2.5 Gen CM SR5 4WD - Least worst cheap 2.5 level/lift
Discussion in 'Suspension' started by FO LO, Apr 4, 2023.
  1. Apr 4, 2023 at 8:31 AM
    FO LO
    FO LO [OP] New Member
    17 CM w/ 5.7 and 4.30s
    Looking for the least worst Cheap level kit for a 2017 crewmax 4x4 SR5 that will work good for occasional slow off-road trails and rough dirt roads. I don't need anything fancy or expensive. I want something that they can align correctly and will work with something around 275 70 18 and factory SR rim.
    Main issue that I'm seeing with the cheap level lift kits in the front is not being able to get it aligned right.
  2. Apr 4, 2023 at 8:34 AM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    AggiePhil and FO LO[OP] like this.
  3. Apr 4, 2023 at 8:39 AM
    FO LO
    That's $1k I'm trying to be around the 200 to $300 range. I wonder what it is about the spacer lifts in the front and rear that prevents them from doing the alignment correctly
  4. Apr 4, 2023 at 8:39 AM
    FO LO
    Does anyone have 2.5 or 3-in spacers with a good alignment??
  5. Apr 4, 2023 at 9:12 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    "Least worst cheap" is that some sort of triple negative connotation?
    texasrho83 and crikeymike like this.
  6. Apr 4, 2023 at 9:18 AM
    PermaFrostTRD
    Northern NY
    5100s. $400-500 range plus install.
  7. Apr 4, 2023 at 9:27 AM
    AggiePhil
    College Station, TX
    Buy once, cry once. I don't think you can even get a new radio that cheap, much less a new suspension. Don't put cheap crap on your truck brother.
  8. Apr 4, 2023 at 9:32 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  9. Apr 4, 2023 at 9:38 AM
    FO LO
    Ok I can get adjustable front 5100 on Amazon for $260 with mounting hardware. I should be able to put those on myself with a spring compressor. Looks like I need to be on the middle setting to get leveled with the stock rear on a SR5 4x4. Do I need a diff drop for that setup??
  10. Apr 4, 2023 at 9:40 AM
    no
  11. Apr 4, 2023 at 9:55 AM
    FO LO
    Is this a good deal??
    PermaFrostTRD likes this.
  12. Apr 4, 2023 at 10:15 AM
    Pretty good
  13. Apr 4, 2023 at 10:29 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    if you have the option of getting the shocks pre assembled, its usually worth the cost in headache, safety and renting a spring compress
    FO LO[OP] likes this.
  14. Apr 4, 2023 at 10:37 AM
    PermaFrostTRD
    Northern NY
    @FO LO
    Looks to be a good deal. Worth it to upgrade the rear for another $200 also as they are way easier to install if you're comfortable installing the fronts. Especially if you're rolling on the stock black turd SR5 shocks like I am (I have 5100s just waiting to install in the summer/fall). Also, if you're keeping your tires to 275/70 r18 you don't need to level. Raise it up 1" (roughly) to keep some rake, that way if you tow or haul your truck isn't riding around like it shit its britches.
