High transmission temp warning
Discussion in '2.5 Gen Tundras (2014-2021)' started by drgordon13, Apr 10, 2023.
  1. Apr 10, 2023 at 11:14 AM
    drgordon13
    drgordon13 [OP] New Member
    2020 Gray Tundra TSS
    I was recently offroading and had a full truck with rooftop tent...we were going up quite an extended incline at slow speed (I was in 4 wheel hi) and I got a warning for high transmission temp. Stopped the truck and let it cool...warning went off and finished the hill and the rest of the trip with no warning...
    So is it time for a transmission cooing system? I do love offroading and tend to have all my overloading gear...don't want to run into this issue in the future!IMG_7864.jpgIMG_7861.jpgIMG_7869.jpg
    Wallygator likes this.
  2. Apr 10, 2023 at 11:15 AM
    drgordon13
    Also looking for an updated gauge system that will help me monitor transmission temp, etc.
  3. Apr 10, 2023 at 11:17 AM
    Yep. Plenty of discussion on here about this.
    4lo and might wanna consider adding a transmission cooler.
    If you got the light, your trans went over 300*. I would service the transmission. A Scan Gauge III or phone app is what you are looking for.
  4. Apr 10, 2023 at 12:41 PM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    I’ve got the Scan Gauge III and really like it. Can monitor a lot of items all at once.
  5. Apr 10, 2023 at 2:39 PM
    Wallygator
    I use the OBD fusion app and an OBD reader purchased off Amazon. Gives the pan and converter temp readings.
    Also have a cooler but maybe you should have been in 4 low especially with bigger tires/lots of weight, or at least in tow/haul mode and s mode locked in a lower gear, or all the above.
    I drive my truck in tow/haul s-mode 24/7, it makes a difference on the driveability and the trans abuse/temp
    Definitely service the trans as @ColoradoTJ mentioned.
    Nice setup by the way!:thumbsup:
    RustyShackle323 and ColoradoTJ like this.
  6. Apr 10, 2023 at 4:27 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    No cooler needed. Toyota says "ok" good to go, no cooler needed. Let warranty / Toyota cover if an failures occur.
    panicman and hagrid like this.
  7. Apr 10, 2023 at 4:41 PM
    So let's say you have a failure at 58k miles. Will it be covered and why?
  8. Apr 10, 2023 at 8:23 PM
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    Are you able to get engine oil temp with the III?
  9. Apr 10, 2023 at 9:00 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    If a failure occurs it more likely than not going to be outside of the warranty period. As others have said, when off road use 4lo, 4hi is more for on road use like snow, unless you're flying through dunes or something over the speeds for 4lo. I installed the kit from @Genuine Cooling Systems and no longer worry about trans temps although I do still monitor just because I like to, now I stay at a nice 185° - 195° unless going up inclines then it will rise but immediately drop back down quickly afterwards.
    Jtundra81 and Wallygator like this.
  10. Apr 10, 2023 at 9:10 PM
    18" TRD Off Road Wheels
    Slow speed in 4hi will overheat your transmission. If you are going under 20 MPH and need 4WD run it in 4Lo.
  11. Apr 11, 2023 at 4:20 AM
    RustyShackle323
    Stewart
    NC
    I can’t remember, I will check today and up this thread.
    *Update does not appear Toyota offers an engine oil temp to display.
  12. Apr 11, 2023 at 9:53 AM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    I'm not sure if a cooler would have saved the OP in this instance. I think the bigger issue was using 4HI at low speeds.
    If you're not moving very fast, I am not sure that there would be enough air being pushed through the cooler to make a huge difference. I installed a cooler on mine, but the purpose was to help transmission temps when pulling my trailer down the freeway, not for off-roading or 4WD use.
    clownkillerloaf and Jtundra81 like this.
  13. Apr 11, 2023 at 9:57 AM
    eagleguy
    eagleguy New Member
    What does the owners manual say?
  14. Apr 11, 2023 at 10:02 AM
    JDR76
    JDR76 New Member
    WA
    From my 2021 Manual:
    “4H” (high speed position, four-wheel drive)
    Use this for driving only on tracks that permit the tires slide, like off-road,
    icy or snow-covered roads. This position provides greater traction than
    two-wheel drive.
    The “4HI” indicator will come on.
    “4L” (low speed position, four-wheel drive)
    Use this for maximum power and traction. Use “4L” for climbing or
    descending steep hills, off-road driving, and hard pulling in sand, mud or
    deep snow.
    Based on this, I would use 4L at low speeds.
  15. Apr 11, 2023 at 10:10 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I would swap the trans fluid or at least do a drain and fill. And get a trans cooler and monitor trans temps.
    The light coming on means it got REALLY hot. My trans got hot once, and the light didn't even come on and the trans was fried. Though this was a unit with 200k+ on the clock, so I would be proactive now and replace the fluid every couple oil changes.
    Saltyhero13 likes this.
  16. Apr 11, 2023 at 10:13 AM
    That's what the engine fan is for.o_O
    GODZILLA, landphil and JDR76[QUOTED] like this.
