Rack and pinion leak
Discussion in '1st Gen Tundras (2000-2006)' started by 270Fan, Aug 11, 2020.
  1. Apr 13, 2023 at 10:27 AM
    Lupe
    Lupe New Member
    Lupe
    2006 Tundra
    Came across this. Going to look up more info on it. Pretty cool they have a whole video how to change you rack.
  2. Apr 13, 2023 at 10:27 AM
    Lupe
    Lupe New Member
    Lupe
    2006 Tundra
    Something to look into i guess.
  3. Apr 13, 2023 at 10:40 AM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Eibach Pro Sport Shocks (1.25in), RAS HD, Sumo Springs, HAWK Talon Rotors, OEM Tow Mirrows, Lund Hard Fold Tonneau, ESP Storage, Stampede Flares, Husky xAct Fit liners, General Grabber ATX 275/60R20
  4. Apr 13, 2023 at 7:35 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I would be careful with that front end "kit" definitely would not use those lower ball joints.
  5. Apr 13, 2023 at 8:59 PM
    Dracko
    Dracko New Member
    2005 Tundra SR5
  6. Apr 14, 2023 at 7:23 AM
    I don't think any of us on here are necessarily rich, and most of us struggle with the cost of OEM.
    That said, there's somethign to be said about how long OEM already lasted and will last on the replacement part, and knowing you'll probably buy 2, maybe 3 aftermarket units in the time a new OEM will last ... aftermarket will likely cost more in the long run, and definitely create more labor. I've rarely in my lifetime seen aftermarket parts last even half as long as OEM *especially* with the shit-quality of parts these days.
    Ultimately, it's your money, your budget. But there is a valid, financially sensible reason for replacing with OEM when you can't get the same part direct from Toyota's suppliers (Denso, Aisin, or sometimes Bosch, Hitachi).
    Another tidbit of advice. Toyota also supplies remanufactured parts. If you have a part number, try adding "84" to the end of it. Like:
    43430-0C010 => CV axle, new
    43430-0C010-84 => CV axle, refurbished
    (note: The new part numbering seems to remove the dashes, like 434300C010 and 434300C01084)
    I've found in the Toyota Parts system where they won't list the remanufactured part. Like @16CMTXED posted a link to the steering rack, 442500C030. I went to Toyota Parts website and plugged in 442500C03084 and lo and behold, at one point, they sold it remanufactured but none are currently available. However, it's not marked as 'Discontinued', so maybe it will become available at some point.
    16CMTXED likes this.
  7. Apr 14, 2023 at 6:32 PM
    Dracko
    Dracko New Member
    2005 Tundra SR5
    I couldn’t agree more Shifty, long term planning OEM is the way to go…and in some cases, the only way. But I have been relatively lucky with some aftermarket parts too, so when if I can replace for a 1/3 or in some cases, 1/4 of the OEM price, I’ll often roll the dice. But I’m definitely not disputing your logic, it makes more sense in the long run.
    And thank you very much for that interesting piece of info regarding refurbished PN’s, very cool! and worth keeping an eye on or checking some locations up here in Canada.
