Filter housing on so tight it broke my filter wrench. What now? (Solved)
Discussion in '2.5 Gen Tundras (2014-2021)' started by panicman, Apr 16, 2023.
  1. Apr 16, 2023 at 12:35 PM
    panicman
    panicman [OP] Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I am doing the oil change at this interval and the last was done at the dealer. I drained the oil and got the filter drained and then went to remove the housing.
    As expected, the MENSA candidate at the dealer waaay over tightened it. I have the all metal housing. I grabbed a cheater and started applying torque. What I thought was the housing coming loose was actually the filter wrench fracturing.
    What now? Obviously I am going to have to fill the trucks oil back up, but if I go buy a new filter wrench it’s likely to just break again. Any recommendations?
    I think I’m officially done with this dealer.
    bulldog93 likes this.
  2. Apr 16, 2023 at 12:43 PM
    panicman
    Eric
    Good for exactly one more use… I used a 1-1/8 socket on the filter wrench and used a half inch torque wrench to get the housing loose.
  3. Apr 16, 2023 at 12:50 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Get a steel oil filter canister cap "socket." Here's what I have in my tool box.
  4. Apr 16, 2023 at 12:57 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    That thing looks really soft. Glad you got it off. Buy a better one and use only the large socket. I've never used center hole. This is a situation where you want an American tool
    ATV25, BigdaddyII, JuanTon21 and 5 others like this.
  5. Apr 16, 2023 at 1:41 PM
    panicman
    Eric
    Thanks guys.
  6. Apr 16, 2023 at 2:29 PM
    PKFan
    2018 Inferno! DC SR5 4x4
    Which dealer was this (so we local folks can avoid them)?
    coldcanuk and WILLINH like this.
  7. Apr 16, 2023 at 2:38 PM
    panicman
    Eric
    Wilsonville. Very disappointing. Just cements my resolve to use a good authorized shop that isn’t a dealer. This isn’t the first time they did this, either.
    I could kick them in the taco right now.
    coldcanuk, hagrid, WILLINH and 3 others like this.
  8. Apr 16, 2023 at 3:24 PM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    Yikes..!! A right boot straight to the TACO….!!!
  9. Apr 16, 2023 at 3:34 PM
    jojo9878
    jojo9878 New Member
    Joseph
    2016 magnetic grey 1794
    Front: 2.5 king 2.5 coil overs Rear: 2.5 kings
    I’ve seen some so tight that you have to replace the whole housing. Because when it did break loose it cracked the whole housing
  10. Apr 16, 2023 at 3:49 PM
    panicman
    Eric
    Why the hell would they do that? It would literally be less work and faster to just seat them appropriately.
    @JimboSlice413 and @TundraMcGov. - thanks for the product recommendation. Just ordered.
  11. Apr 16, 2023 at 3:53 PM
    Fool me twice!
    Do you have a buddy who likes beer and has a garage? It’s much more satisfying.
    TRDFerguson and bulldog93 like this.
  12. Apr 16, 2023 at 3:59 PM
    panicman
    Eric
    At home, the beer floweth freely and the curse words fly… agreed. And I like to wrench on things.
    I have space and tools for this but I do like an authorized trained mechanic to get eyes on on it every few months.
  13. Apr 16, 2023 at 4:02 PM
    The buddy thing helps so you can blame it on one another and then laugh about it, and to drive you to get parts
    I broke mine doing the 4runner, not as gracefully as you, so I feel your pain.
    panicman[QUOTED][OP] likes this.
  14. Apr 16, 2023 at 6:11 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    This seems to be very common when dealers do oil changes. When I did my first one after free oil changes ended I had the same problem. I used a 2' cheater bar and neighbor had to hold my legs. Destroyed a cheap filter wrench and plastic cap in the process. Fortunately I had a metal one on hand. I had to go to parts store for a new wrench. I gave the dealership a 0 on the survey and service manager called me. They also left out 2 skid plate bolts. Service manager ordered me 2 new ones and offered to replace the filter cap. When he said he said he would install the skid plate bolts I said no thanks will do myself. He said all the techs have torque wrenches and he held a meeting on their proper use. I just smiled and walked out wondering how many of those meetings he had.
  15. Apr 17, 2023 at 1:59 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Have the dealer take it for you. Most likely, the filter housing in the engine is toast and needs replacement under warranty since they uga uga on it. The tech probably used an impact. I'm curios on what they say.
