XSP tires anyone?
Discussion in '1st Gen Tundras (2000-2006)' started by AV8R4AA, Apr 14, 2023.
  1. Apr 14, 2023 at 9:51 AM
    AV8R4AA
    AV8R4AA [OP] New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    I have the 20 inch wheels in my 2005 DC Tundra.
    It’s time for new tires. Anyone find something that rides well and
    doesn’t require a kidney to install?
    I have 2 WD.
    It’s a mostly Highway truck that occasionally picks up Home Depot stuff.
  2. Apr 14, 2023 at 10:33 AM
    Casper421
    In the woods
    06 DC
    Michelin defender ltx m/s. Should last you at least 50k+ miles. The 20” wheels are gonna kill you on price with any tire.
    Tundra Dude 45, Sean492 and shifty` like this.
  3. Apr 14, 2023 at 10:37 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Oof. Ethnic wheels are about to get canceled. My 20's are nitto terra grappler. But i rock the 16's and bichelins by choice.
  4. Apr 14, 2023 at 11:23 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    I've always had luck with used tires but never tried to get 20's. With a lot of modern factory vehicles having 20" wheels I'm sure you could find a matching set of 'take-offs' at a used tire shop. I've got 18's now but don't need tires just yet.
    The past 10 years or so that's all I have run on my Toyotas are some sort of used set of 17" truck/suv tire that were OE on some other car but they upgraded to off-road tires or bigger wheels after they bought their vehicle. That's why they are called 'take-offs' or 'roll-offs', depending on where you are. The tires come from cars that just 'rolled off' the sales lot.
    Just be sure to check the DOT date code on the tire sidewall to make sure the tires aren't too old and prone to dry rot.
  5. Apr 14, 2023 at 11:43 AM
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I also have the 20 inch wheel, and chance has it I used the price match on Discount Tire.
    You have to find the exact same brand/size/type, submit the link and screenshot through DT and they will get back to you in a few days to either accept or reject your offer.
    I got mine matched and beat by a few bucks, which saved me close to $250 for a set of 4 tires.
    Wouldn't hurt to give it a try, just FYI, I used Walmart.com to produce the lower cost.
  6. Apr 14, 2023 at 5:12 PM
    sflips
    sflips New Member
    Middle Tn.
    2006 DC XSP
    PXL_20230415_000303558.jpgcontinental terrain-contact 275/55 R20. Great tire for 2WD slightly aggressive, very quiet. When these wear out they will be replaced with the same tire
  7. May 5, 2023 at 6:43 AM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    Wondering what XSP guys use for tire pressure?
    I’m trying 35 each corner for now.
  8. May 8, 2023 at 6:49 AM
    JQ3
    JQ3 2005 XSP rwd
    Michelin Defenders. I run a pressure of about 38.
