Damaged TRD lift axle ring-what would you do?
Discussion in '3rd Gen Tundras (2022+)' started by Silver23, Apr 12, 2023.
  1. Apr 12, 2023 at 5:16 AM
    Silver23
    Silver23 [OP] New Member
    2023 Silver 1794 TRD
    So I purchased my TRD lift about a month ago and was finally able to get an install appointment with my dealer this week. They called me yesterday to inform me that the outer metal ring on both axle's were damaged. He said the tech can straighten the metal ring and it shouldn't be an issue. They also said the black seal isn't damaged. I guess I should have inspected the kit when it was delivered. I don't think there's anything I can do except move forward. I will contact Sparks Parts today but I'm sure they'll tell me to send the axle's back before they send a new set. Meanwhile, my truck is torn apart right now at the dealer and I'm sure they would charge me to put everything back together. The service manager stated everything is under Toyota warranty for one year.
  2. Apr 12, 2023 at 5:22 AM
    NCrunner2012
    NCrunner2012 New Member
    Steven
    2007 Tundra Limited 4x4
    Id straighten it and roll with it. It's just a dust seal and should be just fine.
    ArticTundra likes this.
  3. Apr 12, 2023 at 5:24 AM
    Tom976
    Tom976 New Member
    Tom
    Looks like it might have been damaged in shipping.
    As for fixing/Reparing it? The dust seal on that axle doesn't look right at all. I wouldnt long term any repair on that but to each their own.
    Is it worth the chance of a diminished lifespan of the axle?
    Once the tech takes tools to it, sparke isnt going to touch it for a return.
    You're definitly in a pickle. I'd see if the seller will even help at all.
    This might be something that shipping company would have to deal with and that can take a long time.
  4. Apr 12, 2023 at 5:25 AM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    That's a replaceable dust seal and it's very common for them to get damaged on new axles. I would ask the dealer if they can swap on new ones for you, shouldn't cost more than $100 including parts.
    iiawah808, Skidmarcx and landphil like this.
  5. Apr 12, 2023 at 5:46 AM
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    Not sure if they’re the same diameter as what is on your truck now , but if inside and outside ID are the same they can be taken off easy
  6. Apr 12, 2023 at 8:26 AM
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    This is the route I would take. I would ask the dealer that's installing to replace the seal. i think its worth the cost in the long run.
  7. Apr 12, 2023 at 9:45 AM
    Silver23
    Sparks parts is sending me replacement seals. Guess I'll keep them on hand if the originals ever fail/cause an issue. I'm sure it's a hefty price to replace the seals at a later date.
    iiawah808 likes this.
  8. Apr 12, 2023 at 9:57 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'd be pissed but then I'd think about it over a beer and go with the new seals approach. Then drink another beer in satisfaction over my ability to overcome life's obstacles.
    Black Wolf likes this.
  9. Apr 12, 2023 at 10:45 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    If it's an option I would replace the seals before install. They mate up to the backside of the wheel bearing and keep all the grime out of there, so with a less than stellar seal, you may shorten the life of your wheel bearings. It's not THAT big of a deal but might as well if it's an option.
  10. Apr 12, 2023 at 10:59 AM
    Silver23
    They straightened the metal ring and sent me this pic. Guess I'll roll with it or inquire about a price to replace the seals with the new ones come in.
    KNABORES likes this.
