2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2021 MODELS [V 2.0]
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by iHacker, Apr 21, 2018.
  1. Jan 3, 2023 at 9:18 AM
    #1471
    Scorpion006
    Scorpion006 I'm athletic - I’m known to surf the web for hours
    Austin, TX
    2017 White Tundra 1794
    @iHacker, sorry if I missed this - but does your harness leave the low beams running when you flash or use the high beam?
  2. Jan 3, 2023 at 8:19 PM
    #1472
    iHacker
    iHacker [OP] SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Yes sir, this is how they should be working in normal conditions. Some of the harnesses around don’t work in this way so be sure before buying yours.
  3. Jan 10, 2023 at 9:12 AM
    #1473
    Tex_Tbone
    Tex_Tbone New Member
    @iHacker I got the harness and new lights installed. Thanks for the quick shipping and very helpful installation instructions! I'm very happy with the harness. Wish I would have found this solution much sooner. Great job!
    iHacker[OP] likes this.
  4. Jan 10, 2023 at 12:02 PM
    #1474
    ToyotaG
    ToyotaG New Member
    almost 2 years with Ihackers harness. ZERO issues to this day. Thanks again
  5. Jan 22, 2023 at 4:33 PM
    #1475
    11ty
    11ty New Member
    @iHacker, I need one of these:
    2014-2017 1794/Platinum/2018-2021 SR5 (Trucks with single LED DRL and halogen headlights) $100
    How do I go about placing an order, and what's the estimated time to ship currently?
    Thanks.
  6. Jan 23, 2023 at 9:14 AM
    #1476
    11ty
    11ty New Member
    Thanks for pasting that - though the original post is ~4.5 years old so I asked what the current timeline is. OP responded and it is still 1-2 days.
    Sierradevil and iHacker[OP] like this.
  7. Jan 23, 2023 at 9:26 PM
    #1477
    iHacker
    Mario
    Thanks for your good feedback, I’m glad everything with your headlights is working as expected :yes:
    Sierradevil likes this.
  8. Jan 24, 2023 at 4:26 AM
    #1478
    PermaFrostTRD
    Northern NY
    Don’t mean to threadjack, but go with Baja Designs squadron sport or Diode Dynamics ss3 pro for your fogs. Many on here prefer them to the rigid fogs. If you’re in any kind of snow belt or drive in some desert dusty off road scenarios, go amber lens. If not, the clear lens will be fine but you will be blown away at the output. Similar from going halogen headlights to LED headlights but even better.
    I have the DD SS3 pros, btw.
  9. Jan 30, 2023 at 6:20 PM
    #1479
    Taco-Spike
    Two Trucks
    You’re in the right place. Follow the steps on the first post of the thread
  10. Feb 2, 2023 at 8:14 PM
    #1480
    Dottat
    Dottat New Member
    Got my harness almost a week ago and the lights today. Upgraded my 2017 platinum to led in about 25 minutes today start to finish. Very easy job.
  11. Mar 7, 2023 at 5:53 PM
    #1481
    kingranch
    kingranch New Member
    Shout out to iHacker
    This is one of the best upgrades you can do and his wiring kit made it so simple
    All in it took me 1 hour with beer breaks-
    I bought the oem trd pro LED set from sparks parts for 641$ shipped plus his wiring kit for 130$ so the swap is right around 760$ total.
    2014 sr5 now a pro lol
  12. Mar 12, 2023 at 12:01 PM
    #1482
    27bluenote
    27bluenote New Member
    2017 Barcelona Red TSS
    Another satisfied customer here. Incredible quality harness and easy to follow instructions. The updated TRD Pro LED headlight assemblies look incredible. Thanks @iHacker
    nhw544, iHacker[OP] and Sierradevil like this.
  13. Mar 19, 2023 at 7:01 AM
    #1483
    TUNDRA180
    TUNDRA180 New Member
    MATT
    2017 BLACK TUNDRA PLATINUM
    Just installed ‘19 TRD Pro LED headlights with the iHacker harness. Truly plug and play and simple. I love the look.
    V3N0M and iHacker[OP] like this.
  14. Mar 30, 2023 at 7:53 AM
    #1484
    sonofdad
    sonofdad New Member
    steamboat springs, co
    2017 Tundra SR5
    finally got my TRD pro LEDs installed using @iHacker's harness. easy-peasy and what a difference in light output! thanks @iHacker :thumbsup:
  15. Mar 30, 2023 at 9:28 AM
    #1485
    NickyF25
    NickyF25 New Member
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    Just traded my 17 Platinum and had iHackers harness and OEM LEDs for about 5 years on it and worked flawless. Although better than the pathetic halogens that came with truck, the 18+ LEDs are still a far cry from other manufacturers LEDs output.
  16. Mar 30, 2023 at 9:39 AM
    #1486
    iHacker
    Mario
    Nice to hear everything worked well so far :cheers:
  17. Mar 30, 2023 at 6:07 PM
    #1487
    InfernoBoyz
    InfernoBoyz YoutubeTech
    Reno, NV
    2016 Inferno Tundra Double Cab OR
    Got mine on! Big fan, just need to get dark so I can go adjust them. Anyone have a good method? Or is it all by feel ?