    WILLINH likes this.
  16. Apr 18, 2023 at 2:28 AM
    rdbonds
    rdbonds New Member
    2021 SR5 4x4
    Back in 2011 when my wife bought a new Lexus CT200, I made the mistake of letting the Lexus dealership do the first free oil changes (and had to ARGUE with them that I wanted to use the allotment at 5000 miles instead of 10K). When I did the first change after, the oil filter cap was so tight I was afraid I was going to damage a motor mount trying to get it loose...the entire engine was moving a LOT while I tried to get it loose. My phone call to the dealership service department was not my finest moment.
    When I purchased my current Tundra at 19k miles, the selling dealer had serviced it and had gone full Donkey Kong on tightening it. Not quite as bad as the Lexus was, but it was just silly.
    panicman[OP] and WILLINH like this.
  17. Apr 18, 2023 at 12:53 PM
    Rocko9999
    Rocko9999 New Member
    Looks like they use gas powered impact wrench to tighten that thing.
    300BLK, ATV25, Henry1jg and 4 others like this.
  18. Apr 18, 2023 at 1:22 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I have a cheap one that only used a 27mm socket with. *knock on wood* has not failed yet after 8 oil changes.
    panicman[OP] likes this.
  19. Apr 18, 2023 at 4:21 PM
    kevine0001
    kevine0001 New Member
    Kevin
    I had an issue with my filter housing on so tight, that the tabs and "sides" all broke and it was basically round with one of the cheap ones i got from the parts counter at a dealer. When I took it in, I told them last oil change was by the dealer (last free one), and they got the housing off. I asked to see what they used, and ordered one. Here's link. It works and is very solid when fitted onto the oil filter housing.
    https://www.amazon.com/gp/product/B01B8O0BFU?ie=UTF8
  20. Apr 18, 2023 at 6:26 PM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    I'd give Toyota my left cod if the would put regular spin on oil filters on their trucks and 4runners
  21. Apr 18, 2023 at 6:47 PM
    panicman
    Eric
    Needed the laugh!
    Rocko9999[QUOTED] likes this.
  22. Apr 18, 2023 at 6:49 PM
    panicman
    Eric
    YES! I got one like that as well. It ignores the tabs on the side and only grabs the angled surfaces. $29 and recommended earlier in this thread. I’ll get to use it in about 4750 miles. A189F90C-E510-4806-B2FD-DCB9EB94DC32.jpg
    Henry1jg likes this.
  23. Apr 18, 2023 at 8:03 PM
    TRDpro4x4
    TRDpro4x4 New Member
    2016 TRD DC 5.7V8
    Yeah ..mustve done it while cursing his wife .. LOL
  24. Apr 18, 2023 at 8:41 PM
    PKFan
    I just got one of these myself. I already have the first version of the Motivx wrench which does engage the tabs, but it's too wide for my Camry, so I got the newer one, too.
  25. Apr 19, 2023 at 4:24 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
  26. Apr 19, 2023 at 4:46 AM
    FO LO
    FO LO New Member
  27. Apr 19, 2023 at 9:09 AM
    kevine0001
    Kevin
    Is the MOTIV the same? The one I got is identical to what the dealer techs were using. It's heavy and absolutely grabs that filter housing. If the Motiv is the same, great! But the flimsy metal ones that rely on the tabs are worthless.
  28. Apr 19, 2023 at 10:51 AM
    DeanoBambino64
    DeanoBambino64 New Member
    Dean
    Saskatoon Area
    2008 Tundra Crewmax Limited 4X4 5.7L V8, 20"aluminium oem wheels.
    GODZILLA and NewImprovedRon like this.
  29. Apr 19, 2023 at 11:07 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    You will only need that when you do your first oil change
  30. Apr 22, 2023 at 8:01 AM
    Kentucky22
    Kentucky22 New Member
    21 Tundra Limited 4x4
    I have a 21 limited and used one free oil change. Doing it myself going forward and yes the dealership over torqued the filter housing to death. I attempted to use a standard 3/8 drive socket wrench and it bruised my hand. That hurt for 3 days. I had to get a breaker bar to loosen the housing. Never again will they change my oil. I’m thankful they did not cross tread the plastic housing as they used the impact.
