Long Term Parking
Discussion in 'Electrical' started by ZekeBarker, Mar 14, 2023.
  1. Mar 14, 2023 at 12:32 PM
    ZekeBarker
    ZekeBarker [OP] New Member
    2023 1794 Tundra
    I am going to park my 2023 tundra for a period of about seven weeks. Should I disconnect the battery?
  2. Mar 14, 2023 at 12:39 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I usually connect a float charger if going that long.. but disconnect should be fine too.
    bulldog93 likes this.
  3. Mar 14, 2023 at 12:54 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    If parking for that long I would consider removing the battery and trickle charging it if it won’t have to be moved. I would also take preventative measures to reduce the likelihood of any rodent infestation. People use peppermint oil and other sprays. If you’re going to keeps the battery connected there are also electronic deterrents
  4. Mar 14, 2023 at 8:38 PM
    Eddy20
    Eddy20 New Member
    With my Land Cruiser at our second home up north I would just use a battery Tender ($40 on Amazon or Walmart) and leave it for 6-10 weeks and it always started right up. I did not bother disconnecting the battery; just connected to the battery and plugged in the charger.
    Neo258 likes this.
  5. Mar 14, 2023 at 8:41 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    Connect a trickle charger and be done. No need to disconnect the battery.
    Neo258 likes this.
  6. Mar 14, 2023 at 8:47 PM
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    If its practical trickle charger is a good idea, if not I wouldn't worry about it. I've left vehicles sitting for 6 weeks up to a couple months without issue. I left one sitting for 3 months waiting on repairs, cranked over slightly slow, but started right up.
  7. Mar 31, 2023 at 6:23 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    You can also pull the jumper pin in the engine fuse box. That will disconnect all downstream electronics circuits (ECU, GPS, DCIM, etc). That’s how they store and ship them from the factory
    HulkSmurf14 and Jeff_5_7 like this.
