While accelerating at exactly 40mph faint clunk/pop noise - culprit 100% = air dam.
Discussion in '3rd Gen Tundras (2022+)' started by arrampico, Apr 16, 2023.
  1. Apr 16, 2023 at 7:51 AM
    arrampico
    arrampico [OP] New Member
    2023 SR5 CM 4X4 SB Silver Tundra
    2023 SR5 4x4 Crewmax Shortbed
    Build date 13 March, 2023
    Currently at 5xx miles.
    **Edited - found the answer. Hooked up the go pro and wifi’d to the tablet in the truck.
    Sure enough exactly at 40 mph the air dam drops. Then exactly at 45 the slats close.
    They both open back up at 25 mph.
    Thanks again so much for the help. Hopefully if someone else hears this it will answer the question.
    Almost every time like clockwork -while accelerating exactly at 40 mph I get a very faint clunk sound from under the truck.
    Not accelerating hard or soft….just normal driving. Windows up, A/C on or off is same result, on a quiter road (to hear).
    Transmission is not shifting at this time nor does RPM drop.
    Any ideas? Might be something totally normal…so I’m asking here for experience/expertise.
    * Air Dam activation looking like a very strong possibility.
    in_the_mud and pwpblue like this.
  2. Apr 16, 2023 at 10:00 AM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    Does the rpm drop when this happens? Then I would guess transmission issue. Sounds like a trip to the dealer is in order.
  3. Apr 16, 2023 at 10:17 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Do you have the active air dam? It deploys at 37 mph, according to the owners manual.
  4. Apr 16, 2023 at 10:51 AM
    arrampico
    oh yeaaa!!! I do, I bet thats it too!
    but is exactly at 40. I have a video too….but not sure if i can upload videos here. maybe toss it on google drive….
    landphil[QUOTED] likes this.
  5. Apr 16, 2023 at 10:52 AM
    arrampico
    No - i will edit original post right now with more information.
  6. Apr 16, 2023 at 11:12 AM
    arrampico
    yup i do - i’ll try that. i need to find a smart place to rig it up first
    Mattedfred[QUOTED] likes this.
  7. Apr 16, 2023 at 3:03 PM
    arrampico
    @landphil and @Mattedfred thanks for the help!
    I hooked up the go pro and wifi to the tablet in the truck.
    Thanks again so much…
  8. Apr 16, 2023 at 4:16 PM
    arrampico
    yup…clunk is probably not a good word to describe it maybe slap/pop
    and the sound is super faint but you can def hear it
    i made the air dam drop like 20 times….each time the noise.
    air dam drops exactly at 40 mph
    in_the_mud and landphil like this.
  9. Apr 16, 2023 at 4:20 PM
    arrampico
    i can tell you for a fact it’s not 37 mph. it’s 40 mph. i just watched it like 20 times
    and then the front slats close at 45.
    Hella Krusty likes this.
  10. Apr 16, 2023 at 5:14 PM
    Eagleye
    Eagleye New Member
    22 SR5 4x4
    Rear seat cover, bed mat
    Mine was catching on the right AFE Tow Hook a tiny amount, couldn’t adjust the tow hook to completely clear and had to remove a small amount of material from spoiler. Super easy.
