Does powertrain warranty cover front wheel bearings?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra-dude, Mar 22, 2023.
  1. Mar 22, 2023 at 5:34 PM
    Tundra-dude
    Tundra-dude [OP] New Member
    2020 Tundra SR5 CrewMax
    Folks, I have a 2020 Tundra that is at 27K miles but over the 3 years for the base warranty. I just started hearing what I think is a front wheel bearing failure. Does anyone know if the 5 year/60K mile warranty covers the front wheel bearings? I'd like to be armed with this before heading to the dealership. I'm at 3 months over the 36 month coverage where I know for sure the bearings would be covered. Thanks for the help.
  2. Mar 22, 2023 at 6:16 PM
    Retired...finally
    If not corporate may work with you since you are just over on time and below mileage. Honda was very good about this and my guess is Toyota will be too.
  3. Mar 23, 2023 at 4:28 PM
    737fixer
    737fixer New Member
    No chance the powertrain will cover it but unless your running spacers with 35's + tires I can't see a reason Toyota wouldn't help at least partially with this. 27K is insanely low for a wheel bearing. Not to doubt your diagnosis but again 27K is mindboggling low for our Tundra wheel bearings which makes me think it's something else.
  4. Mar 23, 2023 at 7:09 PM
    Tundra-dude
    All stock truck. It looks like it may be the front differential needle bearing failure. I agree, 27k miles is mind-boggling low. However, our 2015 Toyota Highlander, also bone stock, had a wheel bearing failure at almost the same mileage and less than 3 years. Lucky for us, warranty covered it.
  5. Mar 23, 2023 at 7:17 PM
    I had my wheel bearing swapped out on my 2012 tundra at 55k. The CPO warranty covered it. Come to find out the driver side needle bearing was going out. They did some more research and recommended I do the ECGS bushing, but wouldn't cover it but would install for 600.00. I told them "no thanks" and fix it under warranty. They swapped out the front differential for 2800.00. Not sure how that was a better deal, but not my money.
    After the front diff was swapped, truck was never the same. Sold it at 89k miles.
  6. Mar 23, 2023 at 7:21 PM
    :thumbsup: Edited. Thanks amigo.
  7. Mar 27, 2023 at 5:47 PM
    Tundra-dude
    They've determined the issue is the front differential needle bearing. So, at 29K miles that's really a premature issue for a bone stock truck. The good news is that it is all covered under warranty. I just hope it doesn't keep failing every 29K miles. Now, I think we caught this very early since you can barely hear the difference but it's definitely different. We'll see how the repair goes in a few weeks.
    kittyhawk likes this.
  8. Apr 7, 2023 at 10:18 AM
    kittyhawk
    kittyhawk New Member
    Dave
    Houston/Buffalo Texas!!!!
    2015 Tundra Crewmax SR5 4x4
    6112/5160. Ranchhand rear bumper and Valhallas Shields.
    Good to hear that it'll be covered under the warranty. That's crazy to fail with only 29k, my 15 has right at 160k and has has a small lift for the last 45k and haven't had any issues. Good luck with getting it fixed up.
  9. Apr 14, 2023 at 11:09 AM
    Tundra-dude
    Folks, FYI, they replaced the front diff under warranty and the issue has been resolved. Hope it doesn’t come back once I’m out of warranty. My truck is bone stock, no off road, and nearly zero use of 4 wheel drive. Only engage 4 wheel drive per the manual recommendation for periodic maintenance.
    TXBrit and Northbound Train like this.
