Accessory 12V sources (for air compressor)
Discussion in '2.5 Gen Tundras (2014-2021)' started by AAA96, Apr 14, 2023.
  1. Apr 14, 2023 at 6:16 AM
    AAA96
    AAA96 [OP] New Member
    2020 Tundra 4x4 SR5 CrewMax
    Hello, I am trying to wire up a 12v air compressor (mounting in bed passenger side toward front).
    Can anyone point out where the best source is for 12v accessory wire worthy of a 16amp load?
    Also, where is the best source for a 12v in the dash for an intermittent toggle switch.
    thanks.
  2. Apr 14, 2023 at 7:26 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    You’ll need to do your own fuse tap or relay. You won’t find an “accessory” circuit that’s directly rated for that kind of load directly, and especially to tap off of and add that load to.
  3. Apr 14, 2023 at 7:34 AM
    AAA96
    I plan to use a spare slot in the fuse box to get the 12v for the toggle switch.
    I then plan to run 10ga wire to the relay for power and ground. The 12v switched signal to the relay will also come from the switched power source from the fuse box.
    what is the best route to run the 12v 10gauge wire from the battery to the bed on passenger side?
  4. Apr 14, 2023 at 10:51 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Follow the factory harness - Through the engine bay behind the engine to the junction box near the passenger firewall, then down along the harness through the corner of the passenger fender well, then along the frame. Run them inside of some smurf tube/wire loom and zip tie everywhere that the main harness is tied to the frame.
    AAA96[OP] likes this.