  17. Apr 11, 2023 at 10:40 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Another vote from me for the OBD fusion app, its great and its pretty cheap. Like others have said, your main issue was likely the 4Hi. I do mountain offroading and use OBD fusion app and even with the tranny cooler that I put in, it will get hot pretty fast in 4Hi at low speed as there isnt much air flow getting to the tranny cooler. I started using 4lo more after seeing that. I felt like 4lo wasnt needed and it was just working the truck too hard but its actually the opposite. It just uses more gas. Also, I have found that locking the truck in 2nd or 3rd also helps keeps the temps down rather than just offroading in D.
    Wallygator, JDR76 and AZBoatHauler like this.
  18. Apr 11, 2023 at 11:31 AM
    JDR76
    JDR76 New Member
    WA
    Fair point. :D
  19. Apr 11, 2023 at 7:03 PM
    drgordon13
    Thanks for all the input! I am going with the ScanGauge 3...like the little monitor...
    also going to get my transmission serviced and get the cooler added...just a piece of mind thing!
    RustyShackle323 likes this.
  20. Apr 11, 2023 at 7:33 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Don’t forget you also need to regear your truck for the larger tires.
    Kentucky22 and Wallygator like this.
  21. Apr 11, 2023 at 8:51 PM
    Joe333x
    Joe333x Member
    Boston
    I dont know how much that would actually help since the radiator fan is behind the radiator and the trans cooler is installed in front, so your only getting what ever hot air from the radiator gets in front. You could however install a fan onto the trans radiator itself which would definitely help with slow moving off roading.
  22. Apr 11, 2023 at 9:12 PM
    The fan pulls air in. I have a couple fluid coolers before the radiator on my crawler and can definitely tell when the fan is on or high speed.
  23. Apr 11, 2023 at 9:14 PM
    Joe333x
    Joe333x Member
    Boston
    Learned something new today.
  24. Feb 12, 2024 at 8:19 PM
    PROTERRA
    PROTERRA @201.PRO
    Sal
    So Cal
    2024 Tundra TRD PRO
    I’m glad I stumbled upon this. So I had the same warning come up yesterday on my pro. The only difference was that i was in the regular drive mode (2WD) since the trail i was on was nothing crazy. Definitely not one that required to be in 4Lo. The trail consisted of a moderate steep grade for about a mile and a half. Driving never went over 15mph with most of it hovering around 5-7mph’s. Temp outside was at 70 degrees. I’m running 37’s on stock gears and had 3 passengers in the truck along with my baby. I’ve done this trail before with my 19 Tacoma and never had an issue. Trans light came on about 3/4th’s into the trail and I seriously thought it was a joke.
    the only thing i can think of is bringing it up to the dealership but they’re going to tell me to kick rocks since I’m running 37’s.
    anyone run into this issue off-roading in the regular drive mode?
  25. Feb 12, 2024 at 8:44 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Going 5-7mph uphill for a mile and a half in a big heavy truck with tall tires is going to generate a ton of heat in the trans. It's not about the speed, it's about the load on the engine and how much the trans and converter are slipping. 4lo isn't just for rock crawling in these trucks, it takes a ton of stress off the engine and trans and from what I've seen can drop trans temps by 40+ degrees on hills.
  26. Feb 12, 2024 at 8:53 PM
    PROTERRA
    PROTERRA @201.PRO
    Sal
    So Cal
    2024 Tundra TRD PRO
    I understand. I figured the trail wasn’t very difficult or lengthy so I thought I could get away with 2WD with no issues. Ive never had any issues with my other trucks with high temp warnings on easy trails but then again they’ve all been mid size rigs on 35’s.
    My truck has 3777 miles on the odometer. I feel like after getting that warning it’s a must I service the transmission.
    You think I can get away with driving it for another 1300 miles before taking in?
  27. Feb 12, 2024 at 9:02 PM
    I would take it in. Your fluid got very hot and should be changed.
    A re-gear would also be in my future if I rolled around on 37's.
    I have 5.39 gears in my crawler with 39" tires. I couldn't imagine 4.30.
    PROTERRA likes this.
  28. Feb 12, 2024 at 9:10 PM
    PROTERRA
    PROTERRA @201.PRO
    Sal
    So Cal
    2024 Tundra TRD PRO
    I’ll take it in. Rather be safe than sorry.
    unfortunately gears aren’t out yet for the gen 3’s. That was one of the first things on my to do list after going up to 37’s.
    I heard a company was working on them, but can’t remover who.
    ColoradoTJ and helidave like this.
  29. Feb 12, 2024 at 9:51 PM
    helidave
    flagstaff
    2015 DC 4x4
    I used to think the same until I started monitoring my trans temps. It was pretty alarming how hot it got, and how fast it got there.
    That's where an obd2 app or something like an ultragauge comes in handy. You can try the hill (or whatever) in 2wd or 4hi and if it starts to get hot, just switch to 4lo. No guessing, and you'll know what's happening long before it gets hot enough to hurt anything.
    bflooks and PROTERRA[QUOTED] like this.
  30. Feb 12, 2024 at 10:29 PM
    PROTERRA
    PROTERRA @201.PRO
    Sal
    So Cal
    2024 Tundra TRD PRO
    good to know, you live and you learn. Definitely ordering a Scan Gauge after having gone through this. Thanks for the info!
    helidave[QUOTED] likes this.