    Also, I added some LED Blinkers, but they were always on and had a hyper flash. After some research, it’s an issue that requires a resistor - so I went ahead and put the halogen blinkers back in. Anyone deal with the same issue?
    1EBDDD30-531C-40B8-A2AF-FAD80507A847.jpg DEDB2674-130F-4F7C-9446-CA8DEF83E9F0.jpg
    sonofdad likes this.
  18. Apr 1, 2023 at 10:23 AM
    #1488
    stantlinger
    stantlinger New Member
    Scott
    2017 TRD Off Road - Blazing Blue
    Bilstein 5100/6100 Lift Total Chaos Gussets Toytec Driveshaft drop Method MR 308 285/75/18 Wildpeak AT3W Bumper Spacer BMC TRD Pro LEDs w/ihacker harness Bashfab bed rail tire mount
    Just installed TRD Pro LED headlight housings with @iHacker (Lowlife Style) harness. Maybe 1 hour from start to finish. @iHacker instructions were simple and dead on. Should have done this years ago.
    sonofdad, iHacker[OP] and 1lowlife like this.
  19. Apr 14, 2023 at 1:02 PM
    #1489
    Romulus
    Romulus New Member
    2021 Tundra Limited Nightshade in Windchill Pearl
    Where's the cheapest place to buy TRD Pro style headlights at the moment?
    Bowzer likes this.
  20. Apr 14, 2023 at 2:42 PM
    #1490
    TUNDRA180
    MATT
    Sparksparts had the best deal when I ordered mine.
  21. Apr 14, 2023 at 10:41 PM
    #1491
    iHacker
    Mario
    Totally agree on SparksParts and use the code TUNDRAS.COM or TUNDRADUDE34 for 5% off
    https://www.sparksparts.com/tundra-parts
    Another option is trying to get a price match at your local Toyota dealership so that way you get free shipping.
    Good luck!!
    Y0TA PR0 likes this.
  22. Apr 28, 2023 at 11:52 AM
    #1492
    cotten
    cotten New Member
    2021 Tundra SR5 Trail
  23. May 26, 2023 at 5:17 PM
    #1493
    singletrack_dad
    singletrack_dad New Member
    Ty
    2014 TRD OR CM
    MASSIVE thank you and shout out to you Mr OP for this service. I’m looking to grab a pair of oem LED headlights for my 2014 this year and I’ll be buying your harness if you’re still making them!!!!
  24. May 30, 2023 at 6:41 AM
    #1494
    singletrack_dad
    Ty
    2014 TRD OR CM
  25. May 30, 2023 at 7:24 AM
    #1495
    Taco-Spike
    Two Trucks
    I mean if you're just going for an updated look then maybe.
    Quality won't be as good and I doubt output would be as good as well. Just because something looks like OEM does not mean it will perform like OEM. Just get it right the first go around.
    Someone here did post a while back about one noticeable thing, the DRL's were really DIM in daylight and not much better in overcast.
  26. May 30, 2023 at 7:27 AM
    #1496
    singletrack_dad
    Ty
    2014 TRD OR CM
    Totally agree. I just wish there was more videos and threads going over the differences. I can’t believe you can snag the oem versions for $280 each from online dealers. I’m sure there are definitely some differences but I would love some more coverage on the matter. I’m sitting here looking at $400 aftermarket pair vs $566 for an oem pair. Might be better to just slowly buy the oem’s over time even if it takes longer (I know that’s the right answer lol)
    rodm1 and Taco-Spike[QUOTED] like this.
  27. May 30, 2023 at 7:48 AM
    #1497
    singletrack_dad
    Ty
    2014 TRD OR CM
    I talked to a guy who was selling an oddball pair of these on OfferUp. The DS was an oem black housing version and the PS was the smoked TYC aftermarket headlight. Being transparent with him that I wasn’t going to buy them but had some questions about the performance, he said that the output was basically the same but the LED DRL were a little different. Again leading me to want to see some videos on the subject but I think I’ll just buy the OEM’s for $280 ea & suck it up. It’s not much more than $200 ea for aftermarket lol
    Black@Blue19 likes this.
  28. May 30, 2023 at 8:36 AM
    #1498
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    ^^^^ Can’t beat the OEMs! JMO:) and an ihacker harness
  29. Jun 20, 2023 at 12:05 PM
    #1499
    dofu
    dofu New Member
    Dave
    San Jose, CA
    2015 White Tundra Crewmax SR5
    I bought an aftermarket OE Style and love em. I recently went camping and the roads were pitch black. Here’s an example of the light output. IMG_3005.jpgIMG_2902.jpg
    hrv2017, iHacker[OP] and sonofdad like this.
  30. Jul 3, 2023 at 9:52 PM
    #1500
    Trd_Bev
    Trd_Bev New Member
    Joe
    San Diego
    2014 gray Trd 4x4
    Icon 2.5s, method wrapped in 35/12.5/17 bfgs
    @iHacker can I purchase a harness from you please?
