Bypass Kit
Discussion in '2nd Gen Tundras (2007-2013)' started by jtg1441, Apr 10, 2023.
  1. Apr 10, 2023 at 6:47 PM
    jtg1441
    jtg1441 [OP] New Member
    HagerHill, KY
    2008 Tundra 4.7
    I'm trying to figure out how to get in touch with someone about a Gen 1 or 2 SAIS Bypass kit. I have no idea which one I need. OBD2 Codes are P0419, C1201, P2433. I was told by a Rutech Representative Via email that a bypass kit would not help. Anyone with any ideas.
  2. Apr 10, 2023 at 6:50 PM
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    If air induction pump does your truck go in limp mode? Search dreaded aip failure Tundratalk in google and you’ll see a bunch of threads on bypass. I have heard of guys being able to take both positive negative cables off battery for 10 min and plug back together to temporary bypass
    jtg1441[OP] likes this.
  3. Apr 10, 2023 at 6:52 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  4. Apr 10, 2023 at 6:55 PM
    jtg1441
    HagerHill, KY
    2008 Tundra 4.7
    Truck is already in limp mode. When I bought the truck it ran fine for a few days and then after I changed the battery out for a new one. The VSC, Trac Control and check engine light came on and I stopped at Autozone and had OBD test and I was gave a print out of the codes. But once I got home and done some research on SAIS I went out and looked under passenger front wheel well and I only have 1 Pump mounted there. Shouldn't there be 2?
  5. Apr 10, 2023 at 6:57 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  6. Apr 10, 2023 at 9:31 PM
    Joro43
    Joro43 New Member
    Pretty sure there is only one AIP pump on the passenger side wheel well. I remember this cause people had mentioned avoiding passenger side with huge puddles
