Weird brake issue
Discussion in '2nd Gen Tundras (2007-2013)' started by jbradley702, Apr 5, 2023.
  1. Apr 5, 2023 at 5:48 PM
    jbradley702
    jbradley702 [OP] New Member
    I was driving down the road today, a road I was not accustomed to and there was a stop sign behind a tree that I could not see... Well I slammed on the brakes and I'm fucking terrified.
    My brake pedal got pretty stiff and the truck was barely braking, then all of a sudden the brake returned to "Normal" then the tires screeched and came to a really rough stop.
    The brake and traction control light came on and the VSC light started flashing... As soon as I got to my next stop and restarted the vehicle all lights turned off... This has never happened before, but I've also never needed to stomp on the brakes. This is pretty damn concerning, where do I even begin?
    Thanks!
  2. Apr 5, 2023 at 5:58 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    You could take it to the dealer or trusted shop and ask for a brake inspection.
  3. Apr 6, 2023 at 4:18 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Almost sounds like caliper pins were stuck/frozen
  4. Apr 6, 2023 at 4:20 PM
    jbradley702
    Did some Diag and was able to pull code c1310, followed some steps listed in the protocol and it’s points to replacing ABS control module …
    the part alone is $900 and can’t really be done at home because it needs to be calibrated. I assume it’s going to be close to 2k to fix….
  5. Apr 6, 2023 at 4:22 PM
    Danny3737
    I would still pull the calipers first to make sure they are operating freely.
  6. Apr 6, 2023 at 4:23 PM
    jbradley702
    Doesn’t hurt to check
