Switching to 5w30?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Klowry97, Mar 23, 2020.
  1. Apr 16, 2023 at 6:07 PM
    #451
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Ive run 5w-30 on many change’s myself. I do wonder though, is 5w-30 listed as acceptable in other countries due to oil availability? Like, is high quality synthetic 0w-20 just less common to find
    Sierradevil, Silver17 and Pbed85 like this.
  2. Apr 16, 2023 at 6:30 PM
    #452
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Or could the flip side be true, that the only reason 0w20 is so readily available and pervasive here and not the rest of the world is due to an overbearing government agency with an agenda that is not found in other countries?
  3. Apr 17, 2023 at 3:21 AM
    #453
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I'm curious where else in the rest of the world, outside of the US, is the Tundra (or the same 5.7 gas engine) a common vehicle.
    joey2018 likes this.
  4. Apr 17, 2023 at 4:03 AM
    #454
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    If I could market a system to accurately monitor engine oil temp after the oil cooler I'd be hip deep in bald beaver pelts.
    Before and after the cooler would be even betterer.
  5. Apr 17, 2023 at 4:12 AM
    #455
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
  6. Apr 17, 2023 at 4:17 AM
    #456
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    has someone posted the stats on which oils make an engine fail?
    cuz, that info would be informative. facts/feelings
    see...engines don't have oil related failures when there is a proper amount of oil in the pan, any oil.
  7. Apr 17, 2023 at 4:36 AM
    #457
    sd172
    sd172 New Member
    South Dakota
    Mostly the extended drain intervals (leading to the blockage of oil control rings) and some poorly designed synthetic formulations that can precipitate its additive package in areas with high temperatures (piston rings, turbochargers) can cause harm typically after 60k miles. Otherwise, nobody cares.
    nobodyintexas[QUOTED] likes this.
  8. Apr 17, 2023 at 4:38 AM
    #458
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    You want stats and facts?!
    Like, actual facts? In an oil thread??!!
  9. Apr 17, 2023 at 4:40 AM
    #459
    nobodyintexas
    nobodyintexas What?
    South of Houston
    exactly.
    any God fearing man changes his oil & FILTER every 5k.
    at 5k, the oil type matter not...the oil level however, does.
  10. Apr 17, 2023 at 4:47 AM
    #460
    Silver17
    Eastern PA
    When times are tough I run vegetable oil up to 5,000. At 5,001 though catastrophic failure occurs .
    Mike59, Cpl_Punishment and Pbed85 like this.
  11. Apr 17, 2023 at 6:01 AM
    #461
    nobodyintexas
    nobodyintexas What?
    South of Houston
    We'll need more data on this one.
    canola or safflower?
    Mike59 likes this.
  12. Apr 17, 2023 at 6:10 AM
    #462
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    I had a truck medium/psychic do a session with my truck and they told me the truck feels better when I use canola with a few drops of sage and lavender oils.
    Cpl_Punishment, Hbjeff and hagrid like this.
  13. Apr 17, 2023 at 6:17 AM
    #463
    Silver17
    Eastern PA
    Well, like I said I do this when times are tough. That in mind, I use the original Crisco because when I’m done frying my funnel cakes (since I’m from PA) I pour it into jugs until I have enough for an oil change. It’s all about mastering how often I need to make funnel cakes in order to have enough oil for a change before the 5,000 miles. After 5,000 catastrophic engine failure occurs, but if I make too many funnel cakes to increase my oil change supply that could result in congestive heart failure. It’s a real balancing act.
  14. Apr 17, 2023 at 6:19 AM
    #464
    nobodyintexas
    nobodyintexas What?
    South of Houston
    awarding you 1000 internet credits for incorporating funnel cakes.
    kudos, my man.
  15. Apr 17, 2023 at 6:57 AM
    #465
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The real test would be to use 0w-20 in a “loose tolerance” motor that asks for 5w-30.
  16. Apr 17, 2023 at 8:39 AM
    #466
    Hugemoose
    Hugemoose New Member
    Philly
    2016 Tundra Crewmax
    Not enough....
    I ran 10w-30 once.....
    Should I sell my truck and get a new one now? Dammit.
  17. Apr 17, 2023 at 8:59 AM
    #467
    sd172
    sd172 New Member
    South Dakota
    Now all of your tolerances and oil passages got used to a thicker oil..
    You can’t go back.
  18. Apr 17, 2023 at 10:41 AM
    #468
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    It means it’s still running
  19. Apr 17, 2023 at 10:43 AM
    #469
    JLS in WA
    Kirkland signature canola…
    hagrid likes this.
  20. Jul 21, 2023 at 5:28 PM
    #470
    sd172
    sd172 New Member
    South Dakota
    Doing an extended rinse with this for one week or approximately 250 miles. Might leave it in for longer because the engine seems to run very quiet.
  21. Jul 21, 2023 at 5:35 PM
    #471
    Burdturger
    Burdturger New Member
    Thats funny, didnt know they put tundra motors in tractors. Who knew?:cool:
    Leo's first and Cpl_Punishment like this.
  22. Jul 21, 2023 at 5:36 PM
    #472
    EmergencyMaximum
    What woodoo is this?!!:boink:
  23. Jul 21, 2023 at 5:45 PM
    #473
    sd172
    sd172 New Member
    South Dakota
  24. Jul 22, 2023 at 5:09 PM
    #474
    Abrown3912
    Abrown3912 New Member
    2021 Crewmax
    I switched to 5W-20 at 50k miles. I live in Florida and my truck rarely sees temperatures below freezing.
  25. Jul 22, 2023 at 8:38 PM
    #475
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Interesting how if it was measured under Euro III the manual says the 3UR needs a minimum viscosity of 5w-30, but if you get one after Euro IV certification then suddenly the 0w-20 is at the top of the chart.
    It can't be affecting mileage much. This was with 5w-30 last week. Small gas tank, slight anxiety, cruised at 70 most of it, not going downhill the whole way as the beginning and end of the tank were at the same station. Hand calc was 19.4. Anecdotal but I've only averaged 17 mpg or better seven times and four of those ran 5w-30.
    Gene_in_FL likes this.
  26. Jul 23, 2023 at 8:04 AM
    #476
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    use synthetic oil,
  27. Jul 23, 2023 at 8:21 AM
    #477
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Every 17k mi, when I change my oil, I drain the oil, fill the crank case with premium gas and run it for 24 hrs.
    Leo's first, hagrid and PomDad like this.
  28. Jul 24, 2023 at 9:29 AM
    #478
    sd172
    sd172 New Member
    South Dakota
    Happy to see someone who is confident and doing what’s best for their vehicle!
  29. Jul 26, 2023 at 4:24 AM
    #479
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Why 5w-30? Why not 0w-30? That’s what I run, if you are worried about it then 0w-40? Personally I want oil getting to critical engine parts sooner so running a 0w-Xx makes most sense to me…
    Cpl_Punishment likes this.
  30. Jul 26, 2023 at 4:30 AM
    #480
    nobodyintexas
    nobodyintexas What?
    South of Houston
    because....it does not matter what oil you use.
    5w-30 makes my motor quieter (I think)
    5w-30 is avail at Costco for CHEAP.
    and to compound this oil based conundrum...if I run out of 5w-30, i use 0w-20..what?
    and yes, I have even been known to mix them.
    all the while....our Tesla mocks us by sitting there watching us change oil.
    nobody cares.
    Life is good.
    Sierradevil and Leo's first like this.
