Need a Power Steering Fluid Recommendation
Discussion in '2.5 Gen Tundras (2014-2021)' started by georgiey22, Apr 7, 2023.
  1. Apr 7, 2023 at 9:22 PM
    georgiey22
    georgiey22 [OP] Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Was at my local Toyota dealer today picking up parts for my wife’s car and asked the dealer to put a small bottle of power steering (PS) fluid on my order. I get home and after working on my wife’s car, I see this.
    What brand are you using? What PS fluid do you recommend?
  2. Apr 7, 2023 at 11:25 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    coldcanuk and Wallygator like this.
  3. Apr 7, 2023 at 11:47 PM
    Chip_Tundra
    Chip_Tundra New Member
    Castrol Transmax Dex VI.
    Leo's first likes this.
  4. Apr 8, 2023 at 12:12 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    00718-ATF00
  5. Apr 8, 2023 at 1:06 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    ATF Dexron IV.... previous owner of my SC400 used power steering fluid and the high-pressure hose has started spraying fluid, maybe it's just old, but it states Dexron II on the lid and when I drained the fluid it came out as some bluish brown fluid. Probably not good for the health of the power steering pump.
    georgiey22[OP] likes this.
  6. Apr 14, 2023 at 7:17 AM
    Retroboy1989
    Northern Utah
    Yep, this is the way to go.
  7. Oct 29, 2023 at 11:21 AM
    rodm1
    rodm1 New Member
  8. Oct 29, 2023 at 7:47 PM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
  9. Nov 4, 2023 at 7:29 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    For p/s. Can this be used? toyota oem is expensive @ $15/quart.
    Leo's first and excelw like this.
  10. Nov 4, 2023 at 9:08 PM
    Sully6
    Sully6 New Member
    Ken
    2020 cement trd off ry
    Any regular atf is fine no need to overthink it
    Leo's first and OHwendTrd like this.
  11. Nov 5, 2023 at 8:01 AM
    Joe333x
    Joe333x Member
    Boston
    Probably be fine, I used the OEM 00718-ATF00 personally. It only takes around 2 quarts.
    OHwendTrd[QUOTED] likes this.
  12. Nov 5, 2023 at 8:15 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Thanks. I’ll use OEM for the transmission but doesn’t appear the P/S is as picky on the fluid, especially since everyone is using a blend of different things.
    Leo's first and Joe333x[QUOTED] like this.
  13. Nov 5, 2023 at 8:26 AM
    Joe333x
    Joe333x Member
    Boston
    Fwiw many people also use Maxlife in the transmission. Just dont use the part number I posted for the transmission, thats just the OEM P/S even though it also says ATF. This is the part number for the Toyota WS fluid 00289ATFWS
  14. Nov 5, 2023 at 9:37 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
  15. Nov 5, 2023 at 9:38 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    As long as it meets Dexron II or III, per manual and cap spec.
  16. Nov 5, 2023 at 9:53 AM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
  17. Nov 5, 2023 at 10:09 AM
    Chip_Tundra
    Hook up a fluid extractor to the outlet tube. Fill and extract until fluid coming out is the color of the new fluid.
    OHwendTrd likes this.
  18. Nov 5, 2023 at 10:16 AM
    WBW
    WBW Resident lurker
    Bruce
    Pardon my ignorance, where is the outlet tube you speak of?
  19. Nov 5, 2023 at 10:28 AM
    Chip_Tundra
    The top hose that is connected to the reservoir. Extract the fluid in the reservoir first, remove top hose and hook up to your extractor. Don't forget to plug the reservoir inlet port.
    Before you start extracting through the hose, fill the reservoir with new fluid. Extract until fluid comes out the same color as new. Do not let the reservoir go empty. This should go without saying, but make sure fluid is at the right level when done.
    Reassemble everything after replacing fluid. Lift the front just enough to lift the tires just above the ground. Turn the ignition on but do not start the truck. Turn the steering wheel full lock each way 5 to 10 times to remove any air in the lines. Drop the truck, check level again.
    LS3, NWPirate and WBW[QUOTED] like this.
  20. Nov 5, 2023 at 10:39 AM
    WBW
    WBW Resident lurker
    Bruce
    Wow. That is extremely helpful! Thank you!
    How did you block the inlet port?
  21. Nov 5, 2023 at 11:16 AM
    Chip_Tundra
    Just buy a universal plug kit at any parts store.
  22. Nov 5, 2023 at 11:32 AM
    WBW
    WBW Resident lurker
    Bruce
    Got it! This is on my list of maintenance items in the very near future.
  23. Nov 5, 2023 at 12:30 PM
    Joe333x
    Joe333x Member
    Boston
    If you own a mityvac mine came with a bunch of different plug caps I used one of those
    WBW[QUOTED] likes this.
  24. Nov 5, 2023 at 1:59 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Me, I just use my manual fluid extractor and pull as much outta the reservoir as possible. My fluid exchange is so frequent that it doesn’t matter if I “get it all” out at once.
  25. Nov 5, 2023 at 2:39 PM
    WBW
    WBW Resident lurker
    Bruce
    I don't change mine nearly as often as you do, so I'm leaning toward the entire system flush. @Chip_Tundra has his method down and seems pretty easy. Quite frankly, if I off-roaded my truck even half as much as my fellow East Valley members I would just do the reservoir exchange more frequently and be done with it.
  26. Nov 5, 2023 at 2:41 PM
    WBW
    WBW Resident lurker
    Bruce
    I do have a Mity Vac extractor. I think my son has it in Tucson. I may just buy a new one so he'll have one too.
  27. Nov 5, 2023 at 2:41 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Lol fluid is cheap. Time is expensive, takes me about a minute to r/r the reservoir…
  28. Nov 5, 2023 at 2:43 PM
    WBW
    WBW Resident lurker
    Bruce
    Ok! THAT is a very convincing and compelling argument! I have nothing to counter that argument. You win, Sir!
    BiggHertz[QUOTED] likes this.
  29. Nov 5, 2023 at 2:43 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Mityvac MVA6851 Fluid Extractor, Syringe Action to Extract and Dispense Fluids Into or Out of Small Reservoirs Including Master Cylinder, Transaxles and Power Steering and Coolant Reservoirs https://www.amazon.com/dp/B00MPQ8RBG
    or
    Mityvac MVA6852 1.5-Liter Manual Fluid Extractor/Dispenser - Master Cylinders, Power Steering, Coolant Reservoirs, Transaxles and Diesel Fuel Filters https://a.co/d/0IC41Nj
    Quick and easy..
  30. Nov 5, 2023 at 2:49 PM
    WBW
    WBW Resident lurker
    Bruce
    I have the big, manual extractor. It is very effective and equally inconvenient for small tasks. Your solution is easier to manage for smaller jobs. I should have it Tuesday from Amazon. Thank you!
