22 Tundra TRD Pro nightmare
Discussion in '3rd Gen Tundras (2022+)' started by Willyd6869, Apr 12, 2023.
  1. Apr 12, 2023 at 6:27 AM
    Willyd6869
    Willyd6869 [OP] New Member
    22 Tundra TRD Pro
    Hey Yall,
    I would love some advice. I am at a loss at what to do regarding this situation.
    I have had my 22 TRD Pro for 6 months and it has 8,000 miles on it. I purchased it new.
    I am driving when all of a sudden I get a "Parking Brake Malfunction" and "Trailer Warning Type or Connection Fault" warning.
    The truck was driving normally aside from the warning messages.
    I take it to the dealer and they tell me it needs a new brake actuator.
    They replace the brake actuator and that doesn't fix the problem.
    They say I need a new Skid Control ECU and that it is "Galactically Backordered".
    They give me a loaner car and I settle in for what could be a while.
    A week later, they call me and let me know my truck should be ready the next day and it was actually something besides the Skid Control Ecu.
    The next day they call me and let me know that I no longer qualify for a loner because the issue is my fault. They are claiming that a soda spilled into the fusebox under the rear seat and corroded the connector. They say a new fusebox will be $388 installed and if that doesn't fix it, I will need a new harness that will run $3k. None of it covered under warranty. The fusebox should arrive 4/23.
    I do not have kids, I do not drink sodas, I do not allow food and drink in my vehicles, and maybe two people have ever ridden in the back seat. I wash the inside and outside of my truck myself every weekend. This is definitely something that would not go unnoticed.
    At this point, things are sounding very fishy. If the skid control ecu was "galactically back ordered", why were they messing with my truck in the first place. I couldn't get a straight answer.
    I went to pick up my truck because I need a vehicle in the meantime and I no longer have a loaner car.
    When I pickup my truck, the service manager and the mechanic bring it around together and they tell me the brakes are extra sensitive.
    When I get in the truck to leave the dealership, there are a whole host of warning lights on the dash, and the brakes are basically unusable.
    In addition to the Parking Brake Malfunction and Trailer Warning Type or Connection Fault warnings, I now have:
    Check Engine Light
    Braking Power Low
    Parking Support Brake Malfunction
    Secondary Collision Brake Malfunction
    Pre Collision Malfunction
    The brakes engage very quickly at the top of the pedal, and then they turn to mush and the pedal goes to the floor. The truck has probably 1/4 of the braking power it had before.
    I know the mush feeling from bleeding the brakes on previous trucks, but having the brakes engage firmly and then turn to mush is a new one for me. I assume it is due to some new electronically controlled gizmo.
    I don't even know how to proceed. My first instinct was to just get my truck the hell out of there. Any advice would be very helpful. I just don't know how to argue with insanity. This dealership clearly has no idea what it is doing.
    Do you think I should bleed my brakes and see if that helps? I really need this truck to be drivable until I can get it fixed. It is pretty much impossible to drive. The few miles from the dealership to my house were quite sketchy.
    I will attach a photo of the corroded connector in the fusebox they sent me.
    Acedude likes this.
  2. Apr 12, 2023 at 6:29 AM
    Take it to a different dealer
  3. Apr 12, 2023 at 6:36 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    I don’t see evidence of spelled sod. Just a shitty part
    Gotink, excelw, kparrow and 5 others like this.
  4. Apr 12, 2023 at 6:36 AM
    TWade
    TWade New Member
    Tanner
    2023 Tundra TRD Pro Black on Black
    On top of trying a different dealer, I would complain to BBB. I would also contact Toyota corporate (I know easier said than done). This sounds like absolute BS and I am pissed just hearing this story.
  5. Apr 12, 2023 at 6:48 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Wow! Sounds like this dealer needs a complete new management! Like it happened in my local dealer.
