RIP TUNDRA? After 7 months in the body shop, now SOLD TO CARMAX
Discussion in '2.5 Gen Builds (2014-2021)' started by M3Tundra-JK, May 20, 2022.
  1. Mar 31, 2023 at 12:42 PM
    #271
    M3Tundra-JK
    M3Tundra-JK [OP] New Member
    Scott
    2005 GX470
    It's already SUA!
    Tripleconpanna likes this.
  2. Mar 31, 2023 at 12:42 PM
    #272
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  3. Mar 31, 2023 at 12:43 PM
    #273
    M3Tundra-JK
    Scott
    2005 GX470
    Also I got a vice and was able to compress the caliper piston in easy enough so don't think it's seized. Didn't see any blown fuse, so it's gotta be that the tail light doesn't have anything plugged in, and causing an open circuit issue, like I had seen in other threads.
  4. Mar 31, 2023 at 12:44 PM
    #274
    M3Tundra-JK
    Scott
    2005 GX470
    Spring Under Axle. Long travel kits convert to it with aftermarket leafs. Or in my case lowered the rear 4" by moving the OEM leaf pack from on top of the axle, to under it
  5. Mar 31, 2023 at 12:49 PM
    #275
    LMAO. Right? 4000w pushing those. The whole trunk is amps.
    e30cabrio[QUOTED] likes this.
  6. Mar 31, 2023 at 12:51 PM
    #276
    e30cabrio
    Also, we all need more cowbell!
    https://youtu.be/cVsQLlk-T0s
  7. Mar 31, 2023 at 1:22 PM
    #277
  8. Mar 31, 2023 at 2:17 PM
    #278
    M3Tundra-JK
    Scott
    2005 GX470
    Ok, bumper is off. Wow, so many sensors to unclip, and it's a three piece bumper?!! Had to completed disassemble it to unclip everything.
    Got the 6 bed bolts removed. Got the fender pulled out enough to get the spare tire on.
    Next step is to go buy some apple juice for my whickey lol.
    I'm hoping the Brake Override Malfunction is due to tail lights not being plugged in...but also one of the plugs is missing, wires pulled out of the socket. I see that wire harness is only $45 from Toyota, but it also looks like it's a plug n play from the diagram, but tracing it back, I don't see a connection point.
    Plan was to get truck started, then back it into the sloped driveway, and slide the bed off into the garage onto a table. We'll see how far I get. Gotta clean up tools and space first and foremost
  9. Mar 31, 2023 at 2:25 PM
    #279
    e30cabrio
    You sir... Are an animal!
    M3Tundra-JK[OP] likes this.
  10. Mar 31, 2023 at 3:06 PM
    #280
    M3Tundra-JK
    Scott
    2005 GX470
    It's delicious!!
  11. Mar 31, 2023 at 4:19 PM
    #281
    M3Tundra-JK
    Scott
    2005 GX470
    Heeey! Was the STOP fuse under the steering wheel that blew. Swear I checked it earlier, but ist one of those tiny fuses and really hard to tell that it blew.
    I had already removed the Setrab tran cooler, but forgot to clamp the hoses! I still need to remove the line, or maybe just reconnect the cooler, idk yet.
    But at least it's off the street and in my driveway again. Need to clear more space and drag my table with wheels out of the basement up to the garage. Then I can think about pulling the bed off
  12. Mar 31, 2023 at 4:21 PM
    #282
    M3Tundra-JK
    Scott
    2005 GX470
    Oh shit! How much does the bed weigh?? I just remembered I have a topper lift rigged up already to hoist the roof off the jeep. Only supports 250lbs, but if I could use it just for a few moments maybe....be a shame if I brought my garage roof down lol
  13. Apr 1, 2023 at 12:10 PM
    #283
    M3Tundra-JK
    Scott
    2005 GX470
    Dude came over to buy Tacoma parts, helped me remove the Tundra truck bed
    chugs, Y0TA PR0, Toyotoholic and 3 others like this.
  14. Apr 1, 2023 at 12:18 PM
    #284
    e30cabrio
    Will she run now?
  15. Apr 1, 2023 at 12:35 PM
    #285
    M3Tundra-JK
    Scott
    2005 GX470
    Technically it will, but I'd need to mock up the taillights and license plate. Out running errands, but I'll have to thoroughly check for undercarriage damage later
    e30cabrio likes this.
  16. Apr 1, 2023 at 2:27 PM
    #286
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    Not sure if I missed it or something, but what’s the short term plan? Reason for pulling the bed off? Just to pull mods off?
  17. Apr 1, 2023 at 3:24 PM
    #287
    M3Tundra-JK
    Scott
    2005 GX470
    To check for frame straightness or any other undercarriage damage. Also the bed as a whole will probably need to be replaced. It's all one piece and more than just the side of it is damaged. And I don't believe the shop is gonna want to cut out the damaged parts and reweld in new parts when it's far less time consuming to just replace the bed.
  18. Apr 1, 2023 at 3:25 PM
    #288
    M3Tundra-JK
    Scott
    2005 GX470
    The frame does seem to measure up side to side at 54 1/4". But the left wheel does seem a little crooked
    chugs and Tripleconpanna like this.
  19. Apr 1, 2023 at 3:38 PM
    #289
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I can’t wait to hear what you’re actually saying once this rhyming and old English filter is gone. :rofl:
  20. Apr 1, 2023 at 3:39 PM
    #290
    Silver17
    Eastern PA
  21. Apr 1, 2023 at 3:39 PM
    #291
    M3Tundra-JK
    Scott
    2005 GX470
  22. Apr 1, 2023 at 5:25 PM
    #292
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :rofl::rofl::rofl:
    Dude, you got hacked!!!!
  23. Apr 3, 2023 at 3:19 PM
    #293
    M3Tundra-JK
    Scott
    2005 GX470
    Only just downloaded the detailed estimate for repairs. They didn't even add costs for all the parts they estimated needed to be replaced! And the labor costs they included are about 1/3 of the actual labor costs
  24. Apr 3, 2023 at 3:23 PM
    #294
    e30cabrio
    That's one way to lower costs.
    lol
  25. Apr 3, 2023 at 4:43 PM
    #295
    Tripleconpanna
    Was that off of a "virtual" or video assessment by an adjuster, or did someone from a bodyshop actually look and produce that estimate??
  26. Apr 3, 2023 at 4:46 PM
    #296
    If they’ll guarantee that estimate for full repair, drop it off today!
  27. Apr 3, 2023 at 4:48 PM
    #297
    M3Tundra-JK
    Scott
    2005 GX470
    That's the insurance adjusters quote that came out. There's a long wait to get a shop estimate. I have to call them back tomorrow cause their secretary that schedules was out. But expecting not to get to it till first week of August. But it's a highly recommend independent shop, Wreck Effects
  28. Apr 3, 2023 at 4:49 PM
    #298
    M3Tundra-JK
    Scott
    2005 GX470
    They can't, and no shop in town is available until June at the earliest
  29. Apr 3, 2023 at 4:52 PM
    #299
    M3Tundra-JK
    Scott
    2005 GX470
    I'll probably end up buying the door skins and replacing those myself. Maybe some other things, but only items they've quoted already. Cause they sent out the quotes check to me without me even asking or approving. Called them up and they said ya, claim will stay open until shop can look at it for the supplemental repairs/costs
  30. Apr 3, 2023 at 5:10 PM
    #300
    Tripleconpanna
    It'll probably double once the body shop has it :(
