What are these parts called?
Discussion in '1st Gen Tundras (2000-2006)' started by CCE525, Apr 18, 2023.
  1. Apr 18, 2023 at 6:19 AM
    CCE525
    CCE525 [OP] New Member
    Chad
    2000 SR5
    None
    I’ve been searching parts catalogs for 2 days.
    Does anyone know the name or part number for these little rubber bumpers?
    side note…
    Anyone with a decent 6’ bed for a first gen within a few hundred miles on Cincinnati?
  2. Apr 18, 2023 at 6:25 AM
    Frame Nipples
    jerryallday and tacoguybill like this.
  3. Apr 18, 2023 at 6:29 AM
    Rubber nubbins
    tacoguybill likes this.
  4. Apr 18, 2023 at 7:01 AM
    CCE525
    Chad
    2000 SR5
    None
    While “nipples” and “nubbins” certainly produced interesting search results it doesn’t appear that’s the Toyota name…
    bmf4069, FirstGenVol and JasonC. like this.
  5. Apr 18, 2023 at 8:58 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    You have to Google "Toyota Frame Nipples." Otherwise, you get non-Toyota Nipples.
    bmf4069 and Rodtheviking like this.
  6. Apr 18, 2023 at 9:02 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    My 2002 access cab did not have those when I pulled the bed.
    I would try "locators." Or call a dealership with a parts counter, and provide them pictures of your nipples
    bmf4069 and artsr2002 like this.
  7. Apr 18, 2023 at 9:04 AM
    artsr2002
    'Yonder
    Also, tell you need a water pump gasket for a Tacoma. Tell them the last place gave you the wrong one. Ask them to describe the shape of it to you to ensure you are given the correct one. LOL.
    Tundra2, KNABORES, bmf4069 and 3 others like this.
  8. Apr 18, 2023 at 9:15 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    My guess is that they were used for production to help locate the bed during assembly so not a replaceable part.
    FrenchToasty, shifty` and Tundra2 like this.
  9. Apr 18, 2023 at 2:56 PM
    NetGnome
    NetGnome New Member
    NJ
    Removed lots of rust.
    Body Mount Cushion
  10. Apr 18, 2023 at 3:03 PM
    That's the name of the actual body mounts used for the cab.
    I dug for about 10 mins earlier, checking every body, frame and subframe assembly in the parts system. I can't find the damn things either. I suspect Rod is correct.