  6. Apr 12, 2023 at 6:49 AM
    Skidmarcx
    Skidmarcx New Member
    Glendale, AZ
    ‘22 SR5 CM
    If something was spilt there would be evidence on TOP of the connection and box, this is very strange and I agree go to a different dealer
    So sorry you’re going through this what an ordeal
    Gotink, Willyd6869[OP] and Y0TA PR0 like this.
  7. Apr 12, 2023 at 7:03 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    This is ridiculous.
    The dealership is clearly incompetent and has no clue what is actually happening. As suggested, try a different dealership, call corporate, and BBB.
    ATV25, Willyd6869[OP] and Y0TA PR0 like this.
  8. Apr 12, 2023 at 7:58 AM
    Willyd6869
    22 Tundra TRD Pro
    Thank you very much for your advice everyone!
    I am working on getting it towed to a competent dealer about 45 minutes away. There's absolutely no way I'm taking it on the interstate with these brakes haha.
    The dealer that I have had these problems with is Lakeside Toyota in Metairie, Louisiana. Just outside of New Orleans.
    They did my 5,000 mile maintenance and everything was great. Just wanted to add that for transparency and give credit where credit is due.
    I will update everyone when this gets resolved.
    Thanks again, Will
  9. Apr 12, 2023 at 8:16 AM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC! As others have mentioned take it to a different dealer. Still under factory warranty….
  10. Apr 12, 2023 at 9:30 AM
    Adam B
    Adam B New Member
    2022 Tundra TRD OFF-RD LIMITED- Green & 2024 Tundra TRD OFF-RD LIMITED- Silver
    Next stop General Manager.
    Mattedfred likes this.
  11. Apr 12, 2023 at 9:38 AM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    This makes me sick and its not even my truck. Hopefully the new dealer will have some talented mechanics
    Durtywrench likes this.
  12. Apr 12, 2023 at 9:43 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    shouldve left it there if it had more issues than it came in with
  13. Apr 12, 2023 at 9:52 AM
    katekebo
    katekebo New Member
    So ...
    1) The part definitely looks corroded. Is this the root cause of the problem is still to be confirmed.
    2) These type of connectors are pretty reliable and durable. They don't corrode with just ambient humidity. Some corrosive fluid must have gotten inside. I doubt soda would cause that much damage. Now, you live in Louisiana. Any chance some salt water was spilled on the seat? Like as if you went fishing and than left some soaked clothes on the rear seat? (Lake Ponchantrain is pretty brackish, so it would count as salt water. I lived in Slidell for 3.5 years.)
    3) You could try cleaning the connector. Disconnect the battery. Then used a hard nylon brush (even a hard toothbrush could work) to remove the green stuff. Make sure to clean thoroughly both the plug and the socket. If the problem goes away (or becomes intermittent) after cleaning, at least you will know that this is really the cause. You will still need to replace the damaged parts (you don't want to risk a failure while driving 80 mph on the highway), but you will know what needs to be replaced rather that exposing yourself to a "parts canon".
    4) Are you 100% sure that the photo is from your car? Or did the dealer sent you some random photo from another car to wash their hands?
  14. Apr 12, 2023 at 11:08 AM
    Taikowaza
    Taikowaza New Member
    I might also lawyer up
    troutback likes this.
  15. Apr 12, 2023 at 11:16 AM
    Jaxyaks
    Jaxyaks New Member
    Trade it
  16. Apr 12, 2023 at 11:37 AM
    Tundra_power
    Tundra_power New Member
    That’s insane I just got piss off while reading that. Good move on towing it to a different dealer. Seems like your local dealership made everything worse and I feel like something is a-little fishy going on there.
  17. Apr 12, 2023 at 12:45 PM
    OnThaLake
    OnThaLake New Member
    I recently bought an older Acura TL as a first car for my son.
    It was thoroughly neglected, and has 20 years of soda and Starbucks spilled everywhere inside the car. Seat heater switches were clogged, wiring harness connectors going through the inside of the center console caked in syrupy goo.
