Suspension stumped
Discussion in 'Suspension' started by Jcmf52, Apr 8, 2023.
  1. Apr 8, 2023 at 9:53 PM
    Jcmf52
    Jcmf52 [OP] New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    Alright, getting ready to upgrade suspension and wanted to get some opinions.
    have a budget of ~3K and limited knowledge of the following options:
    - Icon stage 5 kit w/ UCA (on sale where drops price to ~3.3K and close enough for me to consider)
    - Fox 2.5 factory series coilover w/ rear shocks
    - TRD Fox shock setup (was set on this until recently. Worried that 1.5” lift will make me regret not getting larger lift option or adjustable coilover)
    - Toytec aluma series 2.5 coilovers w/ AAL, bumpstomps, and total chaos UCA
    - King 2.5 coilovers and rear shocks
  2. Apr 8, 2023 at 10:38 PM
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    What’s your plan of usage?
    GODZILLA likes this.
  3. Apr 8, 2023 at 10:44 PM
    Jcmf52
    Rob
    2018-1794 S/C
    Mostly daily driver. Occasional off-road but nothing crazy. Would like to have ability to do some trails in area after lift - again nothing crazy
  4. Apr 8, 2023 at 10:55 PM
    txtundra311
    txtundra311 New Member
    Majority of people want a lift to fit bigger tires, not for actual off-road use.
    That's why I prefer the TRD Fox setup, it's specifically designed for our trucks and is the perfect blend for all my needs.
    Unless you're in the minority of doing extreme off-roading, and tackling complex courses, then King or fox 2.5 with adjustable lift option will be needed.
    The real question is: What do you plan on doing with the truck?
  5. Apr 8, 2023 at 10:56 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I think factory fox have 2” lift. IMO 2” lift is about right, anything higher will just make the wheel look smaller. unless you go for BMC or massive lift all you could stuff inside is a 33-34” tire
    txtundra311 likes this.
  6. Apr 8, 2023 at 11:06 PM
    Jcmf52
    Rob
    2018-1794 S/C
    No specific tire size in mind.
    if Fox factory and King are more offroad focused then would remove from comparison.
    Icon stage 5, Toytec Aluma series 2.5, and TRD Fox
  7. Apr 8, 2023 at 11:30 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  8. Apr 9, 2023 at 10:05 AM
    Jcmf52
    Rob
    2018-1794 S/C
