  1. Apr 4, 2023 at 8:11 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    I'd go with the LSD if you don't plan on off roading much. I can tell you from experience that a locker isn't necessarily going to save you in wet grass, sand, or mud. Then again, I didn't have any weight over the rear axle on my prerunners
    txagg and daveeasa[QUOTED] like this.
  2. Apr 4, 2023 at 8:19 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    always better to ask for forgiveness rather than permission.
    shifty`, txagg and Tundra2 like this.
  3. Apr 4, 2023 at 9:05 PM
    daveeasa
    Hard to pour a slab without people asking questions.
    txagg likes this.
  4. Apr 4, 2023 at 9:11 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    I also had all the bolts loose on a my stock 1st gen tacoma at 120-130k miles. When I pulled it for 4.88's and locker/torsen. One bolt was hanging on only by 1.5 threads, ready to turn into shrapnel.
    Everything but an open diff carrier is gonna be 2 pieces. OEM lsd, torsen (eaton, powertrax, etc), aftermarket LSD, air/electric lockers.
    Going with red locktite was the right choice. That's what I run, unless I can use factory tabs as well.
    Did you pull the pinion gear to see if it snapped in the middle or front just behind the flange?
    A good LSD will probably be enough. You could do an air locker as well... or go full retard with a spool ;).
    I'm satisfied with an LSD on my 2wd.
  5. Apr 4, 2023 at 9:14 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Ftfy. A 3500 rpm torque converter would help with tight corners.
    txagg and assassin10000[QUOTED] like this.
  6. Apr 4, 2023 at 9:16 PM
    Sunnier
    Sunny
    San Diego, CA
    Mafia dealt with this the most efficient way.
    txagg, Jack McCarthy, bmf4069 and 3 others like this.
  7. Apr 4, 2023 at 9:22 PM
    daveeasa
    The other piece is I have a spare torsen LSD at my gear install guy’s place. So it’s a $1k+ vs free sort of decision. Or maybe rent for him storing it for the past year or so.
    shifty` and DJenerated like this.
  8. Apr 4, 2023 at 9:24 PM
    DJenerated
    Dija
    The Lone Star State
    Sounds like there's nothing to decide. It's practically a done deal
    shifty` and FrenchToasty like this.
  9. Apr 4, 2023 at 9:39 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  10. Apr 4, 2023 at 9:43 PM
    daveeasa
    I should probably go play in the same spot with the two other trucks in 2wd. Especially the 3rd Gen Tacoma in 2 low w locker engaged. It just feels so dirtbag to tear up my own lawn. And we are fairly visible. I need a fence pronto.
    DJenerated and FrenchToasty like this.
  11. Apr 4, 2023 at 9:47 PM
    daveeasa
    I seriously thought about how much work it would be to get the winch finished on the Tundra and use it to pull myself out. Somewhat amusingly, I didn’t own sae hex keys. I ordered a set of Wera and they sent me a single 1/8”. So I have that set resent as of today and hope to have the winch tight on the tundra by the end of the month. Even so, I’d have to block all traffic to winch from pavement which would be super dirtbag. Or winch from the upper mud pit which is nearly as dirtbag. So I think winch extraction from overflow parking is a no go.
    txagg and DJenerated like this.
  12. Apr 4, 2023 at 10:32 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    des2mtn likes this.
  13. Apr 4, 2023 at 10:52 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    txagg and bmf4069 like this.
  14. Apr 4, 2023 at 11:48 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  15. Apr 4, 2023 at 11:52 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Meanwhile where I’m at, 300,000 4 years ago is 800,000 today.. I’m from a once smaller town.. now I see exotic cars daily. And older farm trucks disappearing. Such a sad sight. But we’re close enough to Chicago and it’s gotten to expensive out there, the lawyers and doctors, etc are all moving here
  16. Apr 5, 2023 at 12:16 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Guess it's a 'thing'. I had plenty of preload on my carrier.
    So obviously the bolts being loose are what caused the flange to shear off of the case, but I definitely had them torqued correctly. and now I've just gotta accept the loss? Thats fukt. At least the R&P weren't compromised
  17. Apr 5, 2023 at 12:22 AM
    DJenerated
    Dija
    The Lone Star State
    Damn dude. I'd call ARB and complain. That's too much money to just take a loss, because their product is crappy and they know it
  18. Apr 5, 2023 at 12:34 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    What are they gonna do? Doubt they'll just kick down a new case. Maybe a 15%off coupon for a new locker? fuk that. They do carry a 5 yr warranty........
    @Casper421 There's no way this locker's less than 5 yrs old right? Who'd you buy it from?
  19. Apr 5, 2023 at 12:43 AM
    DJenerated
    Dija
    The Lone Star State
    Well I just hope you don't go quietly
  20. Apr 5, 2023 at 12:46 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Hmmm. Contact arb for a replacement case?
  21. Apr 5, 2023 at 3:27 AM
    A set of traction boards would have done the job too.
    You've got so many projects going on and limited time. I'm not convinced a LSD would make that big of a difference.
  22. Apr 5, 2023 at 4:12 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Up, and down. Up, and down. Bee-bopping, and flip flopping all around. Naur says I, ain't nothing slowing this country boys roll down.
    https://youtu.be/B4c_SkROzzo
  23. Apr 5, 2023 at 4:41 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  24. Apr 5, 2023 at 7:37 AM
    Casper421
    In the woods
    06 DC
    It sure how old it is but I bought it from @AL_TUNDY
    RUSTYNUTS[QUOTED] likes this.
  25. Apr 5, 2023 at 7:44 AM
    Does it have serial numbers on it? Maybe you can contact ARB and see if it’s the part they’ve redesigned and would possibly replace for you do to the design defect failure.
    DJenerated and RUSTYNUTS[QUOTED] like this.
  26. Apr 5, 2023 at 8:06 AM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Just stopping in to say hello!
    Who doesn’t love some new rubber??
  27. Apr 5, 2023 at 8:10 AM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    If anyone was on the fence….
    15% off and free shipping
    “1STGEN10” is the code
  28. Apr 5, 2023 at 8:29 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Any idea how long ago? I'm only askin cuz IIRC you never installed it, and it was in damn near new condition when I got it from you, so it would seem there's a chance it's under 5 years. Then again, people leave uninstalled parts stacked up for years sometimes. I was about to start taggin foo's but I think we're ALL guilty of that shit
    bmf4069 and txagg like this.
  29. Apr 5, 2023 at 8:30 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I've got parts for vehicles i havent had in over a decade.
    bmf4069, txagg, shifty` and 1 other person like this.
  30. Apr 5, 2023 at 8:39 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Yeah, it's worth a shot. I think protocol will be to sell another completely built unit. Selling it on talk of liabilities and whatnot. We'll see...
    txagg and shifty` like this.