    So, I consider myself an expert at identifying this kind of situation.
    There's absolutely zero signs of a beverage being spilled into the connector. However, it does have signs of "clean" water intrusion. Which, ideally, should never occur in a modern vehicle. Connectors that are not sealed are supposed to be in areas where moisture typically can't enter the connector.
    So, in this picture, I'm wondering how that connector became damaged....
    kparrow likes this.
  18. Apr 12, 2023 at 1:02 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Wow! I'd call Toyota Corporate and complain for sure. The dealer is as sketchy as your brakes. Get another dealer's professional opinion on the matter and share everything you were told and received from the sussy dealer including invoices/estimates/secret conversations had with the manager written on a napkin...
  19. Apr 12, 2023 at 1:02 PM
    troutback
    troutback New Member
    2023 Blueprint SR5 CC
    I'd open a case with Toyota Corporate and call a lawyer.
    Adam B and kparrow like this.
  20. Apr 12, 2023 at 1:23 PM
    Not sure what the lawyer is for
  21. Apr 12, 2023 at 1:26 PM
    eddiefromcali
    Eddie
    100% Stock
    Worst advice ever.
  22. Apr 12, 2023 at 1:34 PM
    Tom976
    Tom976 New Member
    Tom
    Calling a lawyer will be great for the lawyer but you will have to pay those legal fees.
    As for the connector, cant the part just be cleaned up (both side of the connector) and put back in?
    I'd put some dielectric grease in there and put it back together.
    KNABORES likes this.
  23. Apr 12, 2023 at 1:40 PM
    eddiefromcali
    Eddie
    100% Stock
    can def be cleaned up. Some electrical parts cleaner, a toothbrush and some compressed air will make quick work of that.
    4genRunner likes this.
  24. Apr 12, 2023 at 1:44 PM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    Sounds about as competent as my Toyota dealer. Hopefully the next dealer has a clue, for your sake.
  25. Apr 12, 2023 at 2:23 PM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    Make 1-800 Toyo take you seriously. Otherwise they will blow you off
  26. Apr 12, 2023 at 2:29 PM
    Willyd6869
    22 Tundra TRD Pro
    They cleaned up the connector when they had it and it came back to me with more warning messages than before unfortunately.
    I can definitely see how saltwater would cause this type of corrosion, but I put all wet stuff in the bed or in my bed mounted tool box if it would blow out of the bed untill I get home.
  27. Apr 12, 2023 at 4:07 PM
    Prohit
    Prohit New Member
    2024 Sequoia Platinum
    just curious to why? I would not want a 70k brick sitting in my driveway.
    Even if fixed who knows what will pop up next. I would definitely get rid of it.
  28. Apr 12, 2023 at 5:24 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    This definitely sounds like some BS. I do not have a Pro or hybrid so I do not know what it looks like under the seat. A fuse box with a lid on it shouldn't be able to "get" any liquid spilled on it. As for soda corroding, I'm pretty sure when I was a little kid, soda is what you poured on a car battery to clean the corrosion. Can you get to the supposed cleaned connector for inspection? See if there is evidence of it being corroded or cleaned. And they tell you your truck is ready yet it has more lights? Did you bring it to their attention before you left the lot? It always pisses me off when I hear a dealer try to place blame on something that most likely is not your fault. Hope it gets sorted out.
    Tom976 and in_the_mud like this.
  29. Apr 12, 2023 at 5:27 PM
    Fxclm5
    Fxclm5 New Member
    What state are you in, do yours have any lemon laws, has truck been on n dealership possession for more then 30 days trying to fix the same issue, if so this qualifies for Cali lemon law
  30. Apr 12, 2023 at 7:59 PM
    Tom976
    Tom976 New Member
    Tom
    Why oh why did Toyota have to complicate things with these trucks.
    Wish they'd make one with just be enough computers to keep the motor running.... well and the tailgate camera.
    Now we have many ecu's linked via CAN.... One trips and many others follow.
