Soft sided cooler recommendation?
Discussion in 'Outdoors' started by IowaGuy, Apr 10, 2023.
  1. Apr 10, 2023 at 6:41 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I am looking for a soft sided day cooler for trips and day excursions.
    I have a Yeti full size and it works well for our camping trips but it was not cheap. If Yeti soft sided ones are the best then so be it but I imagine there are a lot of other brands now that are just as good.
    I am just looking for something that will hold a few drinks, some sandwiches, cheese and meat sticks and that I can put on the back floor of the truck.
  2. Apr 10, 2023 at 6:45 AM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    I've had great luck with the Walmart Ozark Trail kind, use it at the beach all the time and my drinks stay cold for 4-5 hours on the beach in the sun. It's also about 4 years old now, so I'm sure they're better since then.
    IowaGuy[OP] likes this.
  3. Apr 10, 2023 at 6:47 AM
    Chris the Ogre
    Chris the Ogre Beer fixer
    Santa Barbara
    2003 4X4 AC Tundra TRD
    I have a yeti and an RTIC. the Yeti is a better cooler...but only by a little, like 3 days of cool instead of 2.5. For a few drinks and sandwiches the RTIC will work.
    PermaFrostTRD likes this.
  4. Jun 29, 2023 at 12:21 PM
    Florida AF
    Logan
    North Florida
    My cousin has the Yeti, I have the RTIC and the Yukon. I like the Yukons zipper the best. All hold ice fairly well, especially when iced down the day before.
  5. Jun 29, 2023 at 12:28 PM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    I have an RTIC Soft Pack Cooler & I have nothing but good things to say about it. Good build quality & it definitely will keep ice for a couple days if properly pre-chilled!
  6. Jun 29, 2023 at 1:01 PM
    I bought my mom an RTIC and it only lasted a few times before the zipper broke.
  7. Jun 29, 2023 at 2:10 PM
    2020cement_tundra
    2020cement_tundra New Member
    SC
    2020 tundra
  8. Jun 29, 2023 at 2:18 PM
    I have an Rtic soft side and it has been great.
    Pro tip on the zippers: lube. Frequent lube. The zippers require silicone lube. Frequently. Not lubing will cause them to be hard to open and to bind and get damaged. Lube. Don’t forget the lube!!
  9. Jun 29, 2023 at 2:21 PM
    2020cement_tundra
    SC
    2020 tundra
    Yes good tip, and prechill is a must, here’s a tip also, try salt water. It’s freezes longer than fresh water, we fill up gateraid bottles at the ocean and use those. They actually freeze the melting freshwater ice around them.
  10. Jun 29, 2023 at 2:22 PM
    PermaFrostTRD
    Northern NY
    This.
    My rtic Softie is 6-8 years old or so. Still going strong. I think it’s the “30” Gets us beers, drinks for the kids, some sandwiches etc for a day on the beach. Everything is cold. Don’t even pre-chill. Some can - cutout ice packs that fit in between the cans and a couple of other slim ice packs on top are all that’s needed.
