Cruzer's Re-Build for the Rubicon
Discussion in '2.5 Gen Builds (2014-2021)' started by Cruzer, Dec 8, 2020.
  1. Apr 1, 2023 at 12:40 PM
    #1081
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    When I recently busted the CV axle I found myself running around like a headless chicken wasting time looking for the tools I needed to replace it. My friend was like “I thought you could swap out an axle in less than 30 minutes?”
    I decided I needed a dedicated toolset all in one place so I got a pouch for all the small tools.
  2. Apr 1, 2023 at 12:43 PM
    #1082
    Sunnier
    Sunny
    San Diego, CA
    Awesome!
    I'll bring the torque wrench.
  3. Apr 1, 2023 at 1:02 PM
    #1083
    Are the two extra bolts for the lbj just in case?
    Sunnier likes this.
  4. Apr 1, 2023 at 1:20 PM
    #1084
    Cruzer
    Cruz
    Sunnyvale, CA
    They’re for the brake calipers
  5. Apr 2, 2023 at 6:56 AM
    #1085
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Is that a murse?
  6. Apr 8, 2023 at 2:28 PM
    #1086
    Cruzer
    Cruz
    Sunnyvale, CA
    Hmm well check that out. Broke in a different spot than I thought, which is great cuz I don’t have to take out the driver CV axle :D glass half full I’d say.
  7. Apr 8, 2023 at 7:07 PM
    #1087
    Sunnier
    Sunny
    San Diego, CA
    Hey, what's up with this?
    When I look at the "right" one, I see a difference in the metal, about the same place where the other one broke. Is that something to do with fabrication, or wear? (Something that's gonna happen again?)
  8. Apr 8, 2023 at 7:13 PM
    #1088
    SAGE63
    San Diego County
    good catch sunny
    Sunnier[QUOTED] likes this.
  9. Apr 8, 2023 at 8:43 PM
    #1089
    Cruzer
    Cruz
    Sunnyvale, CA
    :monocle: Didn’t notice, guess we’ll find out
  10. Apr 9, 2023 at 9:47 AM
    #1090
    Cruzer
    Cruz
    Sunnyvale, CA
    Went through the garbage bin to fish these suckers out to get a better look. I'm not a metal guy. Does it look like it was once a solid shaft or was it welded together? @helidave @snivilous
    reywcms likes this.
  11. Apr 9, 2023 at 9:50 AM
    #1091
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Hmm interesting
  12. Apr 9, 2023 at 10:06 AM
    #1092
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Looks solid to me. Looks like a pretty classic shear failure. I'm not a metallurgist but the colors I wouldn't chalk up to much besides maybe darkening from high stresses. The outer cracking is probably due to the OD having the highest strain and once it fracture strain and couldn't stretch any more it let go and then the rest of the shaft too. The look of the surfaces and the sphincter look pretty standard for a sheared shaft.
    If you search shaft shear failure there's some pictures that look very similar with the discoloration, surface condition, and the axis of twist.
    This website shows a similar picture:
    https://cr4.globalspec.com/thread/12259/Failure-Analysis-of-agitator-shaft
  13. Apr 9, 2023 at 10:10 AM
    #1093
    Cruzer
    Cruz
    Sunnyvale, CA
    Dropping that knowledge! :hattip:
    ATV25, Sunnier, reywcms and 2 others like this.
  14. Apr 9, 2023 at 2:42 PM
    #1094
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Shit... I'm a pilot, not a scientist. Looks broken to me :notsure:
    BOSSARU, snivilous, Mater and 2 others like this.
  15. Apr 10, 2023 at 4:03 PM
    #1095
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    It looks like a multiple origin failure due to overloading. Nothing out of the ordinary. This diagram may help to understand this type of failure.
    snivilous, ATV25 and Sunnier like this.
  16. Apr 10, 2023 at 4:04 PM
    #1096
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    Is the "difference in the metal" you see the color?
  17. Apr 10, 2023 at 4:37 PM
    #1097
    Sunnier
    Sunny
    San Diego, CA
    I'm sorry; I don't understand what you're asking. I used a green coloured marker to encircle the portion of the axle where I perceive the metal is lighter in colour than the remainder of the axle. Whatever the cause, the metal appears "lighter" to me, and in the same area of axle where the other axle broke.
  18. Apr 10, 2023 at 5:01 PM
    #1098
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    I was trying to understand if the color of the metal is what you were talking about. Which you have clarified.
    I will say in this case it is simply a color, and has no bearing on the breakage or breakage points. To simplify the manufacturing process on that part, that shaft is machined and then heat treated. The heat treat is likely where it got that dark color. After heat treat it is ground on specified surfaces. (Those are the shiny surfaces). That's why the "colors" are the way they are.
  19. Apr 10, 2023 at 5:09 PM
    #1099
    Sunnier
    Sunny
    San Diego, CA
    Thank you for the info.
    IMXPLRN[QUOTED] likes this.
  20. Apr 10, 2023 at 5:50 PM
    #1100
    Cruzer
    Cruz
    Sunnyvale, CA
    Hmmmmm you seem to know quite a bit.. do you happen to know of any shops, since you're in NorCal, that can replicate this shaft in a stronger alloy?
    reywcms likes this.
  21. Apr 10, 2023 at 6:20 PM
    #1101
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    Used to have an old millwright that retired and opened up a machine shop as a hobby. That dude could build anything out of metal. He has passed but I am sure you could find someone in your area that could make one out of some kind of billet material.
    Mater likes this.
  22. Apr 10, 2023 at 6:22 PM
    #1102
    snivilous
    SW UT
    Maybe hit up spidertrax?
    Cruzer[QUOTED][OP] likes this.
  23. Apr 10, 2023 at 6:28 PM
    #1103
    Cruzer
    Cruz
    Sunnyvale, CA
    I guess it won’t hurt to ask them. Wasn’t aware they made anything else other than spacers.
  24. Apr 10, 2023 at 7:03 PM
    #1104
    snivilous
    SW UT
    Broooo :D they build the premier off-road axles. Wheel spacers are just what the mall community knows them for. Probably the majority of buggies you see with fabricated axles are spidertrax stuff. All custom from the housings to the axle shafts to the unit bearings and made inhouse. Chromoly, 300M, full float, custom brakes, etc. They build some of the fanciest parts in all of off-road.
  25. Apr 12, 2023 at 7:09 AM
    #1105
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    The problem with getting something custom made is the price. There are shops all over norcal that have the capabilities, but you will pay a ridiculous amount to get one or two made.
    Mater likes this.
  26. Apr 12, 2023 at 9:23 AM
    #1106
    Cruzer
    Cruz
    Sunnyvale, CA
    Yup.
  27. Apr 15, 2023 at 4:38 PM
    #1107
    Cruzer
    Cruz
    Sunnyvale, CA
    Picked up a transfer case today.
  28. Apr 15, 2023 at 8:11 PM
    #1108
    SAGE63
    San Diego County
    did you need a new one? or is it a spare....
  29. Apr 16, 2023 at 6:25 PM
    #1109
    Cruzer
    Cruz
    Sunnyvale, CA
    For parts and to help create an adapter for the Atlas transfer case.
  30. Apr 17, 2023 at 11:59 AM
    #1110
    Cruzer
    Cruz
    Sunnyvale, CA
    What do you think our backup plans should be if trails remain closed?
