  1. Mar 30, 2023 at 4:04 PM
    Good catch!
    alb1k[QUOTED] likes this.
  2. Mar 30, 2023 at 4:08 PM
    I really need to get a winch. My bumper looks silly without one.
  3. Mar 30, 2023 at 4:09 PM
    Hahah I had one in the 4runner for years…… never wired it
    NUDRAT[OP] and txagg like this.
  4. Mar 30, 2023 at 4:09 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    A lot of options out there. But a lot of us like the Smitty built X 20.
  5. Mar 30, 2023 at 4:09 PM
    Dude if your truck is that capable in 2WD I can't imagine what it would do with 4WD. I typically shit on rear wheel drive trucks here because of our terrain but that is impressive. I'm excited to see it in person.
  6. Mar 30, 2023 at 4:11 PM
    alb1k
    Left Coast
    It's good
    I think I’m getting the most. I can out of 2WD without going crazy suspension. I’m really happy with it. That was a bit of a harder landing than I would have today.
  7. Mar 30, 2023 at 4:14 PM
    Is it just a wire to each battery terminal? Anything else?
  8. Mar 30, 2023 at 4:15 PM
    alb1k
    Left Coast
    It's good
    There’s the wiring between the solenoid and the winch. That’s only challenging if you remote locate your solenoid but yeah, pretty much a hot and a negative.
  9. Mar 30, 2023 at 4:16 PM
    Sunnier
    Sunny
    San Diego, CA
    TBF, that was with a lighter rack tho-. :p
  10. Mar 30, 2023 at 4:16 PM
    I’m guessing your truck would need to relocate the solenoid box, but might be able to keep it close enough to not need to extend any wires, then yeah it’s just running the main power wires to the battery.
  11. Mar 30, 2023 at 4:18 PM
    Yep. That was the problem I was running into. All the winches are taller than the space allowed in my Brute Force bumper. Maybe I'll see what Black Friday brings.
  12. Mar 30, 2023 at 4:19 PM
    alb1k
    Left Coast
    It's good
    Look at that Smitty built both Casper and I fit them inside our coastal, off-road bumpers, which may even be tighter than the brute force
    I did clock my lever towards the radiator, and Casper left his at 12 o’clock, but trimmed it
    definitely have to remote the solenoid, but I managed it without extending cables
  13. Mar 30, 2023 at 4:24 PM
    This one? I'll measure my bumper again.
  14. Mar 30, 2023 at 4:26 PM
    alb1k
    Left Coast
    It's good
    Yeah, that one. I have the 12 K which you don’t really need. But they are the same dimensions.
  15. Mar 30, 2023 at 4:29 PM
    alb1k
    Left Coast
    It's good
    I think without the solenoid on top of that winch body measures between 7 1/2 and 8 inches tall and wide
  16. Mar 30, 2023 at 4:31 PM
    alb1k
    Left Coast
    It's good
    If you like, I can go out and measure my bumper space, and also the winch height
  17. Mar 30, 2023 at 4:40 PM
    6.2x 8.5 tall including the handle, 6.5” without the handle
  18. Mar 30, 2023 at 5:07 PM
    Good. Mine is slightly taller. 8 3/4". I'll keep that winch in mind.
  19. Mar 30, 2023 at 5:08 PM
    daveeasa
    My question is if I can fix the spool or do I have to remove and remount the winch? Got it used and already wound. In other words, can it wind either way or only one way?
    separately I’ll need help figuring out how to mount the control box.
    and I apparently have to buy a driver side mirror still.
  20. Mar 30, 2023 at 5:08 PM
    So you’ll have to get crafty for a relocate for the box
    alb1k and FirstGenVol[QUOTED] like this.
  21. Mar 30, 2023 at 5:22 PM
    alb1k
    Left Coast
    It's good
    Sounds like a remount. Maybe you can reverse polarity, but I don’t think I would try it.
  22. Mar 30, 2023 at 5:39 PM
    daveeasa
    So the control box should be on the passenger side then? Furthest from the battery?
  23. Mar 30, 2023 at 5:40 PM
    daveeasa
  24. Mar 30, 2023 at 5:47 PM
    daveeasa
    Looks like yes, I will have to R&R the bumper. Bummer.
    alb1k likes this.
  25. Mar 30, 2023 at 5:48 PM
    alb1k
    Left Coast
    It's good
    On mine that’s how it is. My gear lever is on the driver side.
  26. Mar 30, 2023 at 5:49 PM
    daveeasa
    F me, costly mistake given that I spent 90m R&R'ing the bumper the first time. Sigh.
  27. Mar 30, 2023 at 5:50 PM
    alb1k
    Left Coast
    It's good
    I didn’t have my winch when I installed my bumper. So I feel your pain I had to do the same.
  28. Mar 30, 2023 at 5:55 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I cant believe this thing still has paint on it.
    Embiggened the air hole from about 7/8" to 1-3/8" really slowed the pulsejet grown to more of a pop pop pop.
    yea, thats a cactus growing without dirt in that big chunk of trunk.
  29. Mar 30, 2023 at 5:58 PM
    daveeasa
    So, anyone able to help me track down a painted white heated driver side mirror for 2000-2006 Tundra RC/AC?
    Man, I am tired. That was 5h at the garage (a bit less). Kinda dark in there, that's one major drawback. My garage has tons o lighting so it's probably the better option. Also no massive need to finish and be driveable, though this garage is quite close and I limped home without the front plate b/c I was outta time and apparently will need to yank all that stuff to redo the winch anyway.
    Also, apparently warn's socket bolts are standard rather than metric so I have to deal with that too.
  30. Mar 30, 2023 at 6:22 PM
    shifty` You can call 1 (800) PP5-1-DooDoo
    Yeah, that could be a hunt to find something here where I wouldn't catch hell and it was dark enough to make adjustments and mark walls and crap.
    Yeah, flat is 1 in 10, they're only flat on the ends. But then you hafta find one dark and low-traffic.
    bmf4069 and FrenchToasty[QUOTED] like this.
