Anyone know how to seal a tire tread puncture that hasn’t gone all the way through?
Discussion in 'Wheels & Tires' started by Jack McCarthy, Mar 30, 2023.
  1. Mar 30, 2023 at 7:11 AM
    Jack McCarthy [OP] It’s always the fuel filter
    Just trying to see if there’s a way to protect the small hole from contamination since it’s gone all the way through the tread block but hasn’t caused a loss of air pressure indicating a leak. Kinda regretting not paying the extra $50 for the road protection on the relatively new front tires.
    519B36C4-B37E-4207-8779-AF53902D4AE1.jpg 34F04B79-81A7-47BF-880A-23F04F86D370.jpg
  2. Mar 30, 2023 at 7:30 AM
    I’m thinking rubber cement but don’t know if it’ll just make things worse over time.
  3. Mar 30, 2023 at 8:58 AM
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    Looks harmless.
    I’ve pulled worse from tires without issue.
  4. Mar 30, 2023 at 10:09 AM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    I don't see it ever being an issue...but if your inclined and have access to a bit of roofing tar, that could be a potential solution. That's the first thing that came to mind. For the size of that screw I don't forsee there ever being a problem for you to waste your time.
    Jack McCarthy[OP] likes this.
  5. Mar 30, 2023 at 10:31 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
  6. Mar 30, 2023 at 10:38 AM
    If it ain’t leaking, don’t worry about it. Good news is, you’ve got one winter stud location drilled out.
  7. Mar 30, 2023 at 11:35 AM
    Mr Badwrench
    Mr Badwrench New Member
    Doesn't look like it went deeper than the tread block. I'd leave it alone.
    Jack McCarthy[OP] and chugs like this.
  8. Mar 30, 2023 at 2:44 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    If I were worried that the screw went deeper than the tread block and the tire might become compromised because of it, I would repair it like any other tire repair: ream out the hole, insert a tire repair band, and cut off the excess.
    It does kind of look like the screw might have been in there deeper than the tread block. Stand the screw up and compare how high it is standing next to a tread block vs how deep it was in the tread block. Might be worth going ahead with an actual repair. If it is compromised, it would be better to address it now rather than later on the side of the road, especially if you don’t carry an air compressor.
    You can judge best in person; we’re all only seeing pics on our phones and other devices.
  9. Mar 30, 2023 at 2:53 PM
    Again, if that were my tire, and it ain’t leaking, I’m not punching a hole in it, just to fix the hole.
  10. Mar 30, 2023 at 3:00 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    In all seriousness you don't need to worry about it.
  11. Mar 30, 2023 at 3:15 PM
    Terndrerrr
    Music City
    6UR-FE
    I’m not saying he needs to. But it looks like it went deeper than just the tread block. And those look like P rated pavement tires. Might spring a leak later on? I’ve had it happen before myself where I pulled a nail and it didn’t start leaking for a long time. I’ve also repaired dozens of punctures. A good repair is not compromised. If I were worried about it, I’d consider a repair just to be on the preventative side of things.
    OP—please don’t use (edit) ONLY rubber cement.
  12. Mar 30, 2023 at 3:48 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Don’t worry about. It is not going to cause any troubles.
  13. Mar 30, 2023 at 3:54 PM
    Rubber cement is part of most tire plug kits and should definitely be used with the plugs for a one and done seal for most punctures. I goop the shit outta my plugs before I put ‘em in. They never leak. Rubber cement alone? Probably unnecessary and not beneficial.
  14. Mar 30, 2023 at 3:55 PM
    I would like to submit exhibit A and exhibit B:
    E3481A43-B380-4D02-9280-F9889CD9268C.jpg 6347AD07-4B92-4C93-8513-EB6FAD186C21.jpg
  15. Mar 30, 2023 at 4:13 PM
  16. Mar 30, 2023 at 5:29 PM
    Terndrerrr
    Music City
    6UR-FE
    While rubber cement is used as a supplement in many repair kits, I would never suggest someone use it by itself for a repair. I thought it was plain that is what I meant. Edited for clarity.
    That top green one pictured is the kit I’ve had the worst luck with. This one pictured below has been the best. The repair strips are giant, and instead of supplemental adhesive, you actually coat them in lube (included) to get them to slide in better. Great kit. I keep it and a small air compressor on board at all times. My last repair was on the side of the interstate, and I must’ve ran over a railroad tie because it took two repair strips to fill the hole.
