't know why it should be. The part that you had fabricated inelegantly is 77251-0C012 (Tube, Fuel Main), which fits Production Date: 08/2002-08/2004, Fitting Vehicle Options: UCK3#, 4#.
    The part you need (which runs front the fuel rail to the rusty connection by the frame) is 23801-0F010 (should fit your 2002 as well). ~ $50 + S&H @ McGeorge Toyota. (There are probably some washers for the banjo connection to the fuel rail, but I may have some laying around.) I have a new OEM fuel filter which I've never installed because @Shifty told me I didn't need to .~ (.~ is the "snark mark"). When I get around to opening the fuel line (hopefully before it opens itself!) I'll install it as well.
  29. Apr 19, 2023 at 12:04 PM
    Yeah, show off a pic when you get it. My truck was built 2/2002 but that’s probably irrelevant for the part I need.
    FYI…if the fuel line to the filter is rusted at the filter connection, you may need a new rail breaking the old one free.
