General Turbocharger Thread (formerly "Turbo Charging A Tundra!")
Discussion in '2.5 Gen Builds (2014-2021)' started by bflooks, Nov 15, 2022.
  1. Mar 31, 2023 at 4:25 AM
    #481
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Good things happening with the Tundra. Tuning should be wrapping up shortly. :)
  2. Apr 13, 2023 at 9:09 PM
    #482
    AZTundra
    Paul
    Phoenix, AZ
    Been almost two weeks now, any update?
    Saltyhero13 likes this.
  3. Apr 14, 2023 at 4:47 AM
    #483
    TurboKits
    TurboKits New Member
    Thanks for your patience all. This is our busiest time of year with people getting their tax refunds and wanting to finish projects before the nice weather, etc. Anyway, we ran out of MAF flow with the 4.5" MAF pipe at about 6.5 PSI. This is not a negative thing, it means we are making great flow, more than the tuner expected! The truck is running great, super-fast, but below our goal of 7-8 PSI. We really want to see over 500WHP, just to have a nice proven #. Even though we feel most customers will be happy running the 6PSI kit, as the truck was silky smooth and fast there. Unfortunately, we got about 2 revisions into the rescaling for the 5" MAF pipe and the tuner hasn't gotten back to us in over a week. Unfortunately, and we feel horrible for him, his mother is going through Chemo and obviously he has more important things to attend too. The donor truck owner, Ken, is getting antsy to get his truck back as well, so we are going over all of the options to see which one fits best for the current situation... The silver lining, we got tons of fresh new info, where able to create now a 3rd revision to our intercooler piping, which should aid in better fitment for all 2007-2021 Tundra with this kit, plus we got TONs of installation pictures to create a thorough step by step instruction set. Nothing is really lost here. We know the truck will handle the 7-8 PSI we are targeting with the 5" MA pipe and most likely break the 500WHP mark. The only thing we'll be missing is the DYNO to prove it (for now), as we'll undoubtedly get another truck in, maybe even buying a second one for our fleet and do it all over again. Anyway, thanks everyone for your interest and support!!
  4. Apr 14, 2023 at 6:13 AM
    #484
    centex
    centex New Member
    That would be great. Any closer to an idea on pricing?
  5. Apr 14, 2023 at 6:25 AM
    #485
    TurboKits
    Stage 1 - $5-$6K depending on options
    Stage 2 - $7-$8K depending on options
    These are just estimates and adding upgrades like ball bearing turbos, ceramic coating, gauges, etc can push it higher. The plan would be that the Stage 1 can easily be upgraded to the Stage 2 with a rotation of the compressor housing. So all of the hot side stays the same.
    M3Tundra-JK likes this.
  6. Apr 14, 2023 at 6:48 AM
    #486
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    Does the stage 2 cost include water meth or is that a totally different system to account for?
  7. Apr 14, 2023 at 7:16 AM
    #487
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    Tuning; I don’t know a whole lot about tuning tundras, but would you be able to change the MAF to speed density? This would eliminate the need to have it in the system.
  8. Apr 14, 2023 at 7:32 AM
    #488
    Saltyhero13
    Saltyhero13 Throbbing Member
    Based on other discussions on this forum yes speed density is an option via Power Enrichment.
  9. Apr 14, 2023 at 7:45 AM
    #489
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    That’s interesting that the MAF voltage was exceeded. The Prospeed builds I had seen that are pushing around 20psi making 700+whp all use the Prospeed 4.5” intake and don’t have that problem that I’m aware of.
    Saltyhero13 and M3Tundra-JK like this.
  10. Apr 14, 2023 at 7:51 AM
    #490
    TurboKits
    Unfortunately the one place that Toyota screwed the pooch on this platform, there is no back up MAP sensor. The GM guys with HP tuners, can completely remove the MAF and use the factory MAP sensor to convert to speed density. There is no way to do this within the factory ECU tuning parameters that we know of, since there isn't a map sensor on the motor and no provisions for one in the ECU mapping.
    Interesting, got a link? Are they using HP tuners and the factory MAF?
    Water Meth will be optional on both kits, but both kits will have a nozzle bung pre-installed in the charge piping for easy upgradability.
    TucsonTundra1794 and M3Tundra-JK like this.
  11. Apr 14, 2023 at 7:55 AM
    #491
    Saltyhero13
    Delata is probably the upgraded TB. Aren't there limitations with MAF scaling as well? Thought it was recently discussed in the other thread.
    Silver17[QUOTED] likes this.
  12. Apr 14, 2023 at 7:58 AM
    #492
    Saltyhero13
    That is quite unfortunate. I was expecting to hear it was calculated sans MAP.
    On your designed build is there a temp sampling post cooling?
    Thanks.
    reywcms likes this.
  13. Apr 14, 2023 at 8:04 AM
    #493
    TurboKits
    Yes, if you look at the location of the MAF as well as the multiple posts about IATs, our MAF is located as a blow through set up and after the intercooler.
    Saltyhero13[QUOTED] and mZiggy like this.
