Grille Swap
Discussion in '3rd Gen Tundras (2022+)' started by chance12, Apr 10, 2023.
  1. Apr 10, 2023 at 1:19 PM
    chance12
    chance12 [OP] New Member
    GA
    23 Tundra CM Limited
    Can anyone tell me if the front facing camera needs to be adjusted after a grille swap (limited to a TRD PRO grille)? I know a relocation bracket is necessary, and I've looked for an answer but have not been able to find any information regarding the camera accuracy after the swap. Thanks for the help...
  2. Apr 10, 2023 at 1:26 PM
    chance12
    GA
    thanks, are we able to do this ourselves or is this dealer required? also-do you know if it voids the warranty?
  3. Apr 10, 2023 at 1:46 PM
    chance12
    GA
    thank you, that's unfortunate especially since I have the extended warranty. the dealership I've had dealings with have been a little sleezy so I have an idea of what they will say..
  4. Apr 10, 2023 at 3:51 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    My dealer said they were not servicing Tacomas that had gone with a knockoff grille and now had parking sensor/cruise control issues. They would only cover the issue if they used a toyota made grille. That sounds fair to me and would totally accept that if I went chinesium and not OEM.
    chance12[OP] and ryanwgregg like this.
  5. Apr 10, 2023 at 4:40 PM
    eddiefromcali
    Eddie
    100% Stock
    Does this actually work? Tried it with power on, not running and couldn't get it to do anything
  6. Apr 10, 2023 at 5:05 PM
    eddiefromcali
    Eddie
    100% Stock
    On/running, screen off via the display option and just swipe right x5 and swipe left x5?
  7. Apr 10, 2023 at 7:19 PM
    eddiefromcali
    Eddie
    100% Stock
    Got it to work, just have no clue what I'm doing. Lol
    ryanwgregg likes this.
  8. Apr 11, 2023 at 4:33 AM
    chance12
    GA
    I can get behind this for sure. I think that is definitely reasonable. My plan was to install OEM PRO grille anyways
  9. Apr 11, 2023 at 6:48 AM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Question regarding the swap to a PRO grill. I’m looking to have my Limited grill swap to a Heritage PRO. A body shop I’m working with mentioned possibly the safety sensor if connected to grill would have to be recalibrated which is pricey. Can anyone confirm where the sensor is located?
  10. Apr 11, 2023 at 6:58 AM
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    It’s the radar at the bottom of the grill. Plenty of us have done the swap with 0 issues and did not recalibrate. You can recalibrate to the new camera position yourself.
    Yota802[QUOTED] and chance12[OP] like this.
  11. Apr 11, 2023 at 7:12 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    I have a limited off road and change my grill to the pro grill. I did not have to do anything being talked about in regards to recalibrating front camera or the radar. It was a 2 hour swap with no problems. I’m lifted 2.75” in the front and had Toyota do the alignment, there has never been an issues from them or with the truck.
    forzamrit, Mattedfred and Yota802 like this.
  12. Apr 11, 2023 at 12:19 PM
    v-wiz
    v-wiz New Member
    Vic
    Lunar Rock Tundra
    I installed a TRD pro grill and absolutely no adjustment was needed. Plug and play using the correct bracket
    forzamrit, Yaboy and Mattedfred like this.
