2020 TRD Pro (Lifted via Eibach/Coachbuilder/Dirt King)
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Luke_Skywalker, Apr 16, 2023.
  1. Apr 16, 2023 at 8:28 PM
    Luke_Skywalker
    Luke_Skywalker [OP] New Member
    Luke
    2020 Tundra TRD Pro
    Eibach TRD Pro Front Springs, Dirt King UCA's Coachbuilder +3 shackle (poly bushings)/carrier bearing drop, steering upgrade, bumper shims, White Knuckle Sliders, Leitner Designs, Baja Designs, Switch Pro, Victron Solar, BORA 1.25", BFG KO2s, Wheelers Superbumps, VLED interior lights, 12" Sub, Window Tint.
    Hello everyone,
    A few weeks ago I was able to drop my truck off at the good folks down at Baja HQ to upgrade my 2020 Trd Pro. I am very happy with the results. From the way the truck handles both on road and off road, to the looks.
    Installed Parts: Eibach TRD Pro Tundra 19-21 Front Lift Springs, Coachbuilder +3 Shackles with poly bushings, Coachbuilder carrier bearing drop kit, Coachbuilder Steering upgrade kit, Bora 1.25" spacers, Dirt King UCA, Wheelers Superbumps (front and rear).
    Suspension: These springs are a direct replacement for your Fox coilover springs. Eibach claims a 1.8" increase in height. My truck netted around 1.5" (measured center hub to fender) in the front, and about 1.5" in the rear (measured hub to center). I think the rear is slightly higher but barely maybe .1-.2 at most. The result is a very leveled looking truck. The springs are a taller and stiffer (but by like maybe 20-30lbs). Eibach told me the springs are 620lbs, and as far as ive seen the pro has 600, but maybe i'm wrong on this. I feel like the vehicle has maybe 15% less break dive, and corners just a little bit flatter than before (this is with sway bar on, which I have removed since). The rear feels less bouncy and much smoother over bumps. I'm confident that if i pushed the bumper forward with the Coachbuilder shims I have, I could clear a 35" tire with the right offset.
    Offroad: I wanted to make sure I wrote this up after I went offroading. I gotta say the way it handles offroad is definitely better. I still get that smooth feeling the Fox Pro stuff gives you offroad, but just a little more planted. We ran some washes at 45-50 mph and it felt great. No weird popping noises or anything to suggest suspension geometry was off or anything like that.
    Here's some photos!
    AZEric, BillyB, woofhauler and 10 others like this.
  2. Apr 16, 2023 at 8:30 PM
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    RegGex, ryanwgregg and Tripleconpanna like this.
  3. Apr 17, 2023 at 3:53 PM
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    In one of these photos you can see bumpstop spacers that come with the Coachbuilder kit. Those DONT work with this kit, so dont use them unless you're running the coachbuilder coilover shim. I removed them. They limited the articulation like crazy and were coming into contact way too soon. Just FYI.
    BillyB and bulldog93 like this.
  4. Apr 19, 2023 at 9:03 PM
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    Threw mine on finally on Monday and took it out today and it felt great. Felt the same as you described, a little less body roll and perfect off road. Yielded about the same height as the Westcott, but definitely happier with the overall ride
    3A92939A-DFD1-4D79-A5AB-CEF47B09E371.jpg 436C4A51-A20B-4BFF-A3D2-7FA840904CEF.jpg
    BillyB, reywcms and bulldog93 like this.
  5. Apr 20, 2023 at 8:12 AM
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
  6. May 10, 2023 at 4:37 PM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    Did you put on the long steering upgrade kit or regular?
  7. May 11, 2023 at 2:40 PM
    a_double
    a_double New Member
    THe lift looks perfect. Any issues with the +3 shackles and stock leaf springs?
  8. May 20, 2023 at 7:35 PM
    ultraman29
    ultraman29 New Member
    Katy Tx
    2021 White TRD sports
    Do I need to consider the 2” level that the pro provides plus the 1.8” lift for a aftermarket UCA? Been looking for this for a while.
  9. May 23, 2023 at 7:37 PM
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    nope.
  10. Jun 21, 2023 at 10:41 AM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
    Looks great! And yes you can fit 35's without a BMC. I have the coachbuilder bumer shims and fit them fine. My offset is +25 on the methods. Nice truck!
  11. Jul 29, 2023 at 1:37 PM
    Badge618
    Badge618 New Member
    Lassen County, Ca
    2019 TRD Pro Voodoo Blue
    Did you have to go to aftermarket UCA's?
  12. Jul 29, 2023 at 11:28 PM
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    Yes. Any lift over 2” should have UCA’s regardless of what the internet experts keep saying
    BillyB likes this.
  13. Aug 7, 2023 at 9:07 PM
    Badge618
    Badge618 New Member
    Lassen County, Ca
    Gotcha. Just wondering with the new coils as it seems the same height as the Westcott and they said new UCA's weren't necessary. Have the Bilstein/Dirt King ones ordered anyhow.
  14. Dec 11, 2023 at 4:30 PM
    COTundra23
    COTundra23 New Member
    have any hub to fender measurements by chance?
    looks great!
  15. Dec 11, 2023 at 6:16 PM
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    @COTundra23 i don’t, but i can get them for you if you want. Let me know.
    COTundra23 likes this.
  16. Dec 11, 2023 at 6:33 PM
    COTundra23
    That would be awesome! Thanks! Need to know if it’ll still fit in the garage
  17. Jan 10, 2024 at 10:17 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Have you had any issues with topping out/ hard rebounding issues on the front shocks?
    AZEric likes this.
  18. Apr 24, 2024 at 3:48 PM
    COTundra23
    Following up on this! Any measurements are great. Thanks
  19. Jun 13, 2025 at 10:08 AM
    Austintaco
    Austintaco New Member
    Patrick
    Austin, TX
    2021 Lunar Rock TRD Pro, 2003 Tacoma DC TRD, 1984 SR5 4runner with 1uz, 85 Supra
    285/75/18 Duratraks, 5.29’s and Powertrax in the rear, Eibach Pro lift coils, JBA UCAs, RAS and CB Plus 3, AT transmission cooler, RAGO dash plate, Boost Tow mirrors
    Reviving an old thread @Luke_Skywalker , did you end up running wheel spacers after the additional lift? What size tires are you running?
