Replacing the battery on a 2018 tindra
Discussion in '2.5 Gen Tundras (2014-2021)' started by Steplift20, Apr 3, 2023.
  1. Apr 3, 2023 at 6:57 PM
    Steplift20
    Steplift20 [OP] New Member
    2018 Tundra
    do you just replace the battery like always or do you have to do something else.? With all the electronics built into these trucks I was wondering if you just change the battery like normal.
  2. Apr 3, 2023 at 7:11 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Like normal.
  3. Apr 3, 2023 at 7:52 PM
    Like normal.
    1st start it will start then stall, just start it again. It will take a few miles to rest the MPG's and miles till empty.
    FrenchToasty and Auwhatfun like this.
  4. Apr 4, 2023 at 4:18 AM
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    and be happy it's not an auto stop start battery at twice the price.
    your 2018 is more analog than the later 2.5 gens, and I won't even get into the electronics "load" on the new Tundra.
    Soupbean77 and Rocko9999 like this.
  5. Apr 4, 2023 at 4:25 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Easy peasy. Do check your connections at the battery. My battery cable ends were crapped out and I replaced them at 45k miles or so.
    Auwhatfun likes this.
  6. Apr 4, 2023 at 10:43 AM
    Rocko9999
    Rocko9999 New Member
    Are the 'start/stop' batteries any different? Seems like a scam.
  7. Apr 4, 2023 at 12:04 PM
    borla123
    borla123 The Pits
    Ontario
    They (edit - are supposed to) have more capacity to take the abuse (on - off - on - off) plus the electronics load.
    I know they cost alot more because my wife has an auto start/stop battery in her Outback.
    She left the cabin light on and forgot about it. Two times. After the second time it cost me $500 for a battery.
    The previous gen Outback battery with no auto start/stop is about $200.
    So I got curious. Toyota wants $250 Cdn for a 2018 - 2021 battery.
    The 2022 is $530 plus taxes.
  8. Apr 4, 2023 at 12:12 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Cody1060, TheBrit, Outbound and 4 others like this.
  9. Apr 4, 2023 at 12:28 PM
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    Just make sure to disconnect the battery before taking it out.
  10. Apr 4, 2023 at 12:30 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Top advice. Can confirm not easy the other way.
  11. Apr 4, 2023 at 1:01 PM
    clarkritchie
    clarkritchie New Member
    Interstate was $105 at Costco. But they don't swap it for you, so bring tools if you want to avoid making a return trip to recycle the old one.
    Rocko9999 likes this.
  12. Apr 4, 2023 at 1:04 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    It must be waaaay better for the environment then. Does it come with a bumper sticker so everyone knows you're a better person than they are?
  13. Apr 4, 2023 at 1:09 PM
    Steplift20
    2018 Tundra
    Thanks for the replys.
    I never thought about the battery for a start stop engine, that is the worst thing for a engine. Maybe just maybe you safe a gallon of gas a year and that's a big maybe.
    So just do it like I have done before on my vehicles.
    Negative disconnect first
    Positive next. And reverse going in.
    So what did you mean. First start than stalls second start good to go. Do it's going to stall on the first start up?
    RichterScale likes this.
  14. Apr 4, 2023 at 1:27 PM
    Rocko9999
    Well my 2021 Rav4 battery didn't have anything special about it. It was built for start stop and still died at 2 years. That's with me disabling start/stop every time I got in the car. Replacement was actually cheaper at the dealer then compared to anyplace else including Costco, which is really strange.
  15. Apr 4, 2023 at 1:56 PM
    borla123
    borla123 The Pits
    Ontario
    Thats interesting about the short life.
    Subaru actually has a battery replacement campaign going on for anyone whose battery has died early.
    I also edited my previous post to say "they are supposed to have" more capacity - 8^0
    I can only verify the double cost.
  16. Apr 4, 2023 at 2:37 PM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    A little off topic but…. I bought a 1989 Celica GT-S new, the first new car I’d ever bought. It had a Panasonic battery in it… 14 years later I had to replace it with a Toyota True Start.
    Leo's first and Rocko9999 like this.
  17. Apr 4, 2023 at 2:38 PM
    Rocko9999
    From what I read, start stop vehicle require an 'enhanced flooded battery'. That is supposed to offer more than double the number of starts when compared to a normal flooded battery. Who knows. Mine certainly didn't last long.
  18. Apr 4, 2023 at 4:09 PM
    Steplift20
    2018 Tundra
    So just forget it like I have done before on my vehicles.
  19. Apr 4, 2023 at 4:40 PM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Yup, and the reason it may stall once or twice is because the computer has to relearn air/fuel mixture - don't take it straight out onto the interstate because it won't start learning until you slow down at the end of an off ramp, which could be 80 miles from home and you've forgotten it needs to relearn stuff...:oops:
  20. Apr 4, 2023 at 4:42 PM
    TheBrit
    Mark
    Do you have to swipe left or right for the 2018 Tindras? ;)
  21. Apr 5, 2023 at 4:31 PM
    eddie98
    eddie98 New Member
    Atlanta, GA
    2018 MGM CM
    N-Fab Podium Steps, Line-X, Bed Lights
    I just replaced mine 3 weeks ago. Went out to lunch and when I came out it was dead. I had to get a jump and go to the autoparts store to get one. It lasted 5 years the OEM one.
  22. Apr 5, 2023 at 6:23 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    My fingers are crossed… just put in a new Optima Yellow Top D35, built this month. Original factory battery went 76k.
    Right now the Optima is $289USD at AutoZone.
    I’ve had a 6v Red Top in my ‘60 VW for 11 years, and it still cranks fine after sitting 7 month stretches.
    clarkritchie, Soupbean77 and V3N0M like this.
  23. Apr 7, 2023 at 2:28 PM
    Steplift20
    2018 Tundra
    I had a 2003 solara that to when you changed the battery you had to start it and let it idle for about 15 minutes for it to read the computer ,it would even stall when you first changed it so I'm thinking the tundra will be the same.It must be a Toyota thing.
    offsetplayer2 likes this.
  24. Apr 7, 2023 at 8:40 PM
    offsetplayer2
    offsetplayer2 New Member
    Woods and Fields, NC
    2018 Inferno CM 4WD
    Mine died picking my son up from school. Got a jump start from someone. I always keep cables in the toolbox. Went to Walmart and to my surprised, they had 27, and 24f batteries. No 27f however. Big difference with the f in the model. I found a very nice 24f that had better cranking and cold amps than the factory. I got that and installed it in the parking lot.
    I was expecting it to die within the year but I’m going on 2 years still starting strong.
  25. Apr 7, 2023 at 8:41 PM
    offsetplayer2
    2018 Inferno CM 4WD
    Mine always stalls out if you disconnect the negative terminal for a few minutes. Doesn’t matter if you change the battery, intake, or just letting it reset for whatever reason. It starts, stalls, and fires right back up. Someone about disconnecting the battery.
    panicman and 1lowlife like this.
  26. Apr 7, 2023 at 9:02 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Can confirm, my Subaru does the same thing.
    my GMC used to that just for fun every so often… usually on my lunch break making me late with My crew in the truck. Sigh.
    offsetplayer2[QUOTED] likes this.