  14. Apr 14, 2023 at 8:08 AM
    #494
    Silver17
    Eastern PA
    I do think those builds have the RCF TB, but that wouldn’t effect the MAF voltage limit other than it will only allow even more air through to jack the voltage higher. The MAF doesn’t care what size the TB is, it’s just measuring the airflow through the size tube in which it is located.
  15. Apr 14, 2023 at 8:09 AM
    #495
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    How are you extending the MAF back there? I know a few people, not many, have had issues with the Harrop MAF wire extender
  16. Apr 14, 2023 at 8:10 AM
    #496
    TurboKits
    There is room on the factory harness. We did not cut or splice or add any wiring...
    M3Tundra-JK[QUOTED] likes this.
  17. Apr 14, 2023 at 8:11 AM
    #497
    M3Tundra-JK
    Scott
    2005 GX470
    Cool, so probably the same as the Magnusun instructions have you do. Cut back the wire loom to allow the MAF to move to the back, then re-add wire loom
  18. Apr 14, 2023 at 8:12 AM
    #498
    TurboKits
    Yes sir
  19. Apr 14, 2023 at 8:15 AM
    #499
    Silver17
    Eastern PA
    Unfortunately I don’t have a link with a ton of details since it’s on FB, but the one build that comes to mind belongs to Bryan Jones on the boosted tundras page, if you join and search. That one is a Whipple build. The other 700+ build was a Harrop owned by Brent. I believe so, but those high HP builds also use a Motec ECU I think.
  20. Apr 14, 2023 at 8:19 AM
    #500
    Saltyhero13
    It probably was and I am not keeping up with all the updates on this thread.
    So the MAF itself is used to determine charge temp? On Stage 2 Meth is used post MAF?
  21. Apr 14, 2023 at 8:26 AM
    #501
    M3Tundra-JK
    Scott
    2005 GX470
    I LOVE that hood. Would be perfect for the Turbo setup. Would also be really cool to see the ram-air incorporated into an open top air box, that is completely sealed when hood is closed.
    @TurboKits.com should put it as an option on their site and drop-ship it from the manufactures :monocle:
    Saltyhero13 and Silver17[QUOTED] like this.
  22. Apr 14, 2023 at 8:29 AM
    #502
    TurboKits
    Meth is sprayed after the MAF, correct, we did not want to corrode the MAF with the meth mixture.
    Saltyhero13[QUOTED] and Silver17 like this.
  23. Apr 14, 2023 at 8:30 AM
    #503
    TurboKits
    If it's any ECU other than the factory one, then it's speed density...
  24. Apr 14, 2023 at 8:40 AM
    #504
    Silver17
    Eastern PA
    Gotcha, yeah honestly can’t say for sure. Motecs website makes it sound like you can use the MAF since they offer adapter wiring looms for MAF sensors. It’s weird though that most of us are pushing 10-11psi on a 3.85” Magnuson box MAF tube and in the 500whp range and we are just approaching the 5v limit with that. The 4.5” seems bigger than necessary for most of our builds. Maybe the blow through MAF on the turbo setup creates a higher voltage reading than the pull through on the SC kits?
  25. Apr 14, 2023 at 8:46 AM
    #505
    TurboKits
    Do you have any DYNO charts and tunes for people making 500WHP on a 3.85" MAF tube? My tuner stated that even the SC guys going to 500WHP are running the larger MAF tubes. Unless of course, they are using a MAF signal conditioner like from URD or Split Second and then just riding the top line of the tune. This is a fairly viable way to do it, let's say you are maxing out at 6 PSI and want to run 7 PSI, but if you are maxing out at 6 and trying to run 12 PSI, you are losing a ton of definition in the mapping cels to the max voltage.
  26. Apr 14, 2023 at 8:49 AM
    #506
    Silver17
    Eastern PA
    There are dyno charts on Facebook, which if you really want to see I can dig up of guys making 540ish whp on the even smaller stock 3.5” intake actually (the Whipple and Harrop do not provide a larger intake with their kit).
  27. Apr 14, 2023 at 8:50 AM
    #507
    M3Tundra-JK
    Scott
    2005 GX470
    @e30cabrio is going on the dyno again today. He has the 92mm Maggy intake
    https://www.tundras.com/threads/general-supercharger-thread.85513/page-254#post-3158095
  28. Apr 14, 2023 at 9:30 AM
    #508
    Saltyhero13
    Some folks like @nobodyintexas have hit the MAF limit below 500WHP if I am not mistaken.
    Not everyone is using the same dyno either so there is some variance in figures reported.
    Silver17 likes this.
  29. Apr 14, 2023 at 5:24 PM
    #509
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Yup
    wot hits maf max
    but my intake is all stock
    Saltyhero13[QUOTED] likes this.
  30. Apr 14, 2023 at 5:41 PM
    #510
    Silver17
    Eastern PA
    @e30cabrio just put down some nice numbers today on the 3.85” magnuson intake. Maybe he will share his dyno chart here, as he did in the supercharger thread.
