Pumpkin options
Discussion in '1st Gen Tundras (2000-2006)' started by ToddsTundra, Apr 10, 2023.
  1. Apr 10, 2023 at 8:27 AM
    ToddsTundra
    ToddsTundra [OP] New Member
    Hey guys and gals. So am I limited to just using the 3.92 pumpkin in my 06 SR5 or are there other better options? I learning as I go. I want to Make my Gen one a real badass and the rear end is next on my hit list to change.
  2. Apr 10, 2023 at 8:30 AM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    I don't know about the pumpkin options, but you may want to consider a harrop supercharger...best bang for your buck!!!!
  3. Apr 10, 2023 at 8:33 AM
    ToddsTundra
    I am still convincing my lovely wife to get onboard with a super charger
  4. Apr 10, 2023 at 8:35 AM
    ToddsTundra
    But definitely one my long term list goals is to supercharge this blue bitch.
  5. Apr 10, 2023 at 8:36 AM
    Your rear gearing options are pretty wide. Your particular use would help determine what would be the best setup. Wheel and tire choice, towing, not towing, upgrade to locker or limited slip etc. 4.10, 4.30, 4.88. and on are available for these trucks. If you're 4WD, you gotta do the front diff too.
    landphil and des2mtn like this.
  6. Apr 10, 2023 at 8:39 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    You can definitely re-gear your differential(s). Some trucks came stock with 4.10 gears, but 4.56 and 4.88 for instance are readily available aftermarket for the 8.4" Tundra rear end.
    This chart is a good starting point, but your use case is a big factor as well.
    393571d1501894616-axle-swap-gear-swap-ge_3b6015cfe407acd5057e537facd35ddf006e89a2.gif
    bmf4069, FrenchToasty and 805Tundra like this.
  7. Apr 10, 2023 at 8:44 AM
    Do us all a favor so we can have more fruitful conversations and help you out.
    Go into your user profile.
    Find the "Vehicle One-Line Description:" box and add the following info:
    • Year
    • Cab type (DC, AC, RC for double, access, regular)
    • Trim package (Limited/SR5/etc.)
    • Engine (V6/V8)
    • Drivetrain (4WD/2WD, include "MT" if manual, include "LSD" if you've got it)
    This helps us skip the "What..." questions on threads like this, or threads where you need help and don't want to re-write your truck details every time.
    /PSA
    Kimosabe, Saltyhero13, N84434 and 2 others like this.
  8. Apr 10, 2023 at 9:40 AM
    Casper421
    In the woods
    06 DC
    Too bad they don’t make it for our trucks. Thanks for stopping in, bye!! :wave:
    bmf4069, Mr.bee, FrenchToasty and 3 others like this.
  9. Apr 10, 2023 at 4:43 PM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Just rock some 26” tires, that will get the pumpkin turnin!
  10. Apr 10, 2023 at 5:26 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    I know the 3.92 and 4.10 were available in Tundras and Sequoias in open and limited slip. Is 4.10:1 the highest stock ratio available, or was there a 4:30?
  11. Apr 10, 2023 at 6:59 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    There was a 4.30 available for early model v-6 trucks. Might have been manual only.
  12. Apr 10, 2023 at 7:21 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Off / On topic . . . where can we find the gear ratio on our trucks?
    I know mines got the Limited Slip . . . the tag is still on the pumpkin, and I visually confirmed.
    2006 DC 2WD SR5 w/ towing package.
  13. Apr 10, 2023 at 7:26 PM
    Vin number on the owners site I believe? Or the old turn and count
    HBTundra[QUOTED] likes this.
  14. Apr 10, 2023 at 10:36 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    This or call the parts dept with your vin.
    I think the DC only had 4.10's for '04. Everything else was some flavor of 3.9 (note there is a slight difference in ratio between 2wd & 4wd, due to actual tooth count).
  15. Apr 10, 2023 at 10:44 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  16. Apr 10, 2023 at 11:01 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Casper421 likes this.
  17. Apr 10, 2023 at 11:10 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Yea, i get better milage with overdrive off under 55. But i wanna swap in a manual 5 speed.
